Android phones and USB DACs
post-9386676
Post #2,191 of 9,413
DanBa
Micro USB2.0 B and AB mating configurations:
http://www.globalconnectortechnology.com/usb-connectors/micro-usb-2/
"Micro B receptacle accepts Micro-B plug and NOT Micro-A plug. Micro-AB receptacle accepts both Micro-A and Micro-B plugs.
With the introduction of the USB Micro Plug, a new plug receptacle called Micro-AB was also introduced. It can accept either a Micro-A plug or a Micro-B plug.
An OTG product must have a single Micro-AB receptacle and no other USB receptacles [according to the USB specification].
The OTG cable has a Micro-A plug on one side, and a Micro-B plug on the other (it cannot have two plugs of the same type). OTG adds a fifth pin to the standard USB connector, called the ID-pin; the Micro-A plug has the ID pin grounded, while the ID in the Micro-B plug is floating. The device that has a Micro-A plugged in becomes an OTG A-device, and the one that has Micro-B plugged becomes a B-device. The type of the plug inserted is detected by the state of the pin ID."
The USB connector mounted on a USB host or on a USB peripheral is called "receptacle", and the USB connector attached to the cable is called "plug".
http://www.wakamesoba98.net/2012/03/xperiausb-part1-usb.html
Micro-AB receptacle:
Micro-B receptacle:
Micro-B plug – Micro-A plug:
Apparently, the OTG-capable Sony Xperia Z has a Micro-AB receptacle:
Apparently, the OTG-capable Samsung Galaxy S4 has a Micro-B receptacle:
Apparently, the OTG-capable HTC One has a Micro-B receptacle:
OTG-capable Android device => Micro-A plug to Standard-A receptacle adapter + Standard-A plug to B-plug cable provided by the USB DAC manufacturer => USB DAC
A Micro-A plug to Standard-A receptacle adapter:
http://www.digikey.com/product-detail/en/ZX40-A-5S-75-STDAJ/H11576-ND/1787103
A functional Micro-A plug (having the physical appearance of a Micro-B plug, but ID pin 4 connected to the GND pin 5) to Standard-A receptacle adapter:
http://www.amazon.fr/Adaptateur-C%C3%A2ble-Samsung-Galaxy-google/dp/B00646PX3S/ref=sr_1_17
Micro-USB Cables and Connectors Specification:
http://193.219.66.80/datasheets/usb_20/Micro-USB_final/Micro-USB_1_01.pdf
post-9387172
Post #2,192 of 9,413
NZtechfreak
Got my Galaxy S4 this morning.
USB audio working with my HeadAmp Pico and RSA Intruder, not working with my Apex Glacier (need to test the Apex Glacier via USB Audio Recorder Pro next).
post-9387208
Post #2,193 of 9,413
Theogenes
Hmmm... That's a bit concerning on the Glacier. Wonder what the issue is...
post-9387331
Post #2,194 of 9,413
BBEG
Can someone give me the rundown of how to use USB Audio Recorder Pro? I feel like I must be doing something wrong. I have listed compatible devices, an OTG cable, and get no sound coming from my E17.
post-9387597
Post #2,195 of 9,413
iCrap
I got it working with my E10, but my E10 ONLY works with that app. I don't understand why...
Just select the output and load a song, then press play. Also, it dosen't play MP3.
post-9387912
Post #2,196 of 9,413
DanBa
It’s weird.
I’m wondering what is the SoC of your Galaxy S4: Samsung Exynos 5 Octa or Qualcomm Snapdragon.600.
It should be interesting to compare and analyze Galaxy Note2/Apex Glacier and Galaxy S4/Apex Glacier logcat and dmesg outputs.
http://www.flashmyandroid.com/forum/showthread.php?805-How-to-get-logcat-and-dmesg-outputs-for-trouble-shooting-!
post-9388006
Post #2,197 of 9,413
DanBa
[size=10pt]"Make sure to connect your audio device BEFORE starting the app."[/size]
A Meizu MX using USB Audio Recorder PRO can work with USB DAC:
http://www.head-fi.org/t/642504/xduoo-new-company-making-interesting-portable-dac-and-amp-units#post_9027380
"I beta-tested the USB Audio Recorder PRO app with a Meizu MX 4-core and it worked fine with an ODAC, no problem at all."
An Android smartphone using USB Audio Recorder PRO can work with FiiO E17 USB DAC/amp:
http://www.head-fi.org/t/595071/android-phones-and-usb-dacs/1290#post_9031611
"I successfully tested a FiiO E17 with my stock Galaxy S3 using the USB Audio Recorder PRO app."
Four components to be tested:
Meizu MX >> Micro USB to Standard-A receptacle adapter cable + USB cable provided by Fiio >> FiiO E17
Functional FiiO E17 & functional USB cable ??
Test the E17 with a PC
Functional Meizu MX & functional adapter cable ??
Test the Meizu MX & the adapter cable with a simple USB peripheral like a USB mouse or a USB keyboard
post-9388030
Post #2,198 of 9,413
NZtechfreak
It’s weird.
It's the Qualcomm (although with my other Qualcomm handsets the Apex tended to work and the Pico not, just to confuse things).
post-9390822
Post #2,199 of 9,413
DanBa
USB OTG cables:
http://forzaaudioworks.com/en/product.php?id_product=55
USB OTG-capable Android device > digital USB audio out >> USB OTG cable >> standard USB DAC
"Copper/Silver Series Android LOD made for connecting your Android device through digital out to external DAC. Features FAW custom made, gold plated Micro-B USB plug with OFC copper pins and USB connector of your choice. Check first if your Android device supports digital line out through USB OTG cable. For best ergonomics and orientation of plugs (if they should be inverted or not), write your setup in comment box at the checkout (Android device and external DAC)."
"All my cables work with Android devices like eg, Galaxy S3, HTC One etc. In all of them ID pin is connected to ground to enable digital line out."
. Functional Micro-A plug, i.e. ID pin connected to ground, having the appearance of a Micro-B plug to Standard-B plug cable
. Functional Micro-A plug having the appearance of a Micro-B plug to Mini-B plug cable
. Functional Micro-A plug having the appearance of a Micro-B plug to Micro-B plug cable
Cables to connect a DAC to an amp:
Cables to connect an amp to headphones / IEM:
post-9391181
Post #2,201 of 9,413
Buckster
those getting the S4 to work with USB DACs
do you have to use USB Audio Pro - or do they work in all programs ? (just like you can assign say bluetooth output to a speaker)
reason I ask is that about 30-40% of my listening is to films, tv programs etc
thanks
post-9391386
Post #2,202 of 9,413
Zeppelin
post-9391853
Post #2,203 of 9,413
DanBa
I think my use of your picture is covered by fair use, because it is for public interest.
Some fellow forum members are asking about Android & iBasso D-Zero, and a picture is worth a thousand words.
And I did provide a link back to the original picture posted on a public forum.
Anyway, I just remove your picture and your mentioned words from my post.
post-9392336
Post #2,204 of 9,413
NZtechfreak
thanks
Works in all the media players, just like it did with my S3/Note 2/Butterfly/XZ.
Actually haven't tried a video player, should work the same there also.
post-9392834
Post #2,205 of 9,413
Theogenes
Kind of a bizarro-world concern... pictures on the internet are, uh, pictures on the internet. You probably don't want to post them if you have a problem with the idea that somebody might see them or refer to them elsewhere. JM2C.
Users Who Are Viewing This Thread (Users: 1, Guests: 11)
