Shootout: 114 Portable Headphones Reviewed (Xiaomi Mi Headphones added 04/21/2015)
- Thread starter ljokerl
- Tags
- akg akg-high-performance-closed-back-dj-headphones-k181dj akg-k518dj alessandro alessandro-ms-1 astrotec-as200hd audio-technica audio-technica-ath-em7-gm-adjustable-aluminum-clip-on-headphones audio-technica-ath-es7-portable-headphones-black audio-technica-ath-esw9a audio-technica-ath-m50s beyerdynamic beyerdynamic-dt-235-headphone-black beyerdynamic-dt-235-headphone-white creative-aurvana-live-2-headset-with-40mm-drivers-and-in-line-mic creative-aurvana-live-headphones denon denon-ah-d1100 denon-dj-professional-headphones-denon-dnhp700 equation koss koss-ksc75-portable-stereophone-headphones koss-portapro-headphones-semi-open koss-prodj100 m-audio m-audio-studiophile-q40-closed-back-dynamic-headphones panasonic phiaton phiaton-ms-400 sennheiser sennheiser-hd-228-closed-back-headphone-with-excellent-bass sennheiser-hd-238-stereo-open-aire-headphone sennheiser-hd-25-1-ii-professional-headphone sennheiser-px-200-ii-b-closed-on-ear-mini-headphones spider-realvoice-vertical-in-the-ear-headphone
coldmack
- Jul 15, 2009
So then the M-80 has the least bass, while the LP has the most and LP2 is inbetween? How much/heavy is the bass on the M80?
Impulse
The m-80's is above neutral but it's pretty tight and punchy, doesn't overpower the mids.
coldmack
- Jul 15, 2009
How about the m100? How are those?
My only worry I have with the M80 are they could be a bit on the larger size for my taste. .
the search never ends
- Oct 25, 2009
There is a giant thread on the M100's
Impulse
The M-100 are larger if you're alluding to physical size... The M-80 are actually remarkably small, even by on-ear standards. LP/LP2 are same size as the M-100 only they don't collapse.
coldmack
- Jul 15, 2009
Is there like pics comparing the M-80 to others in it's class and price range?
Impulse
Here they are next to Senn HD25-1 ii and Beyer DT 1350... Radio Shack usually has a display model out if you wanna check them out in person. The cups are rather small, the hexagonal shape helps keep them compact. I can post a pic next to MEElec HT-21 if you're familiar with those (they're smaller).
coldmack
- Jul 15, 2009
Thank you for that pic, can you post like a side view comparison if you have any?
The M80's cups are tiny, making even the diminutive HD25 and T50p/DT1350 look a bit bulky by comparison.
coldmack
- Jul 15, 2009
So I can got pretty much to any Radioshack and try these on?
Impulse
Should be able to, yeah, there's three near me and they all have it out for demo... Just bring a source, they're not hooked up to anything. They'll typically have some Skullcandies and maybe an Audio Technica NC set or some Beats out too, from what I've seen around here anyway.
I went to the Rat Shack to try them out several times before eventually ordering them on Amazon. ($130-160 vs $230, you lose RS) Microsoft stores carry them too btw, can't remember if the one that opened here recently had them out to try, but they did have some demo headphones.
They won't let you try them, but they do have a 30-day return policy.
Impulse
Huh, that'd weird, your local Radio Shack doesn't have a headphone demo section?
coldmack
- Jul 15, 2009
So, now I am not sure if I should go to RS or MS store to try them out, or will I be out of luck at both? I have two Radio shacks near me(and about a mile away from each other too) so I could try both, but I could be out of luck at both.
Total: 8 (members: 0, guests: 8)
