Jan 24, 2013 at 1:51 PM Post #1,486 of 9,526
http://www.head-fi.org/t/595071/android-phones-and-usb-dacs/1440#post_9083315
. FiiO E07K Andes (USB DAC/amp): to be confirmed
http://headfonics.com/2012/12/fiio-e07k-the-andes/
http://www.head-fi.org/t/638910/new-fiio-e07k-andes-information-and-impressions/15#post_8924515
http://www.head-fi.org/t/628254/fiio-e18/15#post_8973799
"We have tested E07K do work as DAC for GALAXY S3 and Note 2, but there are few users reported that they can't make it work. so the official reply can not state as " compatible " with Galaxy S3 and Note 2."
[FiiO]
How about another equivalent USB DAC/amp reportedly working with the Galaxy S3 like
the iBasso D-Zero
http://www.head-fi.org/t/595071/android-phones-and-usb-dacs/1335#post_9044972
http://www.headfonia.com/fiio-e7-meet-your-rival-the-ibasso-d-zero/
or
the Topping D1 Mark 2?
http://www.head-fi.org/t/636606/topping-d1-mark-2-review
http://www.headfonia.com/topping-d1-mark-ii/
Jan 24, 2013 at 2:47 PM Post #1,487 of 9,526
Could anybody tell me with what kernels, roms, music players does the fiio e07k work with the samsung galaxy s3. I know that it works with android 4.1.2 but i need more details so i can be sure that it works and then i can order it.
stock, stock stock stock. Most likely any player. Neutron player is the best for quality - worst for interface. Player Pro is the best middle ground (I tested around 15 players.)
And if you read a few posts up then you will see.
Pretty much only the stock based roms work, and even though Siyah kernel supports it, often the roms don't.
The fix shown above works with the liquidsmooth rom, and thats about it,
Jan 24, 2013 at 6:20 PM Post #1,489 of 9,526
If using an external DAC then quality of sound from the player isn't particularly relevant though.
have a stock S3 and i can not get it to interwork with the XP-1 for the life of me, how do we switch on the USB audio out?
There is no switch for USB audio. Plug in DAC to USB host cable, plug in host cable to phone. If that doesn't work then things to try are plugging the DAC into a externally powered USB hub (or similar solution that will power the attached USB device like Y-split cable with a power input), or alternately try the app USB Audio Recorder Pro.
Jan 24, 2013 at 6:41 PM Post #1,490 of 9,526
giving the impression that the phone was still using the internal dac. But now the volume is stuck a max and you can't change it. Don't now if it's placebo but I actually noticed a few details here and there with this patched applied which kinda convinced me that the phone is actually using the dac now.
Yusssss!
I'm glad you're reassured, but it was never using the internal DAC. If it was using the internal DAC it would have to output an analog signal to the external DAC over USB. I would say the differences you are hearing are expectation bias, which is a very powerful influence outside of blinded tests.
Jan 24, 2013 at 8:49 PM Post #1,491 of 9,526
Great news everyone!
The patch that jacknorris was working on over at XDA works for the i9300 and the Nexus 7! :D (No US S3 confirmed to be working atm *sadface*)
This means that we can get our AOSP/AOKP fix!
Currently running CM10.1 with Siyah 1.8.6 using the D-zero, it all works flawlessly! Moreover, it seems that the phone REALLY uses the dac now. On stock/stock roms, you could still change the volume on the phone whilst a external dac was connected, giving the impression that the phone was still using the internal dac. But now the volume is stuck a max and you can't change it. Don't now if it's placebo but I actually noticed a few details here and there with this patched applied which kinda convinced me that the phone is actually using the dac now.
Yusssss!
http://forum.xda-developers.com/showthread.php?p=37125089#post37125089
I believe there needs to be some clarification... The patch jacknorris made, allows Nexus 7 users the ability to hotplug a USB DAC into their tablet.  Before this patch, you had to have the USB DAC plugged in when you booted up the Nexus 7.  Now, you can plug in a USB DAC into the microusb port at any time, and use it without having to reboot. The ability to use USB Audio is provided by many of the N7 kernels out there that enable this feature.
Of course, this is pretty awesome... It really was a pain to reboot everytime I wanted to use my USB DAC, so this patch makes the N7 even more awesome!
Jan 24, 2013 at 10:34 PM Post #1,492 of 9,526
The Android mini PC is a lot cheapier than the SqueezeBox Touch.
http://www.aliexpress.com/wholesale?SearchText=android+mini+pc&catId=0&manual=y
"Android Mini PC: The Next Tech Revolution?"
http://droidwithme.blogspot.fr/2012/12/android-mini-pc-next-tech-revolution.html
"But what if I told you that was about to change? That there is a growing market in the tech industry just around the corner that can very well shape the landscape the way tablets did?
A device that has all the internals that a Android phone/tablet has but with no screen. What it does have is a HDMI output that allows it to connect to your existing HD television. All while running on the latest version of Android with a dual core processor and smaller than any set top box on the market.
The asking price?
A mere $60 USD.
A device filled with endless possibilities.
Android Mini PCs are a relatively new product. The concept is simple. A small device with good internal specifications, running the latest Android, and an HDMI output for the screen. This allows a user to have access to the best Android has to offer on their big screen television. Imagine checking your E-mail, using over 700,000 apps in the Google Play Store, watching videos, listening to music, or browsing the web all from the comfort of your couch."
Anyhow with Android phone, Android tablet and Android mini PC, Android is definitely a New Kid in Town for the USB DAC market sector.
For the low admission fee and what it could possible do, I have to admit it's very interesting.
Jan 24, 2013 at 11:43 PM Post #1,493 of 9,526
I am a frequent flyer at XDA and more of a limited poster here but cross referencing I stumbled onto this thread.  I'm giving it a crack now (the hotplugging part).  I got it working by default with reboot but now I'm venturing with the hotplugging.
Anyways, is there a way to charge the Nexus and run USB audio out (e.g. say a USB switch?).  Can it support input and output or would you have to play with the POGO pins?  I only ask because down the road I'm considering installing the Nexus in a car as a media interface and I'd like to be able to let it be continuously charged and have USB audio out so it's a clean signal leaving the device.  Thanks!
Jan 25, 2013 at 3:04 AM Post #1,494 of 9,526
You are correct but as a i9300 user this is new and great stuff. Before I had to stay on stock/stock roms, but now i can move on to CM10.1 and other 4.2.1 roms. The patch is supposed to work on more devices than the N7/i9300, there's just no confirmation yet.
Jan 25, 2013 at 3:16 AM Post #1,495 of 9,526
Great news for AOSP AT&T Galaxy S3 fans!!!
I flashed Jack Norris' patch:
http://forum.xda-developers.com/showthread.php?p=37158313#post37158313
While CyanogenMod 10.1 & AOKP do not work yet for some reason, I was able to flash a different AOSP based ROM which DOES work!!!
Liquidsmooth ROM works after flashing Jack's patch!!!! Hotplugging and all! Thank you, JACK!!!!
Liquidsmooth looks almost identical to CM10.1. I've never used it before so it's new to me.
Here is the ROM:
http://forum.xda-developers.com/show....php?t=2080247
And I flashed Ktoonsez 4.2 kernel and USB-DAC still works!
http://forum.xda-developers.com/show....php?t=1756776
I don't know for sure, but I would suspect that the Liquidsmooth ROM for Sprint, Verizon and T-Mobile S3's will probably also work after flashing Jack's patch.
CLICK THIS THREAD for my "quick guide" on how to get all this working:
http://forum.xda-developers.com/showthread.php?t=2116877
EDIT:  Jack thinks he has figured out what's wrong in CyanogenMod and is going to release another patch for that soon.
Jan 25, 2013 at 3:50 AM Post #1,496 of 9,526
This is great news now that this stuff is working on CM/AOSP ROMs.
Jan 25, 2013 at 4:19 AM Post #1,497 of 9,526
Now that I have my AOSP, there is one last thing I need for USB-DAC nirvana.
I need a USB-OTG cable that also triggers "dock mode" or "car mode".  Has anyone found anything like this or know how to hack an OTG cable into doing this?
Jan 25, 2013 at 4:30 AM Post #1,498 of 9,526
A list of stock Android-powered devices reportedly interworking with standard USB DAC:
stock Android device > digital USB audio out >> USB OTG cable >> standard USB DAC >> amp >> headphones
. Acer Iconia Tab A200 using USB Audio Recorder PRO (tablet):
http://www.engadget.com/2012/03/15/acer-iconia-tab-a200-review/
http://www.extreamsd.com/USBAudioRecorderPRO/
. Acer Iconia Tab A500 using USB Audio Recorder PRO (tablet):
http://www.engadget.com/2011/04/26/acer-iconia-tab-a500-review/
. Archos G9 (tablet):
http://www.anandtech.com/show/5802/the-archos-g9-tablet-reviews-fast-enough
http://forum.xda-developers.com/showthread.php?t=1539576
. Asus Transformer Pad TF300 using USB Audio Recorder PRO (tablet):
http://www.engadget.com/2012/04/22/asus-transformer-pad-tf300-review/
. Asus Transformer Pad Infinity TF700 using USB Audio Recorder PRO (tablet):
http://www.engadget.com/2012/06/25/asus-transformer-pad-infinity-tf700-review/
. Asus Transformer Prime using USB Audio Recorder PRO (tablet):
http://www.engadget.com/2011/12/01/asus-eee-pad-transformer-prime-review/
. Google Galaxy Nexus using USB Audio Recorder PRO (smartphone):
http://www.theverge.com/products/galaxy-nexus-gsm/2946
http://forum.xda-developers.com/showpost.php?p=35484769&postcount=52
. Google Nexus 7 using USB Audio Recorder PRO (tablet):
http://www.engadget.com/2012/06/28/nexus-7-review/
. Google Nexus 10 using USB Audio Recorder PRO (tablet):
http://www.engadget.com/2012/11/02/nexus-10-review/
http://www.head-fi.org/t/595071/android-phones-and-usb-dacs/1110#post_8973836
. HTC Butterfly / HTC Droid DNA  / HTC J Butterfly (smartphone):
http://www.htc.com/www/smartphones/htc-butterfly/
http://www.head-fi.org/t/595071/android-phones-and-usb-dacs/1425#post_9082851
. Huawei Ascend D1 Quad XL using USB Audio Recorder PRO (smartphone):
http://www.engadget.com/2012/10/20/huawei-ascend-d1-quad-xl-review/
http://www.head-fi.org/t/628254/fiio-e18/15#post_8988466
. Huawei MediaPad using USB Audio Recorder PRO (tablet):
http://www.androidnz.net/2012/09/rapid-review-huawei-mediapadt-mobile.html
. Meizu MX Quad-Core using USB Audio Recorder PRO (smartphone):
http://www.xda-developers.com/android/meizu-mx-quad-core-review/
. Minix Neo G4 (Android mini PC):
http://www.squidoo.com/minix-neo-g4-review
http://www.facebook.com/minixtech/posts/466648763397297
. Minix Neo X5 (Android mini PC):
http://tabletrepublic.com/forum/android-mini-pc/minix-neo-x5-google-tv-box-16gb-android-4-1-bluetooth-review-3241.html
http://forum.audiogon.com/cgi-bin/fr.pl?ddgtl&1358382120&openflup&5&4
. Motorola Razr Maxx HD using USB Audio Recorder PRO (smartphone):
http://www.engadget.com/2012/10/19/droid-razr-hd-and-razr-maxx-hd-review/
. Motorola Xoom using USB Audio Recorder PRO (tablet):
http://www.engadget.com/2011/02/23/motorola-xoom-review/
. Samsung Galaxy Camera EK-G100 using USB Audio Recorder PRO (camera):
http://www.digitaltrends.com/digital-camera-reviews/samsung-galaxy-camera-ek-gc100-review/
. Samsung Galaxy Note II (smartphone):
http://www.engadget.com/2012/10/08/samsung-galaxy-note-ii-review/
. Samsung Galaxy Note 10.1 (tablet):
http://phandroid.com/samsung-galaxy-note-10-1/
http://www.head-fi.org/t/595071/android-phones-and-usb-dacs/645#post_8814831
. Samsung Galaxy R using USB Audio Recorder PRO (smartphone):
http://www.engadget.com/2011/08/10/samsung-galaxy-r-officially-announced-for-europe-and-asia-nobod/
. Samsung Galaxy S III (smartphone):
http://www.theverge.com/2012/5/25/3042640/samsung-galaxy-s-iii-review
. Samsung Galaxy Tab 2 7.0 using USB Audio Recorder PRO (tablet):
http://www.engadget.com/2012/04/11/samsung-galaxy-tab-2-7-0-review/
. Samsung Galaxy Tab 7.7 using USB Audio Recorder PRO (tablet):
http://www.engadget.com/2012/02/07/samsung-galaxy-tab-7-7-review-international-edition/
. Samsung Galaxy Tab 10.1 using USB Audio Recorder PRO (tablet):
http://www.engadget.com/2012/05/15/samsung-galaxy-tab-2-10-1-review/
. Sony Xperia S using USB Audio Recorder PRO (smartphone):
http://www.engadget.com/2012/03/08/sony-xperia-s-review/
. Sony Xperia Sola using USB Audio Recorder PRO (smartphone):
http://www.androidcentral.com/device/sony-xperia-sola
. Sony Xperia Tablet S using USB Audio Recorder PRO (tablet):
http://www.engadget.com/2012/09/24/sony-xperia-tablet-s-review/
. Toshiba Thrive using USB Audio Recorder PRO (tablet):
http://www.engadget.com/2011/07/22/toshiba-thrive-review/
. Wiko Cink King using USB Audio Recorder PRO (smartphone):
http://www.wikomobile.com/telephone-portable-Cink-king.php
A list of standard USB DAC reportedly interworking with the Android-powered smartphone Samsung Galaxy Note II:
stock Galaxy Note II > digital USB audio out >> USB OTG cable (micro-A plug inserted into the Note II) >> standard USB DAC >> amp >> headphones
. Apex Glacier (USB DAC/amp):
http://www.head-fi.org/t/632019/apex-glacier-amp-dac-review-and-appreciation-thread
http://www.head-fi.org/t/632019/apex-glacier-amp-dac-review-and-appreciation-thread/165#post_8924724
. Asus Xonar U3 (USB DAC/amp):
http://www.overclockersclub.com/reviews/asus_xonar_u3/
http://www.head-fi.org/t/595071/android-phones-and-usb-dacs/1200#post_8997468
. Audio-gd NFB-16 (USB DAC/amp):
http://www.audio-gd.com/Pro/Headphoneamp/NFB16/NFB16EN.htm
http://www.head-fi.org/t/625054/samsung-galaxy-note-2/120#post_8943120
. AudioQuest DragonFly using USB Audio Recorder PRO:
http://www.head-fi.org/t/617241/audioquest-dragonfly-review-affordable-outstanding-tiny-dac-amp
http://www.head-fi.org/t/595071/android-phones-and-usb-dacs/1035#post_8959237
. CEntrance DACport LX using USB Audio Recorder PRO:
http://www.headfonia.com/cheaper-better-the-centrance-dacport-lx/
http://www.head-fi.org/t/595071/android-phones-and-usb-dacs/1065#post_8968468
. ELE EL-D01:
http://www.cnfeature.com/goods.php?id=1299
http://www.head-fi.org/t/643883/portable-amp-for-galaxy-note-2-and-grado-sr80i-heaphones#post_9012249
http://www.headphiles.org/index.php?t=msg&goto=253249&
. Focal XS 2.1 (USB speakers):
http://reviews.cnet.com/speakers-speaker-systems/focal-xs-speakers-with/4505-6467_7-33618064.html
http://www.homecinema-fr.com/forum/multimedia-materiels-tablettes-et-smartphones/samsung-galaxy-note-ii-2-go-16-go-android-4-1-2-t30029275.html#p177362999
. GoVibe Magnum (USB DAC/amp):
http://www.head-fi.org/t/324577/review-govibe-magnum-usb-dac-amp
http://www.head-fi.org/t/633201/confirmed-list-of-usb-dacs-for-the-galaxy-s3-international-us-or-note-2#post_8809248
. GoVibe Martini-U (USB DAC/amp):
http://jaben-bandung.com/index.php?route=product/product&product_id=196
http://www.head-fi.org/t/595071/android-phones-and-usb-dacs/990#post_8942287
. GoVibe Vulcan (USB DAC/amp):
http://www.head-fi.org/t/386127/go-vibe-vulcan
http://www.head-fi.org/t/595071/android-phones-and-usb-dacs/960#post_8929084
. HRT HeadStreamer Mobile (USB DAC/amp):
http://highresolutiontechnologies.com/headstreamer-mobile
http://www.computeraudiophile.com/f6-dac-digital-analog-conversion/power-galaxy-note-2-while-using-usb-dac-how-please-14029/
. HeadAmp Pico USB DAC/Amp: bug fixed by HeadAmp
http://www.headfonia.com/headamp-pico/
http://www.head-fi.org/t/595071/android-phones-and-usb-dacs/1305#post_9037872
. HeadAmp Pico Upsampling USB DAC:
http://www.head-fi.org/t/413230/headamp-pico-upsampling-usb-dac-pre-order-now-at-intro-price
. Headstage Lyrix Pro USB total (USB DAC/amp):
http://www.headphonia.com/Amps/Headstage-Lyrix-Pro-USB-total::10071.html
http://www.head-fi.org/t/595071/android-phones-and-usb-dacs/795#post_8854850
. iBasso D-Zero (USB DAC/amp):
. iBasso D12 (USB DAC/amp):
http://www.ibasso.com/en/products/show.asp?ID=63
http://www.head-fi.org/t/595071/android-phones-and-usb-dacs/405#post_8750862
. Leckerton UHA-6S MKII (USB DAC/amp):
http://www.innerfidelity.com/content/leckerton-uha-6s-mkii-portable-headphone-amplifier
http://www.head-fi.org/t/625054/samsung-galaxy-note-2/30#post_8777791
. MyST 1866 PortaDAC (USB DAC/amp):
http://www.musicaacoustics.com/wp/amplifiers/myst-1866/
http://player.ru/showthread.php?t=74459&page=34&p=1084707&viewfull=1#post1084707
. Objective DAC (ODAC):
http://epiphany-acoustics.co.uk/our-products/e-dac-24bit-miniature-usb-dac/
http://www.jdslabs.com/item.php?fetchitem=46
http://www.headnhifi.com/index.php/shop/objective/odac
http://www.head-fi.org/t/595071/android-phones-and-usb-dacs/435#post_8758515
. ODAC+O2 (USB DAC/amp):
http://epiphany-acoustics.co.uk/our-products/ehp-o2d-miniature-desktop-headphone-amplifier-with-usb-dac/
http://www.jdslabs.com/item.php?fetchitem=48
http://www.headnhifi.com/index.php/shop/objective/o2120527192048
. RSA Intruder (USB DAC/amp):
http://www.innerfidelity.com/content/canjam-rmaf-2012-ray-samuels-audio-intruder-balanced-portable-headphone-amp-and-dac
http://www.head-fi.org/t/595071/android-phones-and-usb-dacs/660#post_8819856
. RSA Predator (USB DAC/amp):
http://www.6moons.com/audioreviews/predator/predator_2.html
http://www.head-fi.org/t/625054/samsung-galaxy-note-2/120#post_8960049
. Sony PHA-1 (USB DAC/amp):
http://www.touchmyapps.com/2012/10/09/sony-pha-1-idevice-dac-and-headphone-amp-in-review/
http://www.head-fi.org/t/595071/android-phones-and-usb-dacs/465#post_8769593
. Stoner Acoustics UD100:
http://www.head-fi.org/t/626632/tiny-dac-big-sound-impression-of-stoner-acoustics-ud100-vs-odac
http://forum.lowyat.net/index.php?showtopic=2449848&st=220&p=56352256&#entry56352256
. VentureCraft Go-Dap X (USB DAC/amp): USB cable provided by VentureCraft
http://www.head-fi.org/t/609906/new-venturecraft-go-dap-x-for-both-idevices-and-pcs
. xDuoo XP-1 (USB DAC/amp):
http://www.jaben.com.hk/ProductView.asp?ID=776&SortID=358
http://www.head-fi.org/t/642504/xduoo-new-company-making-interesting-portable-dac-and-amp-units
. Zoom H4 using USB Audio Recorder PRO (USB recorder):
http://en.wikipedia.org/wiki/Zoom_H4_Handy_Recorder
http://forum.xda-developers.com/showpost.php?p=35472432&postcount=23
So far, like the quad-core Exynos powered Galaxy S III, the new quad-core Exynos powered Samsung Galaxy Note II can work with the FiiO E7, the iBasso D12, Leckerton UHA-6S MKII, the ODAC, … ; had some issue with the HeadAmp Pico (bug fixed by HeadAmp); and doesn’t work with the FiiO E17 using the stock USB audio driver.
So, in regard to the USB protocol, the behaviour of the Galaxy Note II is likely identical to the behaviour of the Galaxy S III.
A list of standard USB DAC reportedly interworking with the Android-powered smartphone Samsung Galaxy S III:
stock Samsung Galaxy S III > digital USB audio out >> USB OTG cable (micro-A plug inserted into the S III) >> standard USB DAC >> amp >> headphones
. AMB Gamma 1:
http://www.amb.org/audio/gamma1/
http://www.head-fi.org/t/608535/wolfson-dac-confirmed-for-galaxy-s3/780#post_8750043
. AMB Gamma 2:
http://www.amb.org/audio/gamma2/
http://forum.xda-developers.com/showpost.php?p=27247705&postcount=279
http://www.ttvjaudio.com/Apex_High_Fi_Audio_Glacier_portable_headphone_amp_p/aaa0000010.htm
http://www.head-fi.org/t/608535/wolfson-dac-confirmed-for-galaxy-s3/825#post_8776449
http://www.asus.com/Multimedia/Audio_Cards/Xonar_U3/
http://mybroadband.co.za/vb/showthread.php/429589-Samsung-Galaxy-S3?s=1a313fae4795a9a7493a6ce0f677ca8e&p=8551119&viewfull=1#post8551119
. Atoll DAC 100:
http://www.6moons.com/audioreviews/atoll2/atoll.html
http://forum.xda-developers.com/showpost.php?p=35266076&postcount=17
. Audio-gd Sparrow Version A  (USB DAC/amp):
http://www.audio-gd.com/Pro/Headphoneamp/Sparrow/SparrowEN.htm
http://www.head-fi.org/t/595071/android-phones-and-usb-dacs/915#post_8907415
. Behringer UCA202 (USB DAC/amp):
http://www.behringer.com/EN/Products/UCA202.aspx
http://www.head-fi.org/t/595071/android-phones-and-usb-dacs/240#post_8654226
. Behringer UCA222 (USB DAC/amp):
http://www.behringer.com/en/Products/UCA222.aspx
http://www.computeraudiophile.com/f6-dac-digital-analog-conversion/usb-audio-enabled-android-powered-samsung-galaxy-s-iii-12338/#post171651
. Beresford Caiman:
http://www.techradar.com/reviews/audio-visual/hi-fi-and-audio/hi-fi-accessories/beresford-caiman-673787/review
. C-Media chipset-based sound card Dynamode 7 channel USB 2.0 (USB DAC/amp):
http://soundplayer.systempebisnisonline.com/speaker/dynamode-7-channel-usb-2-0-sound-card/
http://forum.xda-developers.com/showpost.php?p=27604946&postcount=449
. Cakewalk Sonar SPS 25:
https://www.cakewalk.com/support/kb/reader.aspx/2007013101
. Cambridge Audio DacMagic:
http://www.headfonia.com/cambridge-dacmagic-review/
http://www.head-fi.org/t/631855/galaxy-s3-and-ca-dacmagic-plus#post_8899779
. CEntrance DacMini using USB Audio Recorder PRO (USB DAC/amp):
http://centrance.com/products/dacmini/
http://www.head-fi.org/t/595071/android-phones-and-usb-dacs/1200#post_8998731
. Corsair HS1 Gaming headset (USB DAC/amp/headphones):
http://www.anandtech.com/show/3989/corsair-hs1-gaming-headset
http://forum.xda-developers.com/showthread.php?p=27238117#post27238117
. Creative Xmod:
http://reviews.cnet.com/external-audio-adapters/creative-xmod/4505-9335_7-32105686.html
http://www.forum-audiophile.fr/musique-demat/fonction-usb-audio-a-activer-dans-android-t24441-60.html#p336853
. Dared MP 5 or ALO JV5 (USB DAC/amp):
http://www.positive-feedback.com/Issue24/dared_mp5.htm
http://www.head-fi.org/t/595071/android-phones-and-usb-dacs/990#post_8948190
. ELE EL-D01:
http://www.head-fi.org/t/586909/the-discovery-thread-new-dannybs-first-take-ath-ckn50-pg383-ele-hi-fi-usb-18-dac-pg-328/4905#post_8886336
http://www.head-fi.org/t/642554/fiio-e7-galaxy-s3-questions-for-car-audio/15#post_8991125
. FiiO E7 (USB DAC/amp):
http://www.headfonia.com/fiio-e7-portable-dac/
http://www.androidnz.net/2012/07/galaxy-s-iii-real-user-review-part-2.html
. FiiO E17 using USB Audio Recorder PRO (USB DAC/amp):
http://www.headfonia.com/the-upgrade-fiio-e17-alpen/
http://www.head-fi.org/t/595071/android-phones-and-usb-dacs/1020#post_8958018
. Furutech ADL Cruise (USB DAC/amp):
http://www.furutech.com/a2008/product2.asp?prodNo=399
http://www.head-fi.org/t/608535/wolfson-dac-confirmed-for-galaxy-s3/585#post_8567838
. GoVibe DAC:
http://jaben.net/forums/index.php?topic=2824.0
http://forum.lowyat.net/index.php?showtopic=2440879&st=500&p=53317360&#entry53317360
. GoVibe Mini USB DAC:
http://www.head-fi.org/t/566934/introducing-the-govibe-mini-usb-dac
http://www.head-fi.org/t/614111/finally-digital-out-for-galaxy-siii/15#post_8525675
. GoVibe Petite (USB DAC/amp):
http://www.head-fi.org/t/290711/govibe-petite-dac-amp-appreciation-thread-pics-little-update
http://www.head-fi.org/t/595071/android-phones-and-usb-dacs-how-to-increase-the-issues-priority-with-google/195#post_8552452
. HRT HeadStreamer (USB DAC/amp):
http://www.headfonia.com/hrt-headstreamer-review/
http://www.head-fi.org/t/608535/wolfson-dac-confirmed-for-galaxy-s3/750#post_8677483
. HRT Music Streamer II:
http://highresolutiontechnologies.com/music-streamer-ii
http://www.head-fi.org/t/608535/wolfson-dac-confirmed-for-galaxy-s3/465#post_8534856
http://www.head-fi.org/t/258967/headamp-pico-portable-amp-w-optional-upsampling-24-96-usb-dac-pre-order-thread
http://www.head-fi.org/t/632019/apex-glacier-amp-dac-review-and-appreciation-thread/270#post_9036297
http://www.headamp.com/pico/pico_usb_dac/index.htm
. HeadRoom Total BitHead (USB DAC/amp):
http://www.headphone.com/learning-center/bithead-faq.php
http://www.head-fi.org/t/595071/android-phones-and-usb-dacs-how-to-increase-the-issues-priority-with-google/135#post_8527516
. HeadStage USB DAC cable:
http://www.inearmatters.net/2010/04/short-review-headstage-usb-dac-cable.html
http://www.headphiles.org/index.php/topic,4452.msg241979.html#msg241979
. HiFiMan Express HM-101:
http://www.head-fi.org/t/571330/hifiman-express-brand-and-hm-101-portable-usb-dac
http://forum.xda-developers.com/showpost.php?p=27284184&postcount=291
. HiFimeDIY Sabre USB DAC using USB Audio Recorder PRO:
http://hifimediy.com/index.php?route=product/product&product_id=83
http://forum.xda-developers.com/showpost.php?p=36704343&postcount=75
. Hippo CriCri+ using USB Audio Recorder PRO (USB DAC/amp):
http://www.head-fi.org/t/626412/review-hippo-cricri-what-more-could-you-ask-from-this
http://forum.lowyat.net/index.php?showtopic=2222840&st=60&p=57358183&#entry57358183
http://www.ibasso.com/en/products/show.asp?ID=73
http://www.head-fi.org/t/571116/review-ibasso-d-zero-with-fiio-e7-comparison/30#post_8933882
. iBasso D2 Boa (USB DAC/amp):
http://www.ibasso.com/en/products/show.asp?ID=30
http://www.head-fi.org/t/552014/pictures-of-your-portable-rig-part-xv/5535#post_8509186
. iBasso D2+ Boa (USB DAC/amp):
http://www.ibasso.com/en/products/show.asp?ID=42
. iBasso D5 (USB DAC/amp):
http://www.head-fi.org/t/556490/ibasso-d5-hj-yet-another-usb-dac-amp
http://www.head-fi.org/t/614111/finally-digital-out-for-galaxy-siii#post_8462693
. iBasso D6 using USB Audio Recorder PRO (USB DAC/amp):
http://www.ibasso.com/en/products/show.asp?ID=69
http://www.head-fi.org/t/595071/android-phones-and-usb-dacs/1170#post_8980613
. iBasso D10 (USB DAC/amp):
http://www.ibasso.com/en/products/show.asp?ID=39
http://www.head-fi.org/t/628374/samsung-galaxy-s3-to-dac-usb-micro-b-male-to-mini-b-male#post_8735134
http://forum.xda-developers.com/showpost.php?p=29069294&postcount=924
. iBasso DB2 using USB Audio Recorder PRO:
http://www.ibasso.com/en/products/show.asp?ID=71
http://www.head-fi.org/t/595071/android-phones-and-usb-dacs/1035#post_8959039
. iQube v2 (USB DAC/amp):
http://www.i-qube.nl/index.php?id=24
http://forum.xda-developers.com/showpost.php?s=6fe26080d10769d0f785157c83e74465&p=31207282&postcount=1268
. JH Audio JH-3A (USB DSP/DAC/amp/JH16 CIEM):
http://www.jhaudio.com/product/jh-3a-dsp-amp-jh16-pro-custom-ear-monitor
http://www.head-fi.org/t/595071/android-phones-and-usb-dacs/585#post_8799910
. Jabra GN 5035 (USB headset):
http://reviews.cnet.com/headsets/jabra-gn5035-headset/4505-13831_7-32462996.html
http://forum.xda-developers.com/showpost.php?p=33203364&postcount=1368
. KingRex UD-01:
http://www.kingrex.co.uk/dac.html
https://www.facebook.com/headfonia/posts/352787358128700
. Leckerton UHA-4 (USB DAC/amp):
http://www.leckertonaudio.com/products/uha-4/
http://www.head-fi.org/t/536982/leckerton-audio-slimline-uha-4/1020#post_8773152
http://www.leckertonaudio.com/products/uha-6s-mkii/
http://www.head-fi.org/t/602493/new-leckerton-uha-6s-mkii-portable-headphone-amplifier-announced-update-user-impressions-added-july-20th-2012/435#post_8698006
. Logitech wíreless gaming headset G930 (USB wireless headset):
http://www.logitech.com/en-gb/product/7248?crid=721
http://www.head-fi.org/t/595071/android-phones-and-usb-dacs/1215#post_9004830
. M-Audio Duo USB Audio Interface:
http://www.soundonsound.com/sos/oct02/articles/maudio.asp
http://www.head-fi.org/t/595071/android-phones-and-usb-dacs/540#post_8788814
. Matrix Mini-i (USB DAC/amp):
http://www.headfonia.com/matrix-mini-i-balanced-dac/
http://www.head-fi.org/t/595071/android-phones-and-usb-dacs/465#post_8768166
. Meier Audio Cantate.2 (USB DAC/amp):
http://www.head-fi.org/products/meier-audio-corda-cantate-2
http://www.head-fi.org/t/595071/android-phones-and-usb-dacs/660#post_8820899
. Microsoft Philips Digital Sound System 80 (USB DAC/amp/speakers):
http://en.wikipedia.org/wiki/Digital_Sound_System_80
http://forum.xda-developers.com/showthread.php?t=1703218
[size=10pt]. Microsoft LifeChat LX-3000 (USB headset):[/size]
http://www.microsoft.com/hardware/en-au/p/lifechat-lx-3000/JUG-00003
http://forum.xda-developers.com/showpost.php?p=32899845&postcount=1355
http://www.head-fi.org/t/616889/myst-1866-bluetooth-optical-coaxial-usb-dac-headphone-amp-impressions-thread
http://www.head-fi.org/t/595071/android-phones-and-usb-dacs/795#post_8852573
. NuForce Icon HDP (USB DAC/amp):
http://www.nuforce.com/hp/products/iconhdp/index.php
. NuForce Icon Mobile (USB DAC/amp):
http://www.6moons.com/audioreviews/nuforce10/mobile.html
http://www.head-fi.org/t/595071/android-phones-and-usb-dacs/435#post_8759826
. NuForce Icon uDAC-2 (USB DAC/amp):
http://www.digitaltrends.com/headphone-amplifier-reviews/nuforce-icon-udac-2-review/
http://www.head-fi.org/t/628374/samsung-galaxy-s3-to-dac-usb-micro-b-male-to-mini-b-male/30#post_8939722
http://www.facebook.com/permalink.php?story_fbid=410941392302962&id=164588276945555
. Ordnance .25 (USB DAC/amp):
http://jaben.net/forums/index.php?topic=9984.0
http://www.raysamuelsaudio.com/products/intruder
http://www.head-fi.org/t/627080/new-balanced-portable-amp-from-rsa-w-dac/30#post_8781567
http://www.raysamuelsaudio.com/products/predator
http://www.head-fi.org/t/595071/android-phones-and-usb-dacs/150#post_8538933
http://www.head-fi.org/t/624676/sony-pha-1-portable-dac-amp
http://www.head-fi.org/t/645086/samsung-galaxy-s3-and-hd598s#post_9033830
http://stoneracoustics.blogspot.fr/
http://forum.lowyat.net/index.php?showtopic=2452730&st=160&p=54596977&#entry54596977
. Syba SD-AUD20101:
http://www.sybausa.com/productInfo.php?iid=1191
http://www.head-fi.org/t/595071/android-phones-and-usb-dacs/375#post_8736082
. Topping D1 Mark 2 (USB DAC/amp):
http://forum.xda-developers.com/showpost.php?p=28673076&postcount=871
. Topping D2 (USB DAC/amp):
http://www.mightybigword.com/tnt/2012/03/topping-d2-dac-review/
http://forum.xda-developers.com/showpost.php?p=32920194&postcount=1357
. Topping TP30 (USB DAC/amp):
http://news.cnet.com/8300-5_3-0.html?keyword=Topping+TP-30
http://www.androidnz.net/2012/05/samsung-galaxy-s-iii-usb-audio.html
. Turtle Beach Audio Advantage Micro II:
http://linkai8424.blogspot.fr/2011/03/turtle-beach-audio-advantage-micro-ii.html
http://www.head-fi.org/t/595071/android-phones-and-usb-dacs/1155#post_8978516
. Unique Melody PP6 using USB Audio Recorder PRO (USB DSP/DAC/amp/CIEM):
http://www.custom-iem.com/um-platform-pure-pp6-p-670.html
http://www.head-fi.org/t/613417/unique-melody-platform-pure-6-pp6-discussion-appreciation-tour-thread/360#post_8965862
http://venturecraft.jp/gadget_en/gdx.php
http://www.head-fi.org/t/595071/android-phones-and-usb-dacs/315#post_8708233
http://www.xduoo.com/xduoo/ProductShow.asp?ID=47
http://www.erji.net/read.php?tid=1320392&fpage=0&toread=&page=1
Bold: new addition to the list
Jan 25, 2013 at 4:40 AM Post #1,499 of 9,526
Tasker (app) should be able to do that.
Jan 25, 2013 at 10:12 AM Post #1,500 of 9,526
Unfortunately my S1 is now out of action for a few months until I get the screen fixed :(
I still have the Xperia phone and intend on trying it out on my E17 when the cable arrives.
However I wanted to ask a question kind of related but Not quite lol.
Blackberry Playbook 64gb. Whats the score with this RIM based tablet folks?
Anything I can do with it or am I just stuck with headphone out on the tablet?
