lin0003
- Jan 4, 2013
Ok. I just bought the Miracle. 5 weeks left until it gets here.
Any portable headphone that comes close to the UM Miracle?
Hi Joker,
I have the AKG k518le's, I've removed the foam pieces and I've switched the earpads with the ones on my Organic Headphones(which I''m pretty sure is identical to the Coby CV-185) and this reduced the bass and brought out the highs and mids quite a bit but the residual bass is still a bit too much to my liking.
My music of choice is primarily Metal and I do listen to classical and rock as well. I'm not really happy with how metal sounds on these (too much bass and they sound a bit congested on complex tracks). Would the hd 25 velour pads change the sound further? Would stuffing cotton inside the casing absorb the bass?
... Or should I just get another headphone?... If so what would you recommend in this price range. Would the Akg 514mkII or the Incipio f38(FA-004) be good for my tastes? or what about the Superlux HD 660?
Some music I listen to- Sigh, Omnium Gatherum, Wintersun, Vintersorg, Windir...and the like
Edit: I must admit though that these cans are amazing for some other genre's of music although the K518's did get much better for metal after those mods and a little burn in, I just want a bit more though
I have those cans aswell and I too find the bass sometimes overwhelming, the phone it´s pretty dark, if you don't want to spend to much I can recomend any good Koss like the KCS75 or the portapro or even the ktx1, if you can spend a bit more any good grado would do a better job on metal (it's my fav type of music along alternative rock).
Hi Joker,
If there are any small holes/vents on the cups of the K518, taping them up should reduce bass.
I doubt any modification to the K518 would make it lean enough - it's a bassy headphone. If you're willing to go full-size, Superlux might be the way to go. I haven't tried the HD660 but the HD668B was quite good in the <$100 range and nowhere near as bassy as the K518.
Superlux?
The insipios are supposed to really uncomfortable. Fischer used better pads. I'd look at the CAL!, V6, and the Samson clones of the AKG k240 (there are two brands of well received k240 clones, the other escapes me). The k240 is $80 on amazon at the moment, and might be an option.
Wow! Thank You all for the replies. I do have the Samson sr850 which I'm guessing is very similar to the HD668B. I like the sound although I find the treble painfully harsh at times which is a problem for me and they do sound a bit thin. I only have a few hours on them though. Do they get better over time?
Edit: I take that back, I had these burning in over the last couple of days at my place when I was visiting my folks. I come back, tried them on, and they are pretty great. I'm happy with them
Back to my portable option, Have any of you heard the AKG 514 MKII? Its on sale for 60 bucks at Canada computers. I've read it has great mids and high's, would this be good for metal? It seems to be really comfortable which is another issue I have with the K518's.
Btw are there any closed portable headphones that have a similar sound signature to the Samsons?
@ljokerl, can't wait for you to get your hands on the M-100... It's been getting 5-star reviews and editor's choice awards left-and-right but it's really good and exciting to see your take on it though, especially with your vast number of hands-on experience with portables.
Also, the AKG K451 and K618/K619 have been really popular in the EU... Can we expect your review on those in the near future?
Hi Everyone, ( I am not sure which topic is more relevant so I posted this one also to the "buying portable or in-ear .... topic")
This is my first post on headfi. I feel a little bit lost in many posts and I want to ask your opinion.
I have some good set up for my home hifi system but the WAF (wife acceptance factor) of my favorite music (Metallica to Deep Purple, Country to Glam Rock) is not very good and I need headphones. I am using senheisser CX300 in ears for sometime but I need better headphones. I will buy one IEM and around 150USD I made my choice for yamaha eph100 as there are good reviews on headfi.
I also want on ears and I want one closed and one open on ear headphone. My budget will be around 300USD for two of them and I narrowed my choices for closed one to Senn HD25 1-II (200USD.amazon) but I am not sure about the open ones I tried AKG 420 in a local shop few days a a part and first time I thought they are incredible but one week later I thought they are somewhat muddy.
What do you think about my IEM and closed choices and what do you suggest for a open one (grados may be)
Secondly do you think I will like the senns and will not want to use open ones.
Thirdly I am thinking of buying a fiio E12, will it help to improve the sound quality for the above mentioned headphones. Iphone 4, possibly Samsung S4 will be the sources. I will be looking for a dedicated mp3 player also but not sure yet. İpod classic vs sensa.
Thanks for the answers
Hello Joker
Will you be adding the Senn Momentum to this list? I would be very interested in hearing your thoughts compared with the DT1350.
Thanks.
but I am not sure why you wouldn't just go for one very good full-size headphone for home use plus an IEM, rather than open + closed portable + IEM.
