Android phones and USB DACs
Sep 15, 2013 at 7:08 AM Post #3,122 of 9,526
This ebay auction ending in 1 hour! $600 value / 2 months old.
Apex Glacier USB dac amp, perfect size for android phones (been using with htc one)
Includes audiophile grade OTG cable device - device
http://www.ebay.com.au/itm/121171191460?ssPageName=STRK:MESELX:IT&_trksid=p3984.m1555.l2649
Sep 15, 2013 at 5:42 PM Post #3,123 of 9,526
Hello everyone,
I have a Nexus 7 2013 and would like some suggestions as to what DAC/Amp I should purchase for it. I was waiting on the FiiO E18 but am curious as to what others are using with their Nexus 7.
Also, is there anything I have to do to the OS in order to get audio out through its port? Thanks...
Sep 15, 2013 at 8:41 PM Post #3,124 of 9,526
So, I had some time with the Z1 and Note 3 over the weekend, in relation to USB DACs I had these results with mine:
Z1: Apex Glacier, HiFimeDIY, Tiny-M working. Pico not working.
Note 3: Pico, HiFimeDIY, Tiny-M working. Apex Glacier not working (very annoying!)
Didn't have time to compare audio properly, had to check loads of other things like camera/connectivity etc. Will do some blind tests at release of these and others, particularly keen to try 24-bit Vs 16-bit and see whether anyone can do better than guessing when blinded.
Sep 16, 2013 at 2:33 PM Post #3,126 of 9,526
It seems Justin has got the Pico dialed in for Samsung devices.  Sadly, it seems not to work consistently for other phones.
When comparing 24 to 16 bit, be mindful of how the files were brought to 16 bit.  If they were truncated, you'll probably hear the difference.  If they were dithered by a quality program, you'll be unlikely to.  I tested this when mastering an album several years ago.  For a while, I trained myself to hear the noise shaping.  I could pick it out in a blind test.  But I can't hear any difference now.  It's very subtle.  24 bit DACs are great mostly because you don't need to worry about them truncating 24 bit files.  And in the end, it would be nice not to have to bother with dithering.
Sep 17, 2013 at 11:57 AM Post #3,127 of 9,526
Quote: 24/96 music file > USB Audio Recorder PRO on Xperia Z Ultra > USB audio out >> USB OTG cable >> FiiO E17 USB DAC/amp >> headphones. @ Danba
I am still trying to understand the difference between native USB audio driver in the Xperia Z and the TL. I have been trying to get UARP working on my Xperia TL for the last few days. I was having no luck on my own and sent the startup log file to audio-evolution. Davy Wentzler at audio-evolution assisted me, however in the end he came to the conclusion that it probably wouldn't work with the TL. His assessment was the native USB audio driver in the TL did not want to give up control to the UARP driver. Davy owns an Xperia Z and is pretty savvy with their phones. I was issued a refund for the app and appreciate Davy's help. I still have Winamp and Neutron and they both work fine. Xperia TL>OTG CABLE>USB isolator>HifiMeDiy U2 asynch DAC>Blaze S1 amp>ZMF T50RP
Sep 17, 2013 at 5:45 PM Post #3,129 of 9,526
Where can I get a cheap all in one cable with Micro A USB OTG on one end and Micro B on the other. Goal is to connect Samsung Galaxy S3 to the Apex Glacier. Apex Glacier has one of these on their web site for $99, which is outrageous for usb cable. I found a $5 one here (http://hakshop.myshopify.com/products/micro-to-micro-otg) but it is sold out. I have 4 hours searching but am really surprised I cannot find a cable. I do not want to piece together cables and adapers - just want ONE wire.Is that asking for too much?
Ideally, I would have a cable only 2 inches in length with right angles connectors on both ends. How can I get one? Links greatly appreciated.
Sep 17, 2013 at 5:56 PM Post #3,130 of 9,526
Those that have the HiFimeDIY Sabre Android DAC - the green LED is supposed to be lit up at all times right?
I received mine and it seems to be defective. The green light only comes on for a second or two, at completely random times and for random amounts of time. Its as if there's a short in it. This happens on both my 2012 Nexus 7 and 2013 Nexus 7 and I haven't had any issues with the USB port on either of them so I think its the DAC that is faulty.
Frustratingly, even when the green LED does come on, the DAC does not work. Can anyone verify that this DAC works with the 2012 and/or 2013 version of the Nexus 7 running stock Android 4.3?
http://hifimediy.com/index.php?route=product/product&product_id=124
Sep 17, 2013 at 6:12 PM Post #3,131 of 9,526
This isn't a perfect fit for what you're looking for but will probably work... ?
http://www.ebay.com/itm/mini-USB-OTG-Host-cable-adaptor-Samsung-Galaxy-S2-I9100-S3-I9300-SIII-S-III-3-/251323217916?pt=US_Cell_Phone_Replacement_Parts_Tools&hash=item3a8407f7fc
Sep 17, 2013 at 6:45 PM Post #3,133 of 9,526
Not cheap but ...
http://www.head-fi.org/t/595071/android-phones-and-usb-dacs/3000#post_9764945
http://www.mimic-cables.com/blogs/news
http://www.head-fi.org/t/595071/android-phones-and-usb-dacs/2190#post_9390822
Sep 17, 2013 at 7:04 PM Post #3,134 of 9,526
A list of stock Android-powered devices reportedly interworking with standard USB DAC:
stock Android device > digital USB audio out >> standard USB DAC >> amp >> headphones
. Acer Iconia Tab A200 using USB Audio Recorder PRO (tablet):
http://www.engadget.com/2012/03/15/acer-iconia-tab-a200-review/
http://www.extreamsd.com/USBAudioRecorderPRO/
. Acer Iconia Tab A500 using USB Audio Recorder PRO (tablet):
http://www.engadget.com/2011/04/26/acer-iconia-tab-a500-review/
. Ainol Novo 7 Flame using USB Audio Recorder PRO (tablet):
http://en.wikipedia.org/wiki/NOVO7
http://forum.hifimediy.com/showthread.php?89-Sabre-Tiny-USB-DAC-compatibility-with-Android-Devices&p=312&viewfull=1#post312
. Archos G9 (tablet):
http://www.anandtech.com/show/5802/the-archos-g9-tablet-reviews-fast-enough
http://forum.xda-developers.com/showthread.php?t=1539576
. Asus FonePad using USB Audio Recorder PRO (tablet):
http://www.engadget.com/2013/02/25/asus-fonepad-announced/
. Asus Memo Pad ME172V using USB Audio Recorder PRO (tablet):
http://www.notebookcheck.net/Review-Asus-Memo-Pad-ME172V-Tablet.89548.0.html
. Asus PadFone using USB Audio Recorder PRO:
http://www.engadget.com/2012/06/12/asus-padfone-review/
. Asus PadFone Infinity using USB Audio Recorder PRO:
http://www.engadget.com/2013/02/25/asus-padfone-infinity-announced/
http://www.head-fi.org/t/595071/android-phones-and-usb-dacs/2175#post_9375965
. Asus Slider using USB Audio Recorder PRO (tablet):
http://www.phonearena.com/reviews/Asus-Eee-Pad-Slider-Review_id2957
http://www.head-fi.org/t/595071/android-phones-and-usb-dacs/1785#post_9220476
. Asus TF101 using USB Audio Recorder PRO (tablet):
http://www.engadget.com/2011/04/18/asus-eee-pad-transformer-uk-edition-review/
. Asus TF201 using USB Audio Recorder PRO (tablet):
http://www.tomshardware.com/reviews/transformer-prime-tf201-tablet-review,3175.html
. Asus TF300 (tablet):
http://www.engadget.com/2012/04/22/asus-transformer-pad-tf300-review/
http://www.head-fi.org/t/595071/android-phones-and-usb-dacs/2475#post_9510187
. Asus TF700 (tablet):
http://www.engadget.com/2012/06/25/asus-transformer-pad-infinity-tf700-review/
http://www.head-fi.org/t/595071/android-phones-and-usb-dacs/2475#post_9510151
. Asus Transformer Prime (tablet):
http://www.engadget.com/2011/12/01/asus-eee-pad-transformer-prime-review/
. CX-919  (mini PC):
http://www.androydz.com/rk3188-quad-core-android-tv-stick/
http://www.freaktab.com/showthread.php?5309-CX-919-rk3188-quad-core-tv-stick-Android-4-2-Official-Firmware-Release&s=0fed1c9ea300e5cb35a655a7b8bcd62a&p=72022&viewfull=1#post72022
. Fujitsu Arrows NX (smartphone):
http://www.theverge.com/products/arrows-nx-f-06e/7058
http://mobileascii.jp/elem/000/000/079/79016/
. Google Galaxy Nexus using USB Audio Recorder PRO (smartphone):
http://www.theverge.com/products/galaxy-nexus-gsm/2946
http://forum.xda-developers.com/showpost.php?p=35484769&postcount=52
. Google Nexus 4 powered by a custom kernel using USB Audio Recorder PRO (smartphone):
http://www.head-fi.org/t/595071/android-phones-and-usb-dacs/2100#post_9340559
http://www.head-fi.org/t/595071/android-phones-and-usb-dacs/2550#post_9557503
. Google Nexus 7 using USB Audio Recorder PRO (tablet):
http://www.engadget.com/2012/06/28/nexus-7-review/
. Google Nexus 7 v2 using USB Audio Recorder PRO (tablet):
http://www.engadget.com/2013/07/24/nexus-7-2013-hands-on/
http://www.head-fi.org/t/595071/android-phones-and-usb-dacs/2700#post_9651395
. Google Nexus 10 using USB Audio Recorder PRO (tablet):
http://www.engadget.com/2012/11/02/nexus-10-review/
http://www.head-fi.org/t/595071/android-phones-and-usb-dacs/1110#post_8973836
. HTC Butterfly / HTC Droid DNA / HTC J Butterfly (smartphone):
http://www.htc.com/www/smartphones/htc-butterfly/
http://www.head-fi.org/t/595071/android-phones-and-usb-dacs/1425#post_9082851
. HTC J One (smartphone):
http://www.engadget.com/2013/05/20/htc-j-one/
. HTC One (smartphone):
http://www.engadget.com/2013/02/19/htc-one-hands-on-design-and-hardware/
http://forum.xda-developers.com/showthread.php?t=2210536
. HTC One X (smartphone):
http://www.engadget.com/2012/04/02/htc-one-x-review/
http://forum.lowyat.net/index.php?showtopic=2222840&st=60&p=57944246&#entry57944246
. HTC One X+ (smartphone):
http://www.engadget.com/2013/02/19/htc-one-whats-changed/
http://www.head-fi.org/t/595071/android-phones-and-usb-dacs/2265#post_9428274
. HTC One XL using USB Audio Recorder PRO (tablet):
http://www.techradar.com/reviews/phones/mobile-phones/htc-one-xl-1120377/review
http://www.head-fi.org/t/595071/android-phones-and-usb-dacs/1830#post_9237213
. Huawei Ascend D1 Quad XL using USB Audio Recorder PRO (smartphone):
http://www.engadget.com/2012/10/20/huawei-ascend-d1-quad-xl-review/
http://www.head-fi.org/t/628254/fiio-e18/15#post_8988466
. Hyundai T7 using USB Audio Recorder PRO (tablet):
http://engadgetandroid.com/hyundai-t7-a-tablet-style-samsung.html
http://www.head-fi.org/t/595071/android-phones-and-usb-dacs/2745#post_9661439
. iMito MX1 (mini PC):
http://www.squidoo.com/imito-mx1-android-mini-pc-bluetooth
http://www.armtvtech.com/armtvtechforum/viewtopic.php?f=81&t=669&start=10
. iOCEAN X7 using USB Audio Recorder PRO (smartphone):
http://iocean.androidguruz.com/
http://chinandroidhospital.com/viewtopic.php?f=344&t=576
. iRiver WOWtab (tablet):
http://liliputing.com/2013/02/iriver-introduces-the-wowtab-7-inch-tablet-leaves-out-the-wow-factor.html
http://av.watch.impress.co.jp/docs/review/review/20130802_610089.html
. LG Optimus G using USB Audio Recorder PRO (smartphone):
http://www.engadget.com/2012/10/19/lg-optimus-g-review-a-quad-core-powerhouse-with-nexus-aspiratio/
. LG Optimus G Pro (smartphone):
http://www.engadget.com/2013/02/25/lg-optimus-g-pro-hands-on/
http://www.head-fi.org/t/595071/android-phones-and-usb-dacs/2295#post_9450152
. MK808 / MK808B (mini PC):
http://www.squidoo.com/mk808-dual-core-android-mini-pc-review
http://www.head-fi.org/t/595071/android-phones-and-usb-dacs/2505#post_9528413
. Meizu MX Quad-Core using USB Audio Recorder PRO (smartphone): to be confirmed
http://www.xda-developers.com/android/meizu-mx-quad-core-review/
http://www.head-fi.org/t/642504/xduoo-new-company-making-interesting-portable-dac-and-amp-units#post_9027380
http://www.head-fi.org/t/595071/android-phones-and-usb-dacs/2235#post_9415543
. Minix Neo G4 (mini PC):
http://www.squidoo.com/minix-neo-g4-review
http://www.facebook.com/minixtech/posts/466648763397297
. Minix Neo X5 (mini PC):
http://tabletrepublic.com/forum/android-mini-pc/minix-neo-x5-google-tv-box-16gb-android-4-1-bluetooth-review-3241.html
http://forum.audiogon.com/cgi-bin/fr.pl?ddgtl&1358382120&openflup&5&4
. Minix Neo X7 (mini PC):
http://blog.geekbuying.com/index.php/2013/08/06/minix-neo-x7-rk3188-quad-core-android-4-2-tv-box-review/#.UijPxtL0FTl
http://www.head-fi.org/t/595071/android-phones-and-usb-dacs/3030#post_9776265
. Motorola Photon Q using USB Audio Recorder PRO (smartphone):
http://www.engadget.com/2012/08/21/motorola-photon-q-4g-lte-review/
. Motorola Razr HD / Razr Maxx HD using USB Audio Recorder PRO (smartphone):
http://www.engadget.com/2012/10/19/droid-razr-hd-and-razr-maxx-hd-review/
. Motorola Xoom using USB Audio Recorder PRO (tablet):
http://www.engadget.com/2011/02/23/motorola-xoom-review/
. Mpman Mid43c using USB Audio Recorder PRO (tablet):
http://komputer.t0ko.com/tablet/mid43c-tablet-8-gb/
. Pipo M9 using USB Audio Recorder PRO (tablet):
http://www.freaktab.com/showthread.php?5001-Strong-is-beautiful-in-Depth-Review-of-the-PIPO-M9-Quad-Core-Tablet
http://www.tellementnomade.com/forum/viewtopic.php?p=151754#p151754
. Rikomagic MK802 (mini PC):
http://en.wikipedia.org/wiki/Android_Mini_PC_MK802
http://www.squidoo.com/mk802-troubleshooting-guide#module163647104
. Samsung Galaxy Camera (camera):
http://www.digitaltrends.com/digital-camera-reviews/samsung-galaxy-camera-ek-gc100-review/
http://www.sogi.com.tw/android/article_list.aspx?OsId=1&topic_ID=6205384
. Samsung Galaxy Mega (smartphone):
http://www.engadget.com/2013/07/02/samsung-galaxy-mega-review/
http://hifimediy.com/index.php?route=product/product&path=62&product_id=124
. Samsung Galaxy Note 2 (smartphone):
http://www.engadget.com/2012/10/08/samsung-galaxy-note-ii-review/
. Samsung Galaxy Note 3 (smartphone):
http://www.engadget.com/2013/09/04/galaxy-note-3-whats-changed/
http://www.head-fi.org/t/595071/android-phones-and-usb-dacs/3120#post_9806895
. Samsung Galaxy Note 8.0 using USB Audio Recorder PRO (tablet):
http://www.engadget.com/2013/04/09/samsung-galaxy-note-8-review/
. Samsung Galaxy Note 10.1 (tablet):
http://phandroid.com/samsung-galaxy-note-10-1/
http://www.head-fi.org/t/595071/android-phones-and-usb-dacs/645#post_8814831
. Samsung Galaxy R using USB Audio Recorder PRO (smartphone):
http://www.engadget.com/2011/08/10/samsung-galaxy-r-officially-announced-for-europe-and-asia-nobod/
. Samsung Galaxy S3 (smartphone):
http://www.theverge.com/2012/5/25/3042640/samsung-galaxy-s-iii-review
. Samsung Galaxy S4 (smartphone):
http://www.engadget.com/2013/04/24/samsung-galaxy-s-4-review/
http://forum.xda-developers.com/showthread.php?t=2252618
. Samsung Galaxy Tab 7.7 using USB Audio Recorder PRO (tablet):
http://www.engadget.com/2012/02/07/samsung-galaxy-tab-7-7-review-international-edition/
. Samsung Galaxy Tab 10.1 using USB Audio Recorder PRO (tablet):
http://www.engadget.com/2012/05/15/samsung-galaxy-tab-2-10-1-review/
. Sony Tablet S / S1 using USB Audio Recorder PRO (tablet):
http://en.wikipedia.org/wiki/Sony_Tablet_S1
http://www.head-fi.org/t/595071/android-phones-and-usb-dacs/1725#post_9176002
. Sony Xperia A (smartphone):
http://www.engadget.com/2013/05/08/sony-xperia-a-passes-through-the-fcc/
. Sony Xperia Acro S using USB Audio Recorder PRO (smartphone):
http://forum.xda-developers.com/forumdisplay.php?f=1945
. Sony Xperia Arc S using USB Audio Recorder PRO (smartphone):
http://www.engadget.com/2011/11/06/sony-ericsson-xperia-arc-s-review/
. Sony Xperia GX (smartphone):
http://www.engadget.com/2012/08/09/sony-xperia-gx-release-date/
http://bbs.kakaku.com/bbs/K0000183708/SortID=16380480/
. Sony Xperia P using USB Audio Recorder PRO (smartphone):
http://www.engadget.com/2012/06/03/sony-xperia-p-review/
http://www.head-fi.org/t/595071/android-phones-and-usb-dacs/1635#post_9131701
. Sony Xperia S using USB Audio Recorder PRO (smartphone):
http://www.engadget.com/2012/03/08/sony-xperia-s-review/
. Sony Xperia SP (smartphone):
http://www.engadget.com/2013/05/14/sony-xperia-sp-review/
http://www.head-fi.org/t/595071/android-phones-and-usb-dacs/2700#post_9652032
. Sony Xperia Sola using USB Audio Recorder PRO (smartphone): “powered” USB hub required for 500mA USB DAC
http://www.androidcentral.com/device/sony-xperia-sola
http://www.head-fi.org/t/595071/android-phones-and-usb-dacs/2745#post_9661802
. Sony Xperia Tablet Z (tablet):
http://www.engadget.com/2013/05/30/sony-xperia-tablet-z-review/
http://talk.sonymobile.com/thread/140910
. Sony Xperia TL (smartphone):
http://www.engadget.com/2012/11/02/sony-xperia-tl-review-android/
http://www.head-fi.org/t/595071/android-phones-and-usb-dacs/2835#post_9688751
. Sony Xperia V (smartphone):
http://www.gsmarena.com/sony_xperia_v-review-877.php
http://www.head-fi.org/t/595071/android-phones-and-usb-dacs/1800#post_9225211
. Sony Xperia Z (smartphone):
http://www.engadget.com/2013/02/20/sony-xperia-z-review/
http://forum.xda-developers.com/showthread.php?t=2177991
. Sony Xperia Z Ultra (smartphone):
http://www.engadget.com/2013/07/02/sony-xperia-z-ultra-benchmark-camera/
http://forum.xda-developers.com/showthread.php?p=45027345#post45027345
. Sony Xperia Z1 (smartphone):
http://www.engadget.com/2013/09/04/sony-xperia-z1-hands-on/
. Sony Xperia ZL (smartphone):
http://www.engadget.com/2013/04/10/sony-xperia-zl-review/
http://forums.overclockers.com.au/showpost.php?s=00bf76e604f9f640c25e08fabf0ed42e&p=15240770&postcount=174
. Sony Xperia ZR (smartphone):
http://www.gsmarena.com/sony_xperia_zr-5421.php
http://www.head-fi.org/t/595071/android-phones-and-usb-dacs/2655#post_9632318
. Toshiba AT300 using USB Audio Recorder PRO (tablet):
http://www.digitalversus.com/tablet/toshiba-at300-p14161/test.html
http://www.droidforums.net/forum/new-member-introductions-site-assistance/238370-new-member-old-question-usb-dac-issue.html#post2388967
. Toshiba Thrive using USB Audio Recorder PRO (tablet):
http://www.engadget.com/2011/07/22/toshiba-thrive-review/
. Tronsmart MK908 (mini PC):
http://blog.geekbuying.com/index.php/2013/04/19/tronsmart-mk908-another-rk3188-quad-core-mini-pc-tv-box-release-review/#.UbpOVtguiSo
http://forum.xda-developers.com/showpost.php?p=42118398&postcount=33
. Tronsmart T428 (mini PC):
http://blog.geekbuying.com/index.php/2013/04/17/tronsmart-t428-ready-to-shipcome-with-android-4-2-jelly-bean-first-review-here/
http://blog.geekbuying.com/index.php/2013/06/17/tronsmart-t428-new-android-4-2-firmware-comingfix-usb-audio-problem/#.UcDCvaL0FTk
. Vivo Xplay (smartphone):
http://www.engadget.com/2013/05/07/vivo-xplay-phone/
https://www.facebook.com/photo.php?fbid=452989528133363&set=pb.368432713255712.-2207520000.1378667838.&type=3&theater
. Wiko Cink King using USB Audio Recorder PRO (smartphone):
http://www.wikomobile.com/telephone-portable-Cink-king.php
. Xiaomi Mi-2  using USB Audio Recorder PRO (smartphone):
http://www.engadget.com/gallery/xiaomi-phone-2-mi2-hands-on/
http://miuiandroid.com/community/threads/does-mi2-support-usb-dac.21361/#post-173635
The user interface of the USB Audio Recorder PRO player is rather basic, but it now has a shuffle play mode. It can transmit 24/192, and "output very natural sound".
http://www.head-fi.org/t/595071/android-phones-and-usb-dacs/3045#post_9781111
http://www.head-fi.org/t/595071/android-phones-and-usb-dacs/2475#post_9511194
http://www.head-fi.org/t/595071/android-phones-and-usb-dacs/1305#post_9034501
http://www.head-fi.org/t/595071/android-phones-and-usb-dacs/2490#post_9515594
http://www.head-fi.org/t/595071/android-phones-and-usb-dacs/2655#post_9634800
http://www.head-fi.org/t/595071/android-phones-and-usb-dacs/2505#post_9530265
A list of standard USB DAC reportedly interworking with the Android-powered smartphone Samsung Galaxy S3:
stock Samsung Galaxy S3 > digital USB audio out >> USB OTG cable (ID pin grounded) >> standard USB DAC >> amp >> headphones
. ALO audio The International using USB Audio Recorder PRO (USB DAC/amp):
http://audio-head.com/the-international-headphone-ampdac-by-alo-audio/#more-1002
http://www.head-fi.org/t/595071/android-phones-and-usb-dacs/1590#post_9117178
. ALO audio The Pan Am in USB debugging mode, or using USB Audio Recorder PRO (USB DAC/amp):
http://audio-head.com/the-alo-pan-am-desktop-headphone-amplifier-and-usb-dac-review/
http://www.head-fi.org/t/595071/android-phones-and-usb-dacs/2565#post_9574726
. AMB Gamma 1:
http://www.amb.org/audio/gamma1/
http://www.head-fi.org/t/608535/wolfson-dac-confirmed-for-galaxy-s3/780#post_8750043
. AMB Gamma 2:
http://www.amb.org/audio/gamma2/
http://forum.xda-developers.com/showpost.php?p=27247705&postcount=279
. Apex Glacier (USB DAC/amp):
http://www.ttvjaudio.com/Apex_High_Fi_Audio_Glacier_portable_headphone_amp_p/aaa0000010.htm
http://www.head-fi.org/t/608535/wolfson-dac-confirmed-for-galaxy-s3/825#post_8776449
. Asus Xonar U3 (USB DAC/amp):
http://www.asus.com/Multimedia/Audio_Cards/Xonar_U3/
http://mybroadband.co.za/vb/showthread.php/429589-Samsung-Galaxy-S3?s=1a313fae4795a9a7493a6ce0f677ca8e&p=8551119&viewfull=1#post8551119
. Atoll DAC 100:
http://www.6moons.com/audioreviews/atoll2/atoll.html
http://forum.xda-developers.com/showpost.php?p=35266076&postcount=17
. Audinst HUD-mx2 (USB DAC/amp):
http://earmass.com/2013/03/24/audinst-hud-mx2-versatile-dacamp-combo/
http://www.head-fi.org/t/595071/android-phones-and-usb-dacs/1890#post_9264638
. Audio-gd Sparrow Version A (USB DAC/amp):
http://www.audio-gd.com/Pro/Headphoneamp/Sparrow/SparrowEN.htm
http://www.head-fi.org/t/595071/android-phones-and-usb-dacs/915#post_8907415
. AudioQuest DragonFly using USB Audio Recorder PRO:
http://www.stereophile.com/content/audioquest-dragonfly-usb-da-converter
http://www.head-fi.org/t/595071/android-phones-and-usb-dacs/1680#post_9151794
http://www.head-fi.org/t/595071/android-phones-and-usb-dacs/2790#post_9676543
. Behringer UCA202 (USB DAC/amp):
http://www.behringer.com/EN/Products/UCA202.aspx
http://www.head-fi.org/t/595071/android-phones-and-usb-dacs/240#post_8654226
. Behringer UCA222 (USB DAC/amp):
http://www.behringer.com/en/Products/UCA222.aspx
http://www.computeraudiophile.com/f6-dac-digital-analog-conversion/usb-audio-enabled-android-powered-samsung-galaxy-s-iii-12338/#post171651
. Beresford Caiman:
http://www.techradar.com/reviews/audio-visual/hi-fi-and-audio/hi-fi-accessories/beresford-caiman-673787/review
. C-Media CM119 chipset-based sound card Dynamode 7 channel USB 2.0 (USB DAC/amp):
http://alatest.com/reviews/audio-accessories/dynamode-7-channel-usb-2-0-sound-card/po3-149540433,95/
http://forum.xda-developers.com/showpost.php?p=27604946&postcount=449
. C-Media CM6911 chipset-based sound card 3D Sound (USB DAC/amp):
http://www.ebay.co.uk/itm/USB-External-3D-5-1-Channel-Audio-PC-Sound-Card-Adapter-/310227918523?pt=UK_Computing_ComputerComponents_SoundCards&hash=item483b065ebb&clk_rvr_id=448505625943&afsrc=1
http://www.droidforums.net/forum/android-forum/197454-enable-usb-audio-any-android-4-0-device-7.html#post2378579
. Cakewalk Sonar SPS 25:
https://www.cakewalk.com/support/kb/reader.aspx/2007013101
. Cambridge Audio DacMagic:
http://www.headfonia.com/cambridge-dacmagic-review/
http://www.head-fi.org/t/631855/galaxy-s3-and-ca-dacmagic-plus#post_8899779
. Cambridge Audio DacMagic Plus using USB Audio Recorder PRO (USB DAC/amp):
http://www.whathifi.com/review/cambridge-audio-dacmagic-plus
http://www.head-fi.org/t/595071/android-phones-and-usb-dacs/1980#post_9304294
. CEntrance DACmini using USB Audio Recorder PRO (USB DAC/amp):
http://centrance.com/products/dacmini/
http://www.head-fi.org/t/595071/android-phones-and-usb-dacs/1200#post_8998731
. CEntrance DACport using USB Audio Recorder PRO (USB DAC/amp):
http://www.avguide.com/review/centrance-dacport-2496-usb-dacheadphone-amplifier-playback-34
http://www.facebook.com/photo.php?fbid=635892416426250&set=a.634656613216497.1073741826.110473262301504&type=1&theater
. CEntrance DACport LX using USB Audio Recorder PRO:
http://www.headfonia.com/cheaper-better-the-centrance-dacport-lx/
http://www.head-fi.org/t/595071/android-phones-and-usb-dacs/1755#post_9188208
. Citypulse DA2.03e (USB DAC/amp):
http://www.citypulse-audio.com/2,03e.htm
http://www.head-fi.org/t/595071/android-phones-and-usb-dacs/1710#post_9162300
. Corsair HS1 Gaming headset (USB DAC/amp/headphones):
http://www.anandtech.com/show/3989/corsair-hs1-gaming-headset
http://forum.xda-developers.com/showthread.php?p=27238117#post27238117
. Creative Xmod:
http://reviews.cnet.com/external-audio-adapters/creative-xmod/4505-9335_7-32105686.html
http://www.forum-audiophile.fr/musique-demat/fonction-usb-audio-a-activer-dans-android-t24441-60.html#p336853
. Cypher Labs AlgoRhythm Solo –dB using USB Audio Recorder PRO:
http://headfonics.com/2013/03/cypher-labs-algorhythm-solo-db/
http://cypherlabs.com/blog/post/android-devices-play-high-resolution-audio-using-the-algorhythm-solo-db
. Dared MP 5 or ALO JV5 (USB DAC/amp):
http://www.positive-feedback.com/Issue24/dared_mp5.htm
http://www.head-fi.org/t/595071/android-phones-and-usb-dacs/990#post_8948190
. ELE EL-D01:
http://www.head-fi.org/t/586909/the-discovery-thread-new-dannybs-first-take-ath-ckn50-pg383-ele-hi-fi-usb-18-dac-pg-328/4905#post_8886336
http://www.head-fi.org/t/642554/fiio-e7-galaxy-s3-questions-for-car-audio/15#post_8991125
. FiiO E7 (USB DAC/amp):
http://www.headfonia.com/fiio-e7-portable-dac/
http://www.androidnz.net/2012/07/galaxy-s-iii-real-user-review-part-2.html
. FiiO E07K Andes (USB DAC/amp): to be confirmed
http://headfonics.com/2012/12/fiio-e07k-the-andes/
http://www.head-fi.org/t/638910/new-fiio-e07k-andes-information-and-impressions/15#post_8924515
http://www.head-fi.org/t/628254/fiio-e18/15#post_8973799
. FiiO E10 using USB Audio Recorder PRO (USB DAC/amp):
http://www.headfonia.com/the-latest-must-have-the-fiio-e10-usb-dacamp/
http://www.head-fi.org/t/595071/android-phones-and-usb-dacs/2010#post_9319171
. FiiO E17 using USB Audio Recorder PRO (USB DAC/amp):
http://www.headfonia.com/the-upgrade-fiio-e17-alpen/
http://www.head-fi.org/t/595071/android-phones-and-usb-dacs/1020#post_8958018
. Furutech ADL Cruise (USB DAC/amp):
http://www.furutech.com/a2008/product2.asp?prodNo=399
http://www.head-fi.org/t/608535/wolfson-dac-confirmed-for-galaxy-s3/585#post_8567838
. GoVibe DAC:
http://jaben.net/forums/index.php?topic=2824.0
http://forum.lowyat.net/index.php?showtopic=2440879&st=500&p=53317360&#entry53317360
. GoVibe Mini USB DAC:
http://www.head-fi.org/t/566934/introducing-the-govibe-mini-usb-dac
http://www.head-fi.org/t/614111/finally-digital-out-for-galaxy-siii/15#post_8525675
. GoVibe Petite (USB DAC/amp):
http://www.head-fi.org/t/290711/govibe-petite-dac-amp-appreciation-thread-pics-little-update
http://www.head-fi.org/t/595071/android-phones-and-usb-dacs-how-to-increase-the-issues-priority-with-google/195#post_8552452
. Graham Slee Bitzie (USB DAC/amp):
http://www.gspaudio.co.uk/bitzie-usb-dac-external-soundcard.htm
http://www.head-fi.org/t/595071/android-phones-and-usb-dacs/1725#post_9165957
. HRT HeadStreamer (USB DAC/amp):
http://www.headfonia.com/hrt-headstreamer-review/
http://www.head-fi.org/t/608535/wolfson-dac-confirmed-for-galaxy-s3/750#post_8677483
. HRT microStreamer (USB DAC/amp):
http://news.cnet.com/8301-13645_3-57570860-47/a-budget-priced-audiophile-usb-digital-converter/
http://www.head-fi.org/t/595071/android-phones-and-usb-dacs/1635#post_9132299
. HRT Music Streamer II:
http://highresolutiontechnologies.com/music-streamer-ii
http://www.head-fi.org/t/608535/wolfson-dac-confirmed-for-galaxy-s3/465#post_8534856
. HeadAmp Pico USB DAC/Amp: bug fixed by HeadAmp
http://www.head-fi.org/t/258967/headamp-pico-portable-amp-w-optional-upsampling-24-96-usb-dac-pre-order-thread
http://www.head-fi.org/t/632019/apex-glacier-amp-dac-review-and-appreciation-thread/270#post_9036297
http://www.head-fi.org/t/595071/android-phones-and-usb-dacs/1305#post_9037872
. HeadAmp Pico Upsampling USB DAC:
http://www.headamp.com/pico/pico_usb_dac/index.htm
. HeadRoom Total BitHead (USB DAC/amp):
http://www.headphone.com/learning-center/bithead-faq.php
http://www.head-fi.org/t/595071/android-phones-and-usb-dacs-how-to-increase-the-issues-priority-with-google/135#post_8527516
. HeadStage USB DAC cable:
http://www.inearmatters.net/2010/04/short-review-headstage-usb-dac-cable.html
http://www.headphiles.org/index.php/topic,4452.msg241979.html#msg241979
. HiFiMan Express HM-101:
http://www.head-fi.org/t/571330/hifiman-express-brand-and-hm-101-portable-usb-dac
http://forum.xda-developers.com/showpost.php?p=27284184&postcount=291
. HiFimeDIY Sabre Android DAC:
. HiFimeDIY Sabre Tiny USB DAC:
http://hifimediy.com/index.php?route=product/product&path=62&product_id=107
http://forum.hifimediy.com/showthread.php?89-Sabre-Tiny-USB-DAC-compatibility-with-Android-Devices&s=c5c822c2ffc8aafc13dd6135f9cd235c&p=345&viewfull=1#post345
. HiFimeDIY Sabre USB DAC using USB Audio Recorder PRO:
http://hifimediy.com/index.php?route=product/product&product_id=83
http://forum.xda-developers.com/showpost.php?p=36704343&postcount=75
. Hippo CriCri+ using USB Audio Recorder PRO (USB DAC/amp):
http://www.head-fi.org/t/626412/review-hippo-cricri-what-more-could-you-ask-from-this
http://forum.lowyat.net/index.php?showtopic=2222840&st=60&p=57358183&#entry57358183
. iBasso D-Zero (USB DAC/amp):
http://www.ibasso.com/en/products/show.asp?ID=73
http://www.head-fi.org/t/571116/review-ibasso-d-zero-with-fiio-e7-comparison/30#post_8933882
. iBasso D zero-SE (USB DAC/amp):
http://www.hibino-intersound.co.jp/information/3462.html
http://av.watch.impress.co.jp/docs/news/20130610_602920.html
. iBasso D2 Boa (USB DAC/amp):
http://www.ibasso.com/en/products/show.asp?ID=30
http://www.head-fi.org/t/552014/pictures-of-your-portable-rig-part-xv/5535#post_8509186
. iBasso D2+ Boa (USB DAC/amp):
http://www.ibasso.com/en/products/show.asp?ID=42
. iBasso D4 (USB DAC/amp):
http://www.head-fi.org/t/450260/ibasso-d4-mamba-with-dual-dacs-hey-hey-the-now-the-d42-and-improved-starting-on-page-76
http://www.head-fi.org/t/450260/ibasso-d4-mamba-with-dual-dacs-hey-hey-the-now-the-d42-and-improved-starting-on-page-76/1125#post_9501894
. iBasso D42 (USB DAC/amp): (Snapdragon-based S3 in USB debugging mode)
http://www.head-fi.org/t/666556/new-ibasso-d42-mamba
http://www.head-fi.org/t/666556/new-ibasso-d42-mamba/15#post_9569386
. iBasso D5 (USB DAC/amp):
http://www.head-fi.org/t/556490/ibasso-d5-hj-yet-another-usb-dac-amp
http://www.head-fi.org/t/614111/finally-digital-out-for-galaxy-siii#post_8462693
. iBasso D6 using USB Audio Recorder PRO (USB DAC/amp):
http://www.ibasso.com/en/products/show.asp?ID=69
http://www.head-fi.org/t/595071/android-phones-and-usb-dacs/1170#post_8980613
. iBasso D10 (USB DAC/amp):
http://www.ibasso.com/en/products/show.asp?ID=39
http://www.head-fi.org/t/628374/samsung-galaxy-s3-to-dac-usb-micro-b-male-to-mini-b-male#post_8735134
. iBasso D12 (USB DAC/amp):
http://www.ibasso.com/en/products/show.asp?ID=63
http://forum.xda-developers.com/showpost.php?p=29069294&postcount=924
. iBasso D12 Hj (USB DAC/amp):
http://www.hibino-intersound.co.jp/ibasso_audio/2511.html
http://www.mobile01.com/topicdetail.php?f=568&t=2770200&p=28#37073736
. iBasso DB2 using USB Audio Recorder PRO:
http://www.ibasso.com/en/products/show.asp?ID=71
http://www.head-fi.org/t/595071/android-phones-and-usb-dacs/1035#post_8959039
. iQube v2 (USB DAC/amp):
http://www.i-qube.nl/index.php?id=24
http://forum.xda-developers.com/showpost.php?s=6fe26080d10769d0f785157c83e74465&p=31207282&postcount=1268
. JH Audio JH-3A (USB DSP/DAC/amp/JH16 CIEM):
http://www.jhaudio.com/product/jh-3a-dsp-amp-jh16-pro-custom-ear-monitor
http://www.head-fi.org/t/595071/android-phones-and-usb-dacs/585#post_8799910
. Jabra GN 5035 (USB headset):
http://reviews.cnet.com/headsets/jabra-gn5035-headset/4505-13831_7-32462996.html
http://forum.xda-developers.com/showpost.php?p=33203364&postcount=1368
. KingRex UD-01:
http://www.kingrex.co.uk/dac.html
https://www.facebook.com/headfonia/posts/352787358128700
. Leckerton UHA-4 (USB DAC/amp):
http://www.leckertonaudio.com/products/uha-4/
http://www.head-fi.org/t/536982/leckerton-audio-slimline-uha-4/1020#post_8773152
. Leckerton UHA-6S MKII (USB DAC/amp):
http://www.leckertonaudio.com/products/uha-6s-mkii/
http://www.head-fi.org/t/602493/new-leckerton-uha-6s-mkii-portable-headphone-amplifier-announced-update-user-impressions-added-july-20th-2012/435#post_8698006
. Logitech wíreless gaming headset G930 (USB wireless headset):
http://www.logitech.com/en-gb/product/7248?crid=721
http://www.head-fi.org/t/595071/android-phones-and-usb-dacs/1215#post_9004830
. M-Audio Duo USB Audio Interface:
http://www.soundonsound.com/sos/oct02/articles/maudio.asp
http://www.head-fi.org/t/595071/android-phones-and-usb-dacs/540#post_8788814
. M2Tech hiFace DAC using USB Audio Recorder PRO:
http://www.audiostream.com/content/m2tech-hiface-dac
http://www.head-fi.org/t/595071/android-phones-and-usb-dacs/2925#post_9724711
. MHDT Paradisea+:
http://www.positive-feedback.com/Issue38/mhdt_paradisea.htm
http://www.head-fi.org/t/595071/android-phones-and-usb-dacs/1785#post_9215172
. Matrix Mini-i (USB DAC/amp):
http://www.headfonia.com/matrix-mini-i-balanced-dac/
http://www.head-fi.org/t/595071/android-phones-and-usb-dacs/465#post_8768166
. Matrix Mini-Portable using USB Audio Recorder PRO (USB DAC/amp):
http://www.headfonia.com/the-320-portable-dacamp-matrix-mini-portable/
http://www.head-fi.org/t/595071/android-phones-and-usb-dacs/2775#post_9666929
. Meier Cantate.2 (USB DAC/amp):
http://www.head-fi.org/products/meier-audio-corda-cantate-2
http://www.head-fi.org/t/595071/android-phones-and-usb-dacs/2535#post_9546540
. Meier PCStep (USB DAC/amp):
http://www.head-fi.org/t/620752/unboxing-meier-audio-corda-quickstep-and-pcstep
http://www.head-fi.org/t/595071/android-phones-and-usb-dacs/1875#post_9255805
. Meridian Explorer using USB Audio Recorder PRO:
http://www.hifiplus.com/articles/world-exclusive-meridian-audio-explorer-usb-dacheadphone-amplifier-hi-fi/
http://www.head-fi.org/t/650680/news-meridian-releases-the-explorer-pocket-sized-usb-dac/525#post_9232628
. Microsoft Philips Digital Sound System 80 (USB DAC/amp/speakers):
http://en.wikipedia.org/wiki/Digital_Sound_System_80
http://forum.xda-developers.com/showthread.php?t=1703218
. Microsoft LifeChat LX-3000 (USB headset):
http://www.microsoft.com/hardware/en-au/p/lifechat-lx-3000/JUG-00003
http://forum.xda-developers.com/showpost.php?p=32899845&postcount=1355
. Muse HiFi USB DAC:
http://www.goodluckbuy.com/muse-hifi-usb-to-s-pdif-converter-usb-dac-pcm2704-sound-card-board.html
http://www.head-fi.org/t/595071/android-phones-and-usb-dacs/2115#post_9351104
. MyST 1866 PortaDAC (USB DAC/amp):
http://www.head-fi.org/t/616889/myst-1866-bluetooth-optical-coaxial-usb-dac-headphone-amp-impressions-thread
http://www.head-fi.org/t/595071/android-phones-and-usb-dacs/795#post_8852573
. Mytek Stereo192-DSD DAC using USB Audio Recorder PRO (USB DAC/amp):
http://www.head-fi.org/t/622248/mytek-stereo-192-dsd-dac-preamp-amplifier-review-appreciation-thread
http://www.head-fi.org/t/595071/android-phones-and-usb-dacs/1920#post_9273723
. Nova tiny-M portable DAC (USB DAC/amp):
http://nova-audio.myshopify.com/collections/dac/products/nova-tiny-m-portable-dac-pc-mac-android
http://www.head-fi.org/t/595071/android-phones-and-usb-dacs/2805#post_9679776
. NuForce Icon DAC (USB DAC/amp):
https://www.nuforce.com/index.php?option=com_k2&view=item&id=666:icon-dac&Itemid=2659#specifications
http://www.engadget.com/2013/07/29/nuforce-icon-dac-and-headphone-amp-arrives-for-android-mac-and/
. NuForce Icon HDP (USB DAC/amp):
http://www.nuforce.com/hp/products/iconhdp/index.php
http://www.head-fi.org/t/608535/wolfson-dac-confirmed-for-galaxy-s3/585#post_8571797
. NuForce Icon Mobile (USB DAC/amp):
http://www.6moons.com/audioreviews/nuforce10/mobile.html
http://www.head-fi.org/t/595071/android-phones-and-usb-dacs/435#post_8759826
. NuForce Icon uDAC-2 (USB DAC/amp):
http://www.digitaltrends.com/headphone-amplifier-reviews/nuforce-icon-udac-2-review/
. Objective DAC (ODAC):
http://epiphany-acoustics.co.uk/our-products/e-dac-24bit-miniature-usb-dac/
http://www.jdslabs.com/item.php?fetchitem=46
http://www.headnhifi.com/index.php/shop/objective/odac
http://www.head-fi.org/t/628374/samsung-galaxy-s3-to-dac-usb-micro-b-male-to-mini-b-male/30#post_8939722
. ODAC+O2 (USB DAC/amp):
http://epiphany-acoustics.co.uk/our-products/ehp-o2d-miniature-desktop-headphone-amplifier-with-usb-dac/
http://www.jdslabs.com/item.php?fetchitem=48
http://www.headnhifi.com/index.php/shop/objective/o2120527192048
http://www.facebook.com/permalink.php?story_fbid=410941392302962&id=164588276945555
. Ordnance .25 (USB DAC/amp):
http://jaben.net/forums/index.php?topic=9984.0
. Practical Devices XM6 (USB DAC/amp):
http://www.head-fi.org/t/510543/new-practical-devices-xm6-amp-dac-the-complete-review
http://www.head-fi.org/t/633511/pictures-of-your-portable-rig-part-xvi/2490#post_9215369
. RSA Intruder (USB DAC/amp):
http://www.raysamuelsaudio.com/products/intruder
http://www.head-fi.org/t/627080/new-balanced-portable-amp-from-rsa-w-dac/30#post_8781567
. RSA Predator (USB DAC/amp):
http://www.raysamuelsaudio.com/products/predator
http://www.head-fi.org/t/595071/android-phones-and-usb-dacs/150#post_8538933
. Sony PHA-1 (USB DAC/amp):
http://www.head-fi.org/t/624676/sony-pha-1-portable-dac-amp
http://www.head-fi.org/t/645086/samsung-galaxy-s3-and-hd598s#post_9033830
. SteelSeries Siberia USB sound card (USB DAC/amp):
http://steelseries.com/products/audio/steelseries-siberia-usb-soundcard
. Stoner Acoustics UD100:
http://stoneracoustics.blogspot.fr/
http://forum.lowyat.net/index.php?showtopic=2452730&st=160&p=54596977&#entry54596977
. Sunrise Ray DA-P1 (USB DAC/amp):
http://www.head-fi.org/t/660291/short-review-sunrise-audio-ray-excellent-portable-dac-amp
http://www.head-fi.org/t/595071/android-phones-and-usb-dacs/1950#post_9282772
. Syba SD-AUD20101:
http://www.sybausa.com/productInfo.php?iid=1191
http://www.head-fi.org/t/595071/android-phones-and-usb-dacs/375#post_8736082
. TCG U-SKIN (USB DAC/amp):
http://www.tcgcn.com/productshow.asp?id=517
http://www.head-fi.org/t/595071/android-phones-and-usb-dacs/1920#post_9274670
. Topping D1 Mark 2 (USB DAC/amp):
http://www.head-fi.org/t/636606/topping-d1-mark-2-review
http://forum.xda-developers.com/showpost.php?p=28673076&postcount=871
. Topping D2 (USB DAC/amp):
http://www.mightybigword.com/tnt/2012/03/topping-d2-dac-review/
http://forum.xda-developers.com/showpost.php?p=32920194&postcount=1357
. Topping TP30 (USB DAC/amp):
http://news.cnet.com/8300-5_3-0.html?keyword=Topping+TP-30
http://www.androidnz.net/2012/05/samsung-galaxy-s-iii-usb-audio.html
. Turtle Beach Audio Advantage Micro II:
http://linkai8424.blogspot.fr/2011/03/turtle-beach-audio-advantage-micro-ii.html
http://www.head-fi.org/t/595071/android-phones-and-usb-dacs/1155#post_8978516
. Unique Melody PP6 using USB Audio Recorder PRO (USB DSP/DAC/amp/CIEM):
http://www.custom-iem.com/um-platform-pure-pp6-p-670.html
http://www.head-fi.org/t/613417/unique-melody-platform-pure-6-pp6-discussion-appreciation-tour-thread/360#post_8965862
. V-Moda Vamp Verza (USB DAC/amp):
http://www.head-fi.org/t/655315/v-moda-vamp-verza-metallo-discussion-feedback-reviews-pics-crowdsourcing-ideas
http://www.head-fi.org/t/595071/android-phones-and-usb-dacs/1875#post_9255450
. VentureCraft Go-Dap X (USB DAC/amp): USB cable provided by VentureCraft
http://venturecraft.jp/gadget_en/gdx.php
http://www.head-fi.org/t/595071/android-phones-and-usb-dacs/315#post_8708233
. xDuoo XP-1 (USB DAC/amp):
http://www.facebook.com/media/set/?set=a.529433853753069.134639.436744613021994&type=1
http://www.head-fi.org/t/642504/xduoo-new-company-making-interesting-portable-dac-and-amp-units/45#post_9176225
. Zero DAC (USB DAC/amp):
http://www.head-fi.org/t/269458/review-zero-24-bit-192khz-dac-headphone-amp-pre-amp
http://www.head-fi.org/t/633201/confirmed-list-of-usb-dacs-for-the-galaxy-s3-international-us-or-note-2#post_9329790
A list of standard USB DAC reportedly interworking with the Android-powered smartphone Samsung Galaxy Note II:
stock Galaxy Note II > digital USB audio out >> USB OTG cable (ID pin grounded) >> standard USB DAC >> amp >> headphones
. ALO audio The Pan Am using USB Audio Recorder PRO (USB DAC/amp):
http://www.head-fi.org/t/595071/android-phones-and-usb-dacs/2715#post_9653008
http://www.head-fi.org/t/651660/audinst-hud-mx2-dac-amp
http://www.head-fi.org/t/632019/apex-glacier-amp-dac-review-and-appreciation-thread/165#post_8924724
. Asus Xonar Essence One using USB Audio Recorder PRO (USB DAC/amp):
http://www.6moons.com/audioreviews/asus/1.html
http://www.head-fi.org/t/542563/asus-essence-one-headphone-amp-dac-cebit-2011/1365#post_9152456
http://www.overclockersclub.com/reviews/asus_xonar_u3/
http://www.head-fi.org/t/595071/android-phones-and-usb-dacs/1200#post_8997468
. Audio-gd NFB-16 (USB DAC/amp):
http://www.audio-gd.com/Pro/Headphoneamp/NFB16/NFB16EN.htm
http://www.head-fi.org/t/625054/samsung-galaxy-note-2/120#post_8943120
. Audio-gd Reference 3 using USB Audio Recorder PRO (S/PDIF converter):
http://www.head-fi.org/t/438947/coming-soon-audio-gd-reference-3-usb-spdif-converter-wonder-box
http://www.head-fi.org/t/595071/android-phones-and-usb-dacs/2610#post_9609350
http://www.head-fi.org/t/617241/audioquest-dragonfly-review-affordable-outstanding-tiny-dac-amp
http://www.head-fi.org/t/595071/android-phones-and-usb-dacs/1035#post_8959237
http://audio-head.com/the-portable-audiophile-dac-centrance-dacport-lx/
http://www.head-fi.org/t/595071/android-phones-and-usb-dacs/1065#post_8968468
. ELE EL-D01:
http://www.cnfeature.com/goods.php?id=1299
http://www.head-fi.org/t/643883/portable-amp-for-galaxy-note-2-and-grado-sr80i-heaphones#post_9012249
http://www.headphiles.org/index.php?t=msg&goto=253249&
http://www.head-fi.org/t/595071/android-phones-and-usb-dacs/3090#post_9799599
http://www.head-fi.org/t/638910/fiio-e07k-andes-review-and-help-thread/540#post_9194741
http://www.head-fi.org/t/595071/android-phones-and-usb-dacs/2940#post_9737590
. Focal XS 2.1 (USB speakers):
http://reviews.cnet.com/speakers-speaker-systems/focal-xs-speakers-with/4505-6467_7-33618064.html
http://www.homecinema-fr.com/forum/multimedia-materiels-tablettes-et-smartphones/samsung-galaxy-note-ii-2-go-16-go-android-4-1-2-t30029275.html#p177362999
. Furutech ADL Stride (USB DAC/amp):
http://www.theaudiobeat.com/equipment/adl_furutech_stride.htm
http://www.head-fi.org/t/622939/the-centrance-hifi-m8-thread/2865#post_9685056
. GoVibe Magnum (USB DAC/amp):
http://www.head-fi.org/t/324577/review-govibe-magnum-usb-dac-amp
http://www.head-fi.org/t/633201/confirmed-list-of-usb-dacs-for-the-galaxy-s3-international-us-or-note-2#post_8809248
. GoVibe Martini-U (USB DAC/amp):
http://jaben-bandung.com/index.php?route=product/product&product_id=196
http://www.head-fi.org/t/595071/android-phones-and-usb-dacs/990#post_8942287
. GoVibe Vulcan (USB DAC/amp):
http://www.head-fi.org/t/386127/go-vibe-vulcan
http://www.head-fi.org/t/595071/android-phones-and-usb-dacs/960#post_8929084
. HRT HeadStreamer Mobile (USB DAC/amp):
http://highresolutiontechnologies.com/headstreamer-mobile
http://www.computeraudiophile.com/f6-dac-digital-analog-conversion/power-galaxy-note-2-while-using-usb-dac-how-please-14029/
http://www.positive-feedback.com/Issue65/microstreamer.htm
http://www.head-fi.org/t/595071/android-phones-and-usb-dacs/1605#post_9123185
http://www.headfonia.com/headamp-pico/
http://www.head-fi.org/t/413230/headamp-pico-upsampling-usb-dac-pre-order-now-at-intro-price
. Headstage Lyrix Pro USB total (USB DAC/amp):
http://www.headphonia.com/Amps/Headstage-Lyrix-Pro-USB-total::10071.html
http://www.head-fi.org/t/595071/android-phones-and-usb-dacs/795#post_8854850
http://www.head-fi.org/t/678027/hifimediy-sabre-android-dac-digital-to-audio-converter-pcm2706-es9023#post_9810220
http://forum.hifimediy.com/showthread.php?89-Sabre-Tiny-USB-DAC-compatibility-with-Android-Devices&s=3cd1626fb11a5d30d51ac735313dd1e4&p=308&viewfull=1#post308
http://www.head-fi.org/t/652535/if-your-usb-dac-does-not-work-with-your-android-phone-try-this#post_9192976
http://www.headfonia.com/fiio-e7-meet-your-rival-the-ibasso-d-zero/
http://www.head-fi.org/t/595071/android-phones-and-usb-dacs/405#post_8750862
http://headfonics.com/2013/07/the-d42-mamba-by-ibasso/
http://www.head-fi.org/t/595071/android-phones-and-usb-dacs/2700#post_9649935
http://www.innerfidelity.com/content/leckerton-uha-6s-mkii-portable-headphone-amplifier
http://www.head-fi.org/t/625054/samsung-galaxy-note-2/30#post_8777791
http://www.head-fi.org/t/667350/m2tech-hiface-dac-32-384-impressions#post_9664424
. Meier Corda 2Move (USB DAC/amp):
http://www.head-fi.org/t/379715/corda-2move-vs-headamp-pico-vs-rsa-predator
http://www.head-fi.org/t/625054/samsung-galaxy-note-2/390#post_9429211
http://www.musicaacoustics.com/wp/amplifiers/myst-1866/
http://player.ru/showthread.php?t=74459&page=34&p=1084707&viewfull=1#post1084707
http://www.head-fi.org/t/595071/android-phones-and-usb-dacs/2880#post_9711087
http://www.head-fi.org/t/666267/diy-otg-micro-usb-b-cable-to-usb-b-tutorial
http://www.head-fi.org/t/595071/android-phones-and-usb-dacs/435#post_8758515
http://www.innerfidelity.com/content/canjam-rmaf-2012-ray-samuels-audio-intruder-balanced-portable-headphone-amp-and-dac
http://www.head-fi.org/t/595071/android-phones-and-usb-dacs/660#post_8819856
http://www.6moons.com/audioreviews/predator/predator_2.html
http://www.head-fi.org/t/625054/samsung-galaxy-note-2/120#post_8960049
. Resonessence Labs Concero using USB Audio Recorder PRO:
http://www.6moons.com/audioreviews/resonessence2/1.html
http://www.touchmyapps.com/2012/10/09/sony-pha-1-idevice-dac-and-headphone-amp-in-review/
http://www.head-fi.org/t/595071/android-phones-and-usb-dacs/465#post_8769593
http://www.head-fi.org/t/626632/tiny-dac-big-sound-impression-of-stoner-acoustics-ud100-vs-odac
http://forum.lowyat.net/index.php?showtopic=2449848&st=220&p=56352256&#entry56352256
http://www.engadget.com/2013/03/13/v-moda-vamp-versa-headphone-amp-dac-metallo-case/
http://www.head-fi.org/t/609906/new-venturecraft-go-dap-x-for-both-idevices-and-pcs
http://www.head-fi.org/t/609906/new-venturecraft-go-dap-x-for-both-idevices-and-pcs/345#post_9174335
http://www.jaben.com.hk/ProductView.asp?ID=776&SortID=358
http://www.head-fi.org/t/642504/xduoo-new-company-making-interesting-portable-dac-and-amp-units/45#post_9176366
. Zoom H4 using USB Audio Recorder PRO (USB recorder):
http://en.wikipedia.org/wiki/Zoom_H4_Handy_Recorder
http://forum.xda-developers.com/showpost.php?p=35472432&postcount=23
A list of standard USB DAC reportedly interworking with the Android-powered smartphone Samsung Galaxy S4:
stock Samsung Galaxy S4 > digital USB audio out >> USB OTG cable (ID pin grounded) >> standard USB DAC >> amp >> headphones
http://www.head-fi.org/t/661448/us-samsung-galaxy-s4/45#post_9582748
. Apex Glacier using USB Audio Recorder PRO (USB DAC/amp):
. Behringer UCA202 using USB Audio Recorder PRO (USB DAC/amp):
http://www.head-fi.org/t/595071/android-phones-and-usb-dacs/2505#post_9521793
http://forum.xda-developers.com/showpost.php?s=100a28915888288d20999f8b415a1730&p=41481429&postcount=32
. CEntrance HiFi-M8 using USB Audio Recorder PRO (USB DAC/amp):
http://headfijourney.blogspot.sg/2013/08/centrance-hifi-m8.html?m=1
http://www.head-fi.org/t/595071/android-phones-and-usb-dacs/2655#post_9632528
. CEntrance HiFi-M8 LX using USB Audio Recorder PRO (USB DAC/amp):
http://www.head-fi.org/t/622939/the-centrance-hifi-m8-thread/3075#post_9744308
. Cypher Labs AlgoRhythm Solo –dB using USB Audio Recorder PRO (USB DAC):
. FiiO E07K using USB Audio Recorder PRO (USB DAC/amp):
http://www.head-fi.org/t/595071/android-phones-and-usb-dacs/2265#post_9431745
http://www.head-fi.org/t/633511/pictures-of-your-portable-rig-part-xvi/6180#post_9720281
. FiiO E17 (USB DAC/amp):
http://forum.xda-developers.com/showpost.php?p=41229169&postcount=12
. GoVibe Mini U-DAC:
http://jaben-bandung.com/index.php?route=product/product&product_id=147
http://forum.xda-developers.com/showpost.php?p=41350105&postcount=24
http://www.6moons.com/audioreviews/headamp2/pico.html
http://www.head-fi.org/t/595071/android-phones-and-usb-dacs/2895#post_9713453
http://www.head-fi.org/t/595071/android-phones-and-usb-dacs/2190#post_9387172
http://www.head-fi.org/t/595071/android-phones-and-usb-dacs/2985#post_9751486
http://www.head-fi.org/t/595071/android-phones-and-usb-dacs/2460#post_9506498
. iBasso D4 (USB DAC/amp): (in USB debugging mode)
http://www.whathifi.com/review/d4-mamba
http://www.head-fi.org/t/655315/v-moda-vamp-verza-metallo-discussion-feedback-reviews-pics-crowdsourcing-ideas/720#post_9586127
. iBasso D10 using USB Audio Recorder PRO (USB DAC/amp):
http://www.head-fi.org/t/667838/samsung-galaxy-s4-compatible-portable-dac-amps/45#post_9705178
http://www.head-fi.org/t/666556/new-ibasso-d42-mamba/30#post_9610761
http://www.head-fi.org/t/595071/android-phones-and-usb-dacs/2280#post_9433340
. Lexicon Omega using USB Audio Recorder PRO (USB recorder):
http://www.soundonsound.com/sos/mar04/articles/lexiconomega.htm
http://forum.xda-developers.com/showpost.php?p=41487706&postcount=33
http://www.tnt-audio.com/sorgenti/m2tech_hiface_dac_e.html
. M2Tech hiFace Two using USB Audio Recorder PRO (S/PDIF converter):
http://www.tnt-audio.com/sorgenti/m2tech_hiface2_e.html
http://forum.tellementnomade.com/viewtopic.php?p=147120#p147120
http://www.head-fi.org/t/595071/android-phones-and-usb-dacs/2520#post_9536124
. Musical Fidelity X-DAC V8:
http://www.stereophile.com/digitalprocessors/208mfx/index.html
http://www.head-fi.org/t/633511/pictures-of-your-portable-rig-part-xvi/6210#post_9725330
. NuForce Icon uDAC-2 using USB Audio Recorder PRO (USB DAC/amp):
http://www.head-fi.org/t/595071/android-phones-and-usb-dacs/2385#post_9481700
http://audio-head.com/the-rsa-intruder-headphone-ampdac-review/
http://www.head-fi.org/t/680208/sonys-dsd-capable-pha-2-portable-headphone-amp-dac/45#post_9782826
http://www.head-fi.org/t/595071/android-phones-and-usb-dacs/2265#post_9424990
. Styleaudio Carat-Peridot2 (USB DAC/amp):
http://styleaudio.jp/2011/peridot2.html
http://bbs1.ruliweb.daum.net/gaia/do/ruliweb/default/mobile/66/read?bbsId=G002&itemId=8&articleId=262591
A list of standard USB DAC reportedly interworking with the Android-powered smartphone Samsung Galaxy Note3:
stock Samsung Galaxy Note3 > digital USB audio out >> USB OTG cable (ID pin grounded) >> standard USB DAC >> amp >> headphones
