Android phones and USB DACs
post-9400333
Post #2,221 of 9,413
NZtechfreak
Thank you, I have to take the Glacier to the showroom and have it connected to the S4 and see if it works.
If it doesn't, than HTC one will be the one...
The plot will thicken if it does work with yours!
Not sure why it isn't working, must be something with the Samsung software, since it works fine on my HTC One which has the same Qualcomm SoC.
post-9400389
Post #2,222 of 9,413
SoulSlayaz
Can sum1 confirm if any of the fiios work with the s4 quad core variant (i9095) or recommend one that does but under £70 if possible im soooo depressed the s4 sound is too weak! Esp compared to the htc one?! Thanks
post-9401980
Post #2,223 of 9,413
DanBa
Does anybody know if the Nexus4 work?
Apparently, USB OTG can be enabled on Nexus 4; and such a Nexus 4, operating as USB host, can work with USB peripheral like USB DAC.
http://www.head-fi.org/t/595071/android-phones-and-usb-dacs/2100#post_9340559
You can test such a USB OTG-enabled Nexus 4 without or with the USB Audio Recorder PRO app available on Google Play Store.
post-9402017
Post #2,224 of 9,413
fuzzy1969
post-9402078
Post #2,225 of 9,413
SoulSlayaz
The s4 sound quality is mediocre, i dunno maybe its because of the higher frequency output on the HTC one + beats audio enabled just sounds really good, i used my monster turbines pro on both of them and the turbines just shine on the one where as on my s4 they sound like some shabby disposable headphones you get from the pound land..... so i have given up on using the s4 as my music player unless i can get a good DAC or amp but i have limited knowledge in this area and don't know where to begin?? or i may just buy a mp3 player but again i don't know where to begin. Please can a kind soul help me lol im so depressed...... i need that thick bass and clear audio on loud volume!
P.S. I used the same EQ settings on poweramp for both phones...and i dont know if i wanna trust gsm about the levels but i do know that i have had both ones (and now stuck with s4) and the HTC is a bloody beauty of an audio device!!!)
post-9402087
Post #2,226 of 9,413
NZtechfreak
I'd buy a DAC/amp, rather than a standalone mp3 myself. You can use it with stuff like your laptop and other phones going forward.
post-9402175
Post #2,227 of 9,413
SoulSlayaz
OK may just have to, i hope it will work with s4!
Also would have to buy the cables separately
post-9402195
Post #2,228 of 9,413
NZtechfreak
Which ones work with the S4 will be confirmed over time as more here get their hands on them.
Generally you would have to get the cables separately, some like iBasso are including them.
post-9402372
Post #2,229 of 9,413
TekeRugburn
aka. ThePhoenix84, ThePhoenix84md, SUZAKUreturns
hmmm... anyone still looking for a ud100?
post-9402398
Post #2,230 of 9,413
Coop
post-9402748
Post #2,231 of 9,413
kendelahoussaye
USB OTG cables:
http://forzaaudioworks.com/en/product.php?id_product=55
USB OTG-capable Android device > digital USB audio out >> USB OTG cable >> standard USB DAC
"Copper/Silver Series Android LOD made for connecting your Android device through digital out to external DAC. Features FAW custom made, gold plated Micro-B USB plug with OFC copper pins and USB connector of your choice. Check first if your Android device supports digital line out through USB OTG cable. For best ergonomics and orientation of plugs (if they should be inverted or not), write your setup in comment box at the checkout (Android device and external DAC)."
"All my cables work with Android devices like eg, Galaxy S3, HTC One etc. In all of them ID pin is connected to ground to enable digital line out."
. Functional Micro-A plug, i.e. ID pin connected to ground, having the appearance of a Micro-B plug to Standard-B plug cable
. Functional Micro-A plug having the appearance of a Micro-B plug to Mini-B plug cable
. Functional Micro-A plug having the appearance of a Micro-B plug to Micro-B plug cable
Cables to connect a DAC to an amp:
Cables to connect an amp to headphones / IEM:
USB OTG cables:
So, when you go to buy the Android LOD cables, the option for the first end only allows USB micro-B, but this would only appear to be micro-B but act as micro-A correct? Then the second end  I'd choose would be mini-B to connect to a FiiO E07K.
post-9403033
Post #2,234 of 9,413
DanBa
A list of stock Android-powered devices reportedly interworking with standard USB DAC:
stock Android device > digital USB audio out >> standard USB DAC >> amp >> headphones
. Acer Iconia Tab A200 using USB Audio Recorder PRO (tablet):
http://www.engadget.com/2012/03/15/acer-iconia-tab-a200-review/
http://www.extreamsd.com/USBAudioRecorderPRO/
. Acer Iconia Tab A500 using USB Audio Recorder PRO (tablet):
http://www.engadget.com/2011/04/26/acer-iconia-tab-a500-review/
. Archos G9 (tablet):
http://www.anandtech.com/show/5802/the-archos-g9-tablet-reviews-fast-enough
http://forum.xda-developers.com/showthread.php?t=1539576
. Asus Memo Pad ME172V using USB Audio Recorder PRO (tablet):
http://www.notebookcheck.net/Review-Asus-Memo-Pad-ME172V-Tablet.89548.0.html
. Asus PadFone using USB Audio Recorder PRO:
http://www.engadget.com/2012/06/12/asus-padfone-review/
. Asus PadFone Infinity using USB Audio Recorder PRO:
http://www.engadget.com/2013/02/25/asus-padfone-infinity-announced/
http://www.head-fi.org/t/595071/android-phones-and-usb-dacs/2175#post_9375965
. Asus Slider using USB Audio Recorder PRO (tablet):
http://www.phonearena.com/reviews/Asus-Eee-Pad-Slider-Review_id2957
http://www.head-fi.org/t/595071/android-phones-and-usb-dacs/1785#post_9220476
. Asus TF101 using USB Audio Recorder PRO (tablet):
http://www.engadget.com/2011/04/18/asus-eee-pad-transformer-uk-edition-review/
. Asus TF201 using USB Audio Recorder PRO (tablet):
http://www.tomshardware.com/reviews/transformer-prime-tf201-tablet-review,3175.html
. Asus TF300 using USB Audio Recorder PRO (tablet):
http://www.engadget.com/2012/04/22/asus-transformer-pad-tf300-review/
. Asus TF700 using USB Audio Recorder PRO (tablet):
http://www.engadget.com/2012/06/25/asus-transformer-pad-infinity-tf700-review/
. Asus Transformer Prime using USB Audio Recorder PRO (tablet):
http://www.engadget.com/2011/12/01/asus-eee-pad-transformer-prime-review/
. Google Galaxy Nexus using USB Audio Recorder PRO (smartphone):
http://www.theverge.com/products/galaxy-nexus-gsm/2946
http://forum.xda-developers.com/showpost.php?p=35484769&postcount=52
. Google Nexus 7 using USB Audio Recorder PRO (tablet):
http://www.engadget.com/2012/06/28/nexus-7-review/
. Google Nexus 10 using USB Audio Recorder PRO (tablet):
http://www.engadget.com/2012/11/02/nexus-10-review/
http://www.head-fi.org/t/595071/android-phones-and-usb-dacs/1110#post_8973836
. HTC Butterfly / HTC Droid DNA / HTC J Butterfly (smartphone):
http://www.htc.com/www/smartphones/htc-butterfly/
http://www.head-fi.org/t/595071/android-phones-and-usb-dacs/1425#post_9082851
. HTC One (smartphone):
http://www.engadget.com/2013/02/19/htc-one-hands-on-design-and-hardware/
http://forum.xda-developers.com/showthread.php?t=2210536
. HTC One X (smartphone):
http://www.engadget.com/2012/04/02/htc-one-x-review/
http://forum.lowyat.net/index.php?showtopic=2222840&st=60&p=57944246&#entry57944246
. HTC One XL using USB Audio Recorder PRO (tablet):
http://www.techradar.com/reviews/phones/mobile-phones/htc-one-xl-1120377/review
http://www.head-fi.org/t/595071/android-phones-and-usb-dacs/1830#post_9237213
. Huawei Ascend D1 Quad XL using USB Audio Recorder PRO (smartphone):
http://www.engadget.com/2012/10/20/huawei-ascend-d1-quad-xl-review/
http://www.head-fi.org/t/628254/fiio-e18/15#post_8988466
. Huawei MediaPad using USB Audio Recorder PRO (tablet):
http://www.androidnz.net/2012/09/rapid-review-huawei-mediapadt-mobile.html
. iMito MX1 (mini PC):
http://www.squidoo.com/imito-mx1-android-mini-pc-bluetooth
http://www.armtvtech.com/armtvtechforum/viewtopic.php?f=81&t=669&start=10
. MK808 / MK808B (mini PC):
http://www.squidoo.com/mk808-dual-core-android-mini-pc-review
http://tabletrepublic.com/forum/android-mini-pc/uhost2-mk808-supports-audio-usb-dongle-3092.html
. Meizu MX Quad-Core using USB Audio Recorder PRO (smartphone): to be confirmed
http://www.xda-developers.com/android/meizu-mx-quad-core-review/
http://www.head-fi.org/t/642504/xduoo-new-company-making-interesting-portable-dac-and-amp-units#post_9027380
http://www.head-fi.org/t/595071/android-phones-and-usb-dacs/2235#post_9415543
. Minix Neo G4 (mini PC):
http://www.squidoo.com/minix-neo-g4-review
http://www.facebook.com/minixtech/posts/466648763397297
. Minix Neo X5 (mini PC):
http://tabletrepublic.com/forum/android-mini-pc/minix-neo-x5-google-tv-box-16gb-android-4-1-bluetooth-review-3241.html
http://forum.audiogon.com/cgi-bin/fr.pl?ddgtl&1358382120&openflup&5&4
. Motorola Razr Maxx HD using USB Audio Recorder PRO (smartphone):
http://www.engadget.com/2012/10/19/droid-razr-hd-and-razr-maxx-hd-review/
. Motorola Xoom using USB Audio Recorder PRO (tablet):
http://www.engadget.com/2011/02/23/motorola-xoom-review/
. Samsung Galaxy Camera (camera):
http://www.digitaltrends.com/digital-camera-reviews/samsung-galaxy-camera-ek-gc100-review/
http://www.sogi.com.tw/android/article_list.aspx?OsId=1&topic_ID=6205384
. Samsung Galaxy Note II (smartphone):
http://www.engadget.com/2012/10/08/samsung-galaxy-note-ii-review/
. Samsung Galaxy Note 10.1 (tablet):
http://phandroid.com/samsung-galaxy-note-10-1/
http://www.head-fi.org/t/595071/android-phones-and-usb-dacs/645#post_8814831
. Samsung Galaxy R using USB Audio Recorder PRO (smartphone):
http://www.engadget.com/2011/08/10/samsung-galaxy-r-officially-announced-for-europe-and-asia-nobod/
. Samsung Galaxy S3 (smartphone):
http://www.theverge.com/2012/5/25/3042640/samsung-galaxy-s-iii-review
. Samsung Galaxy S4 (smartphone):
http://www.engadget.com/2013/04/24/samsung-galaxy-s-4-review/
http://forum.xda-developers.com/showthread.php?t=2252618
. Samsung Galaxy Tab 2 7.0 using USB Audio Recorder PRO (tablet):
http://www.engadget.com/2012/04/11/samsung-galaxy-tab-2-7-0-review/
. Samsung Galaxy Tab 7.7 using USB Audio Recorder PRO (tablet):
http://www.engadget.com/2012/02/07/samsung-galaxy-tab-7-7-review-international-edition/
. Samsung Galaxy Tab 10.1 using USB Audio Recorder PRO (tablet):
http://www.engadget.com/2012/05/15/samsung-galaxy-tab-2-10-1-review/
. Sony Tablet S / S1 using USB Audio Recorder PRO (tablet):
http://en.wikipedia.org/wiki/Sony_Tablet_S1
http://www.head-fi.org/t/595071/android-phones-and-usb-dacs/1725#post_9176002
. Sony Xperia Acro S using USB Audio Recorder PRO (smartphone):
http://forum.xda-developers.com/forumdisplay.php?f=1945
. Sony Xperia P using USB Audio Recorder PRO (smartphone):
http://www.engadget.com/2012/06/03/sony-xperia-p-review/
http://www.head-fi.org/t/595071/android-phones-and-usb-dacs/1635#post_9131701
. Sony Xperia S using USB Audio Recorder PRO (smartphone):
http://www.engadget.com/2012/03/08/sony-xperia-s-review/
. Sony Xperia Sola using USB Audio Recorder PRO (smartphone):
http://www.androidcentral.com/device/sony-xperia-sola
. Sony Xperia V (smartphone):
http://www.gsmarena.com/sony_xperia_v-review-877.php
http://www.head-fi.org/t/595071/android-phones-and-usb-dacs/1800#post_9225211
. Sony Xperia Z (smartphone):
http://www.engadget.com/2013/02/20/sony-xperia-z-review/
http://forum.xda-developers.com/showthread.php?t=2177991
. Sony Xperia ZL (smartphone):
http://www.engadget.com/2013/04/10/sony-xperia-zl-review/
http://forums.overclockers.com.au/showpost.php?s=00bf76e604f9f640c25e08fabf0ed42e&p=15240770&postcount=174
. Toshiba AT300 using USB Audio Recorder PRO (tablet):
http://www.digitalversus.com/tablet/toshiba-at300-p14161/test.html
http://www.droidforums.net/forum/new-member-introductions-site-assistance/238370-new-member-old-question-usb-dac-issue.html#post2388967
. Toshiba Thrive using USB Audio Recorder PRO (tablet):
http://www.engadget.com/2011/07/22/toshiba-thrive-review/
. Wiko Cink King using USB Audio Recorder PRO (smartphone):
http://www.wikomobile.com/telephone-portable-Cink-king.php
The USB Audio Recorder PRO player is basic for the time being, but it can transmit 24/192:
http://www.head-fi.org/t/595071/android-phones-and-usb-dacs/1635#post_9133811
http://www.head-fi.org/t/595071/android-phones-and-usb-dacs/1305#post_9034501
http://neutronmp.com/forum/viewtopic.php?f=4&t=314&sid=9f141f74398200e620f59f94599266d3&start=70#p4097
A list of standard USB DAC reportedly interworking with the Android-powered smartphone Samsung Galaxy Note II:
stock Galaxy Note II > digital USB audio out >> USB OTG cable (micro-A plug inserted into the Note II) >> standard USB DAC >> amp >> headphones
. Audinst HUD-mx2 (USB DAC/amp):
http://www.head-fi.org/t/651660/audinst-hud-mx2-dac-amp
http://www.head-fi.org/t/595071/android-phones-and-usb-dacs/1890#post_9264638
. Apex Glacier (USB DAC/amp):
http://www.head-fi.org/t/632019/apex-glacier-amp-dac-review-and-appreciation-thread
http://www.head-fi.org/t/632019/apex-glacier-amp-dac-review-and-appreciation-thread/165#post_8924724
. Asus Xonar Essence One using USB Audio Recorder PRO (USB DAC/amp):
http://www.6moons.com/audioreviews/asus/1.html
http://www.head-fi.org/t/542563/asus-essence-one-headphone-amp-dac-cebit-2011/1365#post_9152456
. Asus Xonar U3 (USB DAC/amp):
http://www.overclockersclub.com/reviews/asus_xonar_u3/
http://www.head-fi.org/t/595071/android-phones-and-usb-dacs/1200#post_8997468
. Audio-gd NFB-16 (USB DAC/amp):
http://www.audio-gd.com/Pro/Headphoneamp/NFB16/NFB16EN.htm
http://www.head-fi.org/t/625054/samsung-galaxy-note-2/120#post_8943120
. AudioQuest DragonFly using USB Audio Recorder PRO:
http://www.head-fi.org/t/617241/audioquest-dragonfly-review-affordable-outstanding-tiny-dac-amp
http://www.head-fi.org/t/595071/android-phones-and-usb-dacs/1035#post_8959237
. CEntrance DACport LX using USB Audio Recorder PRO:
http://audio-head.com/the-portable-audiophile-dac-centrance-dacport-lx/
http://www.head-fi.org/t/595071/android-phones-and-usb-dacs/1065#post_8968468
. ELE EL-D01:
http://www.cnfeature.com/goods.php?id=1299
http://www.head-fi.org/t/643883/portable-amp-for-galaxy-note-2-and-grado-sr80i-heaphones#post_9012249
. FiiO E07K Andes (USB DAC/amp): to be confirmed
http://www.headphiles.org/index.php?t=msg&goto=253249&
http://www.head-fi.org/t/638910/new-fiio-e07k-andes-information-and-impressions/15#post_8924515
http://www.head-fi.org/t/628254/fiio-e18/15#post_8973799
. FiiO E10 using USB Audio Recorder PRO (USB DAC/amp):
http://www.headfonia.com/the-latest-must-have-the-fiio-e10-usb-dacamp/
http://www.head-fi.org/t/638910/fiio-e07k-andes-review-and-help-thread/540#post_9194741
. Focal XS 2.1 (USB speakers):
http://reviews.cnet.com/speakers-speaker-systems/focal-xs-speakers-with/4505-6467_7-33618064.html
http://www.homecinema-fr.com/forum/multimedia-materiels-tablettes-et-smartphones/samsung-galaxy-note-ii-2-go-16-go-android-4-1-2-t30029275.html#p177362999
. Furutech ADL Stride (USB DAC/amp):
http://www.theaudiobeat.com/equipment/adl_furutech_stride.htm
http://www.head-fi.org/t/631713/playstation-vita-audio-headphone-compatibility-amps-etc#post_8778115
. GoVibe Magnum (USB DAC/amp):
http://www.head-fi.org/t/324577/review-govibe-magnum-usb-dac-amp
http://www.head-fi.org/t/633201/confirmed-list-of-usb-dacs-for-the-galaxy-s3-international-us-or-note-2#post_8809248
. GoVibe Martini-U (USB DAC/amp):
http://jaben-bandung.com/index.php?route=product/product&product_id=196
http://www.head-fi.org/t/595071/android-phones-and-usb-dacs/990#post_8942287
. GoVibe Vulcan (USB DAC/amp):
http://www.head-fi.org/t/386127/go-vibe-vulcan
http://www.head-fi.org/t/595071/android-phones-and-usb-dacs/960#post_8929084
. HRT HeadStreamer Mobile (USB DAC/amp):
http://highresolutiontechnologies.com/headstreamer-mobile
http://www.computeraudiophile.com/f6-dac-digital-analog-conversion/power-galaxy-note-2-while-using-usb-dac-how-please-14029/
. HRT microStreamer (USB DAC/amp):
http://www.positive-feedback.com/Issue65/microstreamer.htm
http://www.head-fi.org/t/595071/android-phones-and-usb-dacs/1605#post_9123185
. HeadAmp Pico USB DAC/Amp: bug fixed by HeadAmp
http://www.headfonia.com/headamp-pico/
http://www.head-fi.org/t/595071/android-phones-and-usb-dacs/1305#post_9037872
. HeadAmp Pico Upsampling USB DAC:
http://www.head-fi.org/t/413230/headamp-pico-upsampling-usb-dac-pre-order-now-at-intro-price
. Headstage Lyrix Pro USB total (USB DAC/amp):
http://www.headphonia.com/Amps/Headstage-Lyrix-Pro-USB-total::10071.html
http://www.head-fi.org/t/595071/android-phones-and-usb-dacs/795#post_8854850
. HiFimeDIY Sabre USB DAC using USB Audio Recorder PRO:
http://hifimediy.com/index.php?route=product/product&product_id=83
http://www.head-fi.org/t/652535/if-your-usb-dac-does-not-work-with-your-android-phone-try-this#post_9192976
. iBasso D-Zero (USB DAC/amp):
http://www.headfonia.com/fiio-e7-meet-your-rival-the-ibasso-d-zero/
. iBasso D12 (USB DAC/amp):
http://www.ibasso.com/en/products/show.asp?ID=63
http://www.head-fi.org/t/595071/android-phones-and-usb-dacs/405#post_8750862
. Leckerton UHA-6S MKII (USB DAC/amp):
http://www.innerfidelity.com/content/leckerton-uha-6s-mkii-portable-headphone-amplifier
http://www.head-fi.org/t/625054/samsung-galaxy-note-2/30#post_8777791
. MyST 1866 PortaDAC (USB DAC/amp):
http://www.musicaacoustics.com/wp/amplifiers/myst-1866/
http://player.ru/showthread.php?t=74459&page=34&p=1084707&viewfull=1#post1084707
. Objective DAC (ODAC):
http://epiphany-acoustics.co.uk/our-products/e-dac-24bit-miniature-usb-dac/
http://www.jdslabs.com/item.php?fetchitem=46
http://www.headnhifi.com/index.php/shop/objective/odac
http://www.head-fi.org/t/595071/android-phones-and-usb-dacs/435#post_8758515
. ODAC+O2 (USB DAC/amp):
http://epiphany-acoustics.co.uk/our-products/ehp-o2d-miniature-desktop-headphone-amplifier-with-usb-dac/
http://www.jdslabs.com/item.php?fetchitem=48
http://www.headnhifi.com/index.php/shop/objective/o2120527192048
. RSA Intruder (USB DAC/amp):
http://www.innerfidelity.com/content/canjam-rmaf-2012-ray-samuels-audio-intruder-balanced-portable-headphone-amp-and-dac
http://www.head-fi.org/t/595071/android-phones-and-usb-dacs/660#post_8819856
. RSA Predator (USB DAC/amp):
http://www.6moons.com/audioreviews/predator/predator_2.html
http://www.head-fi.org/t/625054/samsung-galaxy-note-2/120#post_8960049
. Sony PHA-1 (USB DAC/amp):
http://www.touchmyapps.com/2012/10/09/sony-pha-1-idevice-dac-and-headphone-amp-in-review/
http://www.head-fi.org/t/595071/android-phones-and-usb-dacs/465#post_8769593
. Stoner Acoustics UD100:
http://www.head-fi.org/t/626632/tiny-dac-big-sound-impression-of-stoner-acoustics-ud100-vs-odac
http://forum.lowyat.net/index.php?showtopic=2449848&st=220&p=56352256&#entry56352256
. V-Moda Vamp Verza (USB DAC/amp):
http://www.engadget.com/2013/03/13/v-moda-vamp-versa-headphone-amp-dac-metallo-case/
http://www.head-fi.org/t/655315/v-moda-vamp-verza-metallo-discussion-feedback-reviews-pics-crowdsourcing-ideas
. VentureCraft Go-Dap X (USB DAC/amp): USB cable provided by VentureCraft
http://www.head-fi.org/t/609906/new-venturecraft-go-dap-x-for-both-idevices-and-pcs
http://www.head-fi.org/t/609906/new-venturecraft-go-dap-x-for-both-idevices-and-pcs/345#post_9174335
. xDuoo XP-1 (USB DAC/amp):
http://www.jaben.com.hk/ProductView.asp?ID=776&SortID=358
http://www.head-fi.org/t/642504/xduoo-new-company-making-interesting-portable-dac-and-amp-units/45#post_9176366
. Zoom H4 using USB Audio Recorder PRO (USB recorder):
http://en.wikipedia.org/wiki/Zoom_H4_Handy_Recorder
http://forum.xda-developers.com/showpost.php?p=35472432&postcount=23
So far, like the quad-core Exynos powered Galaxy S III, the new quad-core Exynos powered Samsung Galaxy Note II can work with the FiiO E7, the iBasso D12, Leckerton UHA-6S MKII, the ODAC, … ; had some issue with the HeadAmp Pico (bug fixed by HeadAmp); and doesn’t work with the FiiO E17 using the stock USB audio driver.
So, in regard to the USB protocol, the behaviour of the Galaxy Note II is likely identical to the behaviour of the Galaxy S III.
A list of standard USB DAC reportedly interworking with the Android-powered smartphone Samsung Galaxy S III:
stock Samsung Galaxy S III > digital USB audio out >> USB OTG cable (micro-A plug inserted into the S III) >> standard USB DAC >> amp >> headphones
. ALO audio The International using USB Audio Recorder PRO (USB DAC/amp):
http://audio-head.com/the-international-headphone-ampdac-by-alo-audio/#more-1002
http://www.head-fi.org/t/595071/android-phones-and-usb-dacs/1590#post_9117178
. AMB Gamma 1:
http://www.amb.org/audio/gamma1/
http://www.head-fi.org/t/608535/wolfson-dac-confirmed-for-galaxy-s3/780#post_8750043
. AMB Gamma 2:
http://www.amb.org/audio/gamma2/
http://forum.xda-developers.com/showpost.php?p=27247705&postcount=279
http://www.ttvjaudio.com/Apex_High_Fi_Audio_Glacier_portable_headphone_amp_p/aaa0000010.htm
http://www.head-fi.org/t/608535/wolfson-dac-confirmed-for-galaxy-s3/825#post_8776449
http://www.asus.com/Multimedia/Audio_Cards/Xonar_U3/
http://mybroadband.co.za/vb/showthread.php/429589-Samsung-Galaxy-S3?s=1a313fae4795a9a7493a6ce0f677ca8e&p=8551119&viewfull=1#post8551119
. Atoll DAC 100:
http://www.6moons.com/audioreviews/atoll2/atoll.html
http://forum.xda-developers.com/showpost.php?p=35266076&postcount=17
http://earmass.com/2013/03/24/audinst-hud-mx2-versatile-dacamp-combo/
. Audio-gd Sparrow Version A (USB DAC/amp):
http://www.audio-gd.com/Pro/Headphoneamp/Sparrow/SparrowEN.htm
http://www.head-fi.org/t/595071/android-phones-and-usb-dacs/915#post_8907415
. AudioQuest DragonFly using USB Audio Recorder PRO: amp required
http://www.stereophile.com/content/audioquest-dragonfly-usb-da-converter
http://www.head-fi.org/t/595071/android-phones-and-usb-dacs/1680#post_9151794
. Behringer UCA202 (USB DAC/amp):
http://www.behringer.com/EN/Products/UCA202.aspx
http://www.head-fi.org/t/595071/android-phones-and-usb-dacs/240#post_8654226
. Behringer UCA222 (USB DAC/amp):
http://www.behringer.com/en/Products/UCA222.aspx
http://www.computeraudiophile.com/f6-dac-digital-analog-conversion/usb-audio-enabled-android-powered-samsung-galaxy-s-iii-12338/#post171651
. Beresford Caiman:
http://www.techradar.com/reviews/audio-visual/hi-fi-and-audio/hi-fi-accessories/beresford-caiman-673787/review
. C-Media CM119 chipset-based sound card Dynamode 7 channel USB 2.0 (USB DAC/amp):
http://alatest.com/reviews/audio-accessories/dynamode-7-channel-usb-2-0-sound-card/po3-149540433,95/
http://forum.xda-developers.com/showpost.php?p=27604946&postcount=449
. C-Media CM6911 chipset-based sound card 3D Sound (USB DAC/amp):
http://www.ebay.co.uk/itm/USB-External-3D-5-1-Channel-Audio-PC-Sound-Card-Adapter-/310227918523?pt=UK_Computing_ComputerComponents_SoundCards&hash=item483b065ebb&clk_rvr_id=448505625943&afsrc=1
http://www.droidforums.net/forum/android-forum/197454-enable-usb-audio-any-android-4-0-device-7.html#post2378579
. Cakewalk Sonar SPS 25:
https://www.cakewalk.com/support/kb/reader.aspx/2007013101
. Cambridge Audio DacMagic:
http://www.headfonia.com/cambridge-dacmagic-review/
http://www.head-fi.org/t/631855/galaxy-s3-and-ca-dacmagic-plus#post_8899779
. Cambridge Audio DacMagic Plus using USB Audio Recorder PRO (USB DAC/amp):
http://www.whathifi.com/review/cambridge-audio-dacmagic-plus
http://www.head-fi.org/t/595071/android-phones-and-usb-dacs/1980#post_9304294
. CEntrance DACmini using USB Audio Recorder PRO (USB DAC/amp):
http://centrance.com/products/dacmini/
http://www.head-fi.org/t/595071/android-phones-and-usb-dacs/1200#post_8998731
. CEntrance DACport using USB Audio Recorder PRO (USB DAC/amp):
http://www.avguide.com/review/centrance-dacport-2496-usb-dacheadphone-amplifier-playback-34
http://www.facebook.com/photo.php?fbid=635892416426250&set=a.634656613216497.1073741826.110473262301504&type=1&theater
http://www.headfonia.com/cheaper-better-the-centrance-dacport-lx/
http://www.head-fi.org/t/595071/android-phones-and-usb-dacs/1755#post_9188208
. Citypulse DA2.03e (USB DAC/amp):
http://www.citypulse-audio.com/2,03e.htm
http://www.head-fi.org/t/595071/android-phones-and-usb-dacs/1710#post_9162300
. Corsair HS1 Gaming headset (USB DAC/amp/headphones):
http://www.anandtech.com/show/3989/corsair-hs1-gaming-headset
http://forum.xda-developers.com/showthread.php?p=27238117#post27238117
. Creative Xmod:
http://reviews.cnet.com/external-audio-adapters/creative-xmod/4505-9335_7-32105686.html
http://www.forum-audiophile.fr/musique-demat/fonction-usb-audio-a-activer-dans-android-t24441-60.html#p336853
. Dared MP 5 or ALO JV5 (USB DAC/amp):
http://www.positive-feedback.com/Issue24/dared_mp5.htm
http://www.head-fi.org/t/595071/android-phones-and-usb-dacs/990#post_8948190
. ELE EL-D01:
http://www.head-fi.org/t/586909/the-discovery-thread-new-dannybs-first-take-ath-ckn50-pg383-ele-hi-fi-usb-18-dac-pg-328/4905#post_8886336
http://www.head-fi.org/t/642554/fiio-e7-galaxy-s3-questions-for-car-audio/15#post_8991125
. FiiO E7 (USB DAC/amp):
http://www.headfonia.com/fiio-e7-portable-dac/
http://www.androidnz.net/2012/07/galaxy-s-iii-real-user-review-part-2.html
http://headfonics.com/2012/12/fiio-e07k-the-andes/
http://www.head-fi.org/t/595071/android-phones-and-usb-dacs/2010#post_9319171
. FiiO E17 using USB Audio Recorder PRO (USB DAC/amp):
http://www.headfonia.com/the-upgrade-fiio-e17-alpen/
http://www.head-fi.org/t/595071/android-phones-and-usb-dacs/1020#post_8958018
. Furutech ADL Cruise (USB DAC/amp):
http://www.furutech.com/a2008/product2.asp?prodNo=399
http://www.head-fi.org/t/608535/wolfson-dac-confirmed-for-galaxy-s3/585#post_8567838
. GoVibe DAC:
http://jaben.net/forums/index.php?topic=2824.0
http://forum.lowyat.net/index.php?showtopic=2440879&st=500&p=53317360&#entry53317360
. GoVibe Mini USB DAC:
http://www.head-fi.org/t/566934/introducing-the-govibe-mini-usb-dac
http://www.head-fi.org/t/614111/finally-digital-out-for-galaxy-siii/15#post_8525675
. GoVibe Petite (USB DAC/amp):
http://www.head-fi.org/t/290711/govibe-petite-dac-amp-appreciation-thread-pics-little-update
http://www.head-fi.org/t/595071/android-phones-and-usb-dacs-how-to-increase-the-issues-priority-with-google/195#post_8552452
. Graham Slee Bitzie (USB DAC/amp):
http://www.gspaudio.co.uk/bitzie-usb-dac-external-soundcard.htm
http://www.head-fi.org/t/595071/android-phones-and-usb-dacs/1725#post_9165957
. HRT HeadStreamer (USB DAC/amp):
http://www.headfonia.com/hrt-headstreamer-review/
http://www.head-fi.org/t/608535/wolfson-dac-confirmed-for-galaxy-s3/750#post_8677483
http://tweekgeek.blogspot.fr/2013/01/hrt-microstreamer-review.html
http://www.head-fi.org/t/595071/android-phones-and-usb-dacs/1635#post_9132299
. HRT Music Streamer II:
http://highresolutiontechnologies.com/music-streamer-ii
http://www.head-fi.org/t/608535/wolfson-dac-confirmed-for-galaxy-s3/465#post_8534856
http://www.head-fi.org/t/258967/headamp-pico-portable-amp-w-optional-upsampling-24-96-usb-dac-pre-order-thread
http://www.head-fi.org/t/632019/apex-glacier-amp-dac-review-and-appreciation-thread/270#post_9036297
http://www.headamp.com/pico/pico_usb_dac/index.htm
. HeadRoom Total BitHead (USB DAC/amp):
http://www.headphone.com/learning-center/bithead-faq.php
http://www.head-fi.org/t/595071/android-phones-and-usb-dacs-how-to-increase-the-issues-priority-with-google/135#post_8527516
. HeadStage USB DAC cable:
http://www.inearmatters.net/2010/04/short-review-headstage-usb-dac-cable.html
http://www.headphiles.org/index.php/topic,4452.msg241979.html#msg241979
. HiFiMan Express HM-101:
http://www.head-fi.org/t/571330/hifiman-express-brand-and-hm-101-portable-usb-dac
http://forum.xda-developers.com/showpost.php?p=27284184&postcount=291
http://forum.xda-developers.com/showpost.php?p=36704343&postcount=75
. Hippo CriCri+ using USB Audio Recorder PRO (USB DAC/amp):
http://www.head-fi.org/t/626412/review-hippo-cricri-what-more-could-you-ask-from-this
http://forum.lowyat.net/index.php?showtopic=2222840&st=60&p=57358183&#entry57358183
http://www.ibasso.com/en/products/show.asp?ID=73
http://www.head-fi.org/t/571116/review-ibasso-d-zero-with-fiio-e7-comparison/30#post_8933882
. iBasso D2 Boa (USB DAC/amp):
http://www.ibasso.com/en/products/show.asp?ID=30
http://www.head-fi.org/t/552014/pictures-of-your-portable-rig-part-xv/5535#post_8509186
. iBasso D2+ Boa (USB DAC/amp):
http://www.ibasso.com/en/products/show.asp?ID=42
. iBasso D5 (USB DAC/amp):
http://www.head-fi.org/t/556490/ibasso-d5-hj-yet-another-usb-dac-amp
http://www.head-fi.org/t/614111/finally-digital-out-for-galaxy-siii#post_8462693
. iBasso D6 using USB Audio Recorder PRO (USB DAC/amp):
http://www.ibasso.com/en/products/show.asp?ID=69
http://www.head-fi.org/t/595071/android-phones-and-usb-dacs/1170#post_8980613
. iBasso D10 (USB DAC/amp):
http://www.ibasso.com/en/products/show.asp?ID=39
http://www.head-fi.org/t/628374/samsung-galaxy-s3-to-dac-usb-micro-b-male-to-mini-b-male#post_8735134
http://forum.xda-developers.com/showpost.php?p=29069294&postcount=924
. iBasso DB2 using USB Audio Recorder PRO:
http://www.ibasso.com/en/products/show.asp?ID=71
http://www.head-fi.org/t/595071/android-phones-and-usb-dacs/1035#post_8959039
. iQube v2 (USB DAC/amp):
http://www.i-qube.nl/index.php?id=24
http://forum.xda-developers.com/showpost.php?s=6fe26080d10769d0f785157c83e74465&p=31207282&postcount=1268
. JH Audio JH-3A (USB DSP/DAC/amp/JH16 CIEM):
http://www.jhaudio.com/product/jh-3a-dsp-amp-jh16-pro-custom-ear-monitor
http://www.head-fi.org/t/595071/android-phones-and-usb-dacs/585#post_8799910
. Jabra GN 5035 (USB headset):
http://reviews.cnet.com/headsets/jabra-gn5035-headset/4505-13831_7-32462996.html
http://forum.xda-developers.com/showpost.php?p=33203364&postcount=1368
. KingRex UD-01:
http://www.kingrex.co.uk/dac.html
https://www.facebook.com/headfonia/posts/352787358128700
. Leckerton UHA-4 (USB DAC/amp):
http://www.leckertonaudio.com/products/uha-4/
http://www.head-fi.org/t/536982/leckerton-audio-slimline-uha-4/1020#post_8773152
http://www.leckertonaudio.com/products/uha-6s-mkii/
http://www.head-fi.org/t/602493/new-leckerton-uha-6s-mkii-portable-headphone-amplifier-announced-update-user-impressions-added-july-20th-2012/435#post_8698006
. Logitech wíreless gaming headset G930 (USB wireless headset):
http://www.logitech.com/en-gb/product/7248?crid=721
http://www.head-fi.org/t/595071/android-phones-and-usb-dacs/1215#post_9004830
. M-Audio Duo USB Audio Interface:
http://www.soundonsound.com/sos/oct02/articles/maudio.asp
http://www.head-fi.org/t/595071/android-phones-and-usb-dacs/540#post_8788814
. MHDT Paradisea+:
http://www.positive-feedback.com/Issue38/mhdt_paradisea.htm
http://www.head-fi.org/t/595071/android-phones-and-usb-dacs/1785#post_9215172
. Matrix Mini-i (USB DAC/amp):
http://www.headfonia.com/matrix-mini-i-balanced-dac/
http://www.head-fi.org/t/595071/android-phones-and-usb-dacs/465#post_8768166
. Meier Audio Cantate.2 (USB DAC/amp):
http://www.head-fi.org/products/meier-audio-corda-cantate-2
http://www.head-fi.org/t/595071/android-phones-and-usb-dacs/660#post_8820899
. Meier Audio PCStep (USB DAC/amp):
http://www.head-fi.org/t/620752/unboxing-meier-audio-corda-quickstep-and-pcstep
http://www.head-fi.org/t/595071/android-phones-and-usb-dacs/1875#post_9255805
. Meridian Explorer using USB Audio Recorder PRO: amp required
http://www.hifiplus.com/articles/world-exclusive-meridian-audio-explorer-usb-dacheadphone-amplifier-hi-fi/
http://www.head-fi.org/t/650680/news-meridian-releases-the-explorer-pocket-sized-usb-dac/525#post_9232628
. Microsoft Philips Digital Sound System 80 (USB DAC/amp/speakers):
http://en.wikipedia.org/wiki/Digital_Sound_System_80
http://forum.xda-developers.com/showthread.php?t=1703218
[size=10pt]. Microsoft LifeChat LX-3000 (USB headset):[/size]
http://www.microsoft.com/hardware/en-au/p/lifechat-lx-3000/JUG-00003
http://forum.xda-developers.com/showpost.php?p=32899845&postcount=1355
. Muse HiFi USB DAC:
http://www.goodluckbuy.com/muse-hifi-usb-to-s-pdif-converter-usb-dac-pcm2704-sound-card-board.html
http://www.head-fi.org/t/595071/android-phones-and-usb-dacs/2115#post_9351104
http://www.head-fi.org/t/616889/myst-1866-bluetooth-optical-coaxial-usb-dac-headphone-amp-impressions-thread
http://www.head-fi.org/t/595071/android-phones-and-usb-dacs/795#post_8852573
. Mytek Stereo192-DSD DAC using USB Audio Recorder PRO (USB DAC/amp):
http://www.head-fi.org/t/622248/mytek-stereo-192-dsd-dac-preamp-amplifier-review-appreciation-thread
http://www.head-fi.org/t/595071/android-phones-and-usb-dacs/1920#post_9273723
. NuForce Icon HDP (USB DAC/amp):
http://www.nuforce.com/hp/products/iconhdp/index.php
. NuForce Icon Mobile (USB DAC/amp):
http://www.6moons.com/audioreviews/nuforce10/mobile.html
http://www.head-fi.org/t/595071/android-phones-and-usb-dacs/435#post_8759826
. NuForce Icon uDAC-2 (USB DAC/amp):
http://www.digitaltrends.com/headphone-amplifier-reviews/nuforce-icon-udac-2-review/
http://www.head-fi.org/t/628374/samsung-galaxy-s3-to-dac-usb-micro-b-male-to-mini-b-male/30#post_8939722
http://www.facebook.com/permalink.php?story_fbid=410941392302962&id=164588276945555
. Ordnance .25 (USB DAC/amp):
http://jaben.net/forums/index.php?topic=9984.0
. Practical Devices XM6 (USB DAC/amp):
http://www.head-fi.org/t/510543/new-practical-devices-xm6-amp-dac-the-complete-review
http://www.head-fi.org/t/633511/pictures-of-your-portable-rig-part-xvi/2490#post_9215369
http://www.raysamuelsaudio.com/products/intruder
http://www.head-fi.org/t/627080/new-balanced-portable-amp-from-rsa-w-dac/30#post_8781567
http://www.raysamuelsaudio.com/products/predator
http://www.head-fi.org/t/595071/android-phones-and-usb-dacs/150#post_8538933
http://www.head-fi.org/t/624676/sony-pha-1-portable-dac-amp
http://www.head-fi.org/t/645086/samsung-galaxy-s3-and-hd598s#post_9033830
http://stoneracoustics.blogspot.fr/
http://forum.lowyat.net/index.php?showtopic=2452730&st=160&p=54596977&#entry54596977
. Sunrise Ray DA-P1 (USB DAC/amp):
http://www.head-fi.org/t/660291/short-review-sunrise-audio-ray-excellent-portable-dac-amp
http://www.head-fi.org/t/595071/android-phones-and-usb-dacs/1950#post_9282772
. Syba SD-AUD20101:
http://www.sybausa.com/productInfo.php?iid=1191
http://www.head-fi.org/t/595071/android-phones-and-usb-dacs/375#post_8736082
. TCG U-SKIN (USB DAC/amp):
http://www.tcgcn.com/productshow.asp?id=517
http://www.head-fi.org/t/595071/android-phones-and-usb-dacs/1920#post_9274670
. Topping D1 Mark 2 (USB DAC/amp):
http://www.head-fi.org/t/636606/topping-d1-mark-2-review
http://forum.xda-developers.com/showpost.php?p=28673076&postcount=871
. Topping D2 (USB DAC/amp):
http://www.mightybigword.com/tnt/2012/03/topping-d2-dac-review/
http://forum.xda-developers.com/showpost.php?p=32920194&postcount=1357
. Topping TP30 (USB DAC/amp):
http://news.cnet.com/8300-5_3-0.html?keyword=Topping+TP-30
http://www.androidnz.net/2012/05/samsung-galaxy-s-iii-usb-audio.html
. Turtle Beach Audio Advantage Micro II:
http://linkai8424.blogspot.fr/2011/03/turtle-beach-audio-advantage-micro-ii.html
http://www.head-fi.org/t/595071/android-phones-and-usb-dacs/1155#post_8978516
. Unique Melody PP6 using USB Audio Recorder PRO (USB DSP/DAC/amp/CIEM):
http://www.custom-iem.com/um-platform-pure-pp6-p-670.html
http://www.head-fi.org/t/613417/unique-melody-platform-pure-6-pp6-discussion-appreciation-tour-thread/360#post_8965862
http://www.head-fi.org/t/595071/android-phones-and-usb-dacs/1875#post_9255450
http://venturecraft.jp/gadget_en/gdx.php
http://www.head-fi.org/t/595071/android-phones-and-usb-dacs/315#post_8708233
http://www.facebook.com/media/set/?set=a.529433853753069.134639.436744613021994&type=1
http://www.head-fi.org/t/642504/xduoo-new-company-making-interesting-portable-dac-and-amp-units/45#post_9176225
. Zero DAC (USB DAC/amp):
http://www.head-fi.org/t/269458/review-zero-24-bit-192khz-dac-headphone-amp-pre-amp
http://www.head-fi.org/t/633201/confirmed-list-of-usb-dacs-for-the-galaxy-s3-international-us-or-note-2#post_9329790
Bold: new addition to the list
Reactions: nipit
post-9403679
Post #2,235 of 9,413
Coop
Did a re-build of my OTG + Charging cable tonight:
Updates from the previous version:
- The point where all the cables come together is now protected by a decent piece of housing instead of just some shrinktube
- The cable is sleeved with braided nylon sleeving
- The Micro B that acts as a Micro A is now the only connector that has a red marker on it
Users Who Are Viewing This Thread (Users: 0, Guests: 5)
