NZtechfreak
- Jan 19, 2012
Wow, it was three years ago I started this post on Head-Fi about USB audio on Android...
I thought I would update the first post today to point to the post that contains all of the most up to date resources for this topic, from the fantastic and dedicated DanBa here. EDIT: Updated to DanBa's newest information on 27 Nov 2015.
The information from that post is here, but no doubt will be superceded by updates from DanBa in due course:
Android USB audio
Information search:
1. Click on the following link
https://www.google.fr/?gws_rd=ssl#q=%22XY%22+site:http:%2F%2Fwww.head-fi.org%2Ft%2F595071%2Fandroid-phones-and-usb-dacs
2. Replace XY by your search keyword(s).
FAQ:
http://goo.gl/A4dCnP
A list of USB OTG cables / adapters:
http://goo.gl/4JyOe5
A list of USB Type-C cables / adapters:
https://goo.gl/n1cxPx
A list of stock Android-powered devices reportedly interworking with compatible USB DAC:
stock Android device > digital USB audio out >> USB DAC >> amp >> headphones
http://goo.gl/ksoF0d
A list of USB Audio Player PRO resources (compatible USB DAC, compatible Android devices, ...):
http://www.extreamsd.com/USBAudioRecorderPRO/
A list of standard USB DAC reportedly interworking with the Android-powered smartphone Samsung Galaxy S3 having a microSD card slot:
stock Samsung Galaxy S3 > digital USB audio out >> USB OTG cable (ID pin grounded) >> USB DAC >> amp >>headphones
http://goo.gl/yBKivk
A list of standard USB DAC reportedly interworking with the Android-powered smartphone Samsung Galaxy Note2 having a microSD card slot:
stock Galaxy Note2 > digital USB audio out >> USB OTG cable (ID pin grounded) >> USB DAC >> amp >>headphones
http://goo.gl/Ga1jYw
A list of standard USB DAC reportedly interworking with the Android-powered smartphone Samung Galaxy S4 having a microSD card slot:
stock Samsung Galaxy S4 > digital USB audio out >> USB OTG cable (ID pin grounded) >> USB DAC >> amp >>headphones
http://goo.gl/dIwrqp
A list of standard USB DAC reportedly interworking with the Android-powered smartphone Samsung Galaxy Note3 having a microSD card slot:
stock Samsung Galaxy Note3 > digital USB audio out >> USB OTG cable (ID pin grounded) >> USB DAC >> amp >> headphones
http://goo.gl/7Bvkhz
A list of standard USB DAC reportedly interworking with the Android-powered smartphone Samung Galaxy S5 having a microSD card slot:
stock Samsung Galaxy S5 > digital USB audio out >> USB OTG cable (ID pin grounded) >> USB DAC >> amp >>headphones
http://goo.gl/zUjud0
A list of standard USB DAC reportedly interworking with the Android-powered smartphone Samsung Galaxy Note4 having a microSD card slot:
stock Samsung Galaxy Note4 > digital USB audio out >> USB OTG cable (ID pin grounded) >> USB DAC >> amp >> headphones
http://goo.gl/gnmvuf
USB DAC descriptors:
http://goo.gl/pYJbTu
The basics:
http://goo.gl/MCFY2x
