swbf2cheater
- Aug 14, 2009
edit: meh, idk about that p5 being ranked higher than the esw9
Would there be any chance of reviewing the JVC RX700 or the Shure 440? I am looking to upgrade from my Aiwa and they are about the only decent well prices headphones in UK that is not a rip off compared to US prices.
For mainly portable use, but a little bit at home as well, is the Sony XB700 really worth the extra $30 or so over the XB500? I heard the XB500 and liked the sound sig, is the XB700 $30 worth of improvement?
hello Joker,
I notice the P5 has 8/10 in value in the review but 7 in the table.
Good reviews as usual, i could think of get me a P5 when they go for 120$, i ditch the look.
On question:
I have only stock vinyl(?) pads for my hd25, cant stop thinking if the velour would make a noticeable difference, for the better. They go for 25 to 30$, does the change in sound worth the price?
^ Whoa... echo? Strong possibility the one you listened to was a fake. There isn't even a hint of echo on mine and the bass is very soft and forgiving
$30 for HD25 pads?....snip...snip...snip...
Ah, that would be a mistake. Should be 7/10 all around.
I have had the esw9 myself, I liked the sound, but it sounded a little bassy but without punch...
The isolation is not that great, at low volume it seems to increase the outside noise, really strange, or I may say it this way, it made some kind of echo...
It was nice, really beautiful but, I was always afraid of scratching it...
I found the esw9 bass to be soft (in terms of feel, not volume). It also had a bit of resonance to it similar to the Phiaton MS400 which would make some outside noises seemingly louder. I figure it is also due to the isolation which does not cut out all frequencies evenly, so those parts of the spectrum that don't will feel amplified.
The fake esw9s that I've seen seemed to share the same overall shape and were even made of wood, so chances are they would have a similar isolation/resonant characteristic.
