Android phones and USB DACs
Jan 14, 2013 at 6:26 PM Post #1,366 of 9,526
The Spotify app can’t use the USB audio function which is included in the USB Audio Recorder PRO app.
Like a modified Neutron Music Player, a modified Spotify app interfacing with the upcoming USB audio service developed by eXtream Software Development could output a digital audio stream to a FiiO E17 USB DAC/amp:
"If some generalized audio output API is provided by developer of USB Audio Recorder Pro then it would be great and Neutron would support it as one of additional output drivers. In the future it also worth trying to develop own USB soft-driver too."
http://www.head-fi.org/t/595071/android-phones-and-usb-dacs/1305#post_9034501
Thanks for the quick response. The information you compiled in this thread is really helpful. Guess I'll have to get a stoner acoustic UD100 soon cuz the DAC in US version gs3 really sucks coming from iphone 4s, and there is still no word on the release date for fiio e18 or e19. gs4 is half a year away...
Jan 15, 2013 at 2:57 AM Post #1,368 of 9,526
As far as I understand, another app like Neutron Music Player using the USB Audio Android Service provided by eXtream Software Development is the player.
This USB Audio Android Service should run in the background.
"A Service is a component which runs in the background, without interacting with the user. Every developer can create new Services in his application.
You can declare your own Service to perform long running operations without user interaction or to supply functionality to other applications."
http://www.vogella.com/articles/AndroidServices/article.html
Jan 15, 2013 at 3:02 PM Post #1,369 of 9,526
Different USB audio solutions::
USB audio-enabled Android device: Samsung Galaxy S III, Samsung Galaxy Note II, Samsung Galaxy Note 10.1, Archos G9
USB host-enabled Android device: Samsung Galaxy S III, Samsung Galaxy Note II, Samsung Galaxy Note 10.1, Archos G9, Acer Iconia Tab A200, Acer Iconia Tab A500, Asus Transformer Pad TF300, Asus Transformer Pad Infinity TF700, Asus Transformer Prime, Google Galaxy Nexus, Google Nexus 7, Google Nexus 10, Huawei Ascend D1 Quad XL, Huawei MediaPad, Meizu MX Quad-Core, Motorola Razr Maxx HD, Motorola Xoom, Samsung Galaxy Camera EK-G100, Samsung Galaxy R, Samsung Galaxy Tab 2 7.0, Samsung Galaxy Tab 7.7, Samsung Galaxy Tab 10.1, Sony Xperia S, Sony Xperia Sola, Sony Xperia Tablet S, Toshiba Thrive, Wiko Cink King
Jan 16, 2013 at 4:38 AM Post #1,370 of 9,526
Heya fellow headfiers,
 I have been following this thread from a very early stage, and i really have to appreciate what Danba has made possible for us here. I have a question from you, with the amount of Dac's/Amp's said to be working with the GSIII (in particular) and other android devices it has gotten a bit confusing for me as to which Dac/Amp to purchase for my GSIII and atrios MG7's, I might get the HE 400 in a month or so. I like the Ibasso's but its huge selection , and the Fiio E17(iv heard it sounds good with the HE 400). What would you suggest a good dac/amp is under 200$ with more emphasis on the Dac aspect and where to get a usb OTG cable for it? Thank you.
Regards,
Jan 16, 2013 at 7:50 AM Post #1,371 of 9,526
I've tried searching this thread but couldn't find the info on the following but would it be correct that for the Galaxy S3 if :-
1) non-OTG cable is used with something like the VentureCraft Go-DAP X, it's USB Audio-enabled Android mode
   - the VentureCraft Go-DAP X won't be draining or siphoning the battery off the Galaxy S3
2) OTG cable is used then it's USB Host-enabled Android mode
   - the USB DAC/Amp will be draining or siphoning the battery off the Galaxy S3?
Apologies if this is a silly question.
Jan 16, 2013 at 8:39 AM Post #1,372 of 9,526
Regards,
Hey there.
I can recommend the iBasso D-zero (109$) as I've done previously in this thread. That is if you want a dac/amp for portable use. The D-zero comes with a short OTG cable (even though this isn't listed on their site) as well with a short 3.5mm male to male cable, and of course the normal usb to mini usb for charging/using via a computer.
The D-zero is one of (if not the) smallest usb/dac combos out there. It packs a lot of punch for its size and you won't be disappointed with the sound.
Review with FiiO E7 comparison(not by me): http://www.head-fi.org/t/571116/review-ibasso-d-zero-with-fiio-e7-comparison
iBasso's site: http://www.ibasso.com/en/products/show.asp?ID=73
Jan 16, 2013 at 8:43 AM Post #1,373 of 9,526
I spoke to eXtream Software Development they and the dev of Neutron Player, are looking into this. They are looking to see how feasible it is to implement reliably.
Thats all for now though.
Jan 16, 2013 at 8:56 AM Post #1,374 of 9,526
According to wikipedia, is impossible to have a micro b to mini b usb cable.
Have a look:
http://en.wikipedia.org/wiki/Universal_Serial_Bus#Mini_and_Micro_connectors
Jan 16, 2013 at 1:24 PM Post #1,375 of 9,526
I am currently using Fiio E17 with mi SGS3 and it has an option to "disable" usb charging .... this is useful to avoid battery draining from SGS3 ! I don't know about the other dac/amp if they can do like this !
good luck
Jan 16, 2013 at 2:33 PM Post #1,376 of 9,526
good luck
The Leckerton MK2 can do this as well, and works with the SGS3
Jan 16, 2013 at 3:22 PM Post #1,377 of 9,526
Jan 17, 2013 at 3:25 AM Post #1,378 of 9,526
A list of stock Android-powered devices reportedly interworking with standard USB DAC:
stock Android device > digital USB audio out >> USB OTG cable >> standard USB DAC >> amp >> headphones
. Acer Iconia Tab A200 using USB Audio Recorder PRO (tablet):
http://www.engadget.com/2012/03/15/acer-iconia-tab-a200-review/
http://www.extreamsd.com/USBAudioRecorderPRO/
. Acer Iconia Tab A500 using USB Audio Recorder PRO (tablet):
http://www.engadget.com/2011/04/26/acer-iconia-tab-a500-review/
. Archos G9 (tablet):
http://www.anandtech.com/show/5802/the-archos-g9-tablet-reviews-fast-enough
http://forum.xda-developers.com/showthread.php?t=1539576
. Asus Transformer Pad TF300 using USB Audio Recorder PRO (tablet):
http://www.engadget.com/2012/04/22/asus-transformer-pad-tf300-review/
. Asus Transformer Pad Infinity TF700 using USB Audio Recorder PRO (tablet):
http://www.engadget.com/2012/06/25/asus-transformer-pad-infinity-tf700-review/
. Asus Transformer Prime using USB Audio Recorder PRO (tablet):
http://www.engadget.com/2011/12/01/asus-eee-pad-transformer-prime-review/
. Google Galaxy Nexus using USB Audio Recorder PRO (smartphone):
http://www.theverge.com/products/galaxy-nexus-gsm/2946
http://forum.xda-developers.com/showpost.php?p=35484769&postcount=52
. Google Nexus 7 using USB Audio Recorder PRO (tablet):
http://www.engadget.com/2012/06/28/nexus-7-review/
. Google Nexus 10 using USB Audio Recorder PRO (tablet):
http://www.engadget.com/2012/11/02/nexus-10-review/
http://www.head-fi.org/t/595071/android-phones-and-usb-dacs/1110#post_8973836
. Huawei Ascend D1 Quad XL using USB Audio Recorder PRO (smartphone):
http://www.engadget.com/2012/10/20/huawei-ascend-d1-quad-xl-review/
http://www.head-fi.org/t/628254/fiio-e18/15#post_8988466
. Huawei MediaPad using USB Audio Recorder PRO (tablet):
http://www.androidnz.net/2012/09/rapid-review-huawei-mediapadt-mobile.html
. Meizu MX Quad-Core using USB Audio Recorder PRO (smartphone):
http://www.xda-developers.com/android/meizu-mx-quad-core-review/
. Motorola Razr Maxx HD using USB Audio Recorder PRO (smartphone):
http://www.engadget.com/2012/10/19/droid-razr-hd-and-razr-maxx-hd-review/
. Motorola Xoom using USB Audio Recorder PRO (tablet):
http://www.engadget.com/2011/02/23/motorola-xoom-review/
. Samsung Galaxy Camera EK-G100 using USB Audio Recorder PRO (camera):
http://www.digitaltrends.com/digital-camera-reviews/samsung-galaxy-camera-ek-gc100-review/
. Samsung Galaxy Note II (smartphone):
http://www.engadget.com/2012/10/08/samsung-galaxy-note-ii-review/
. Samsung Galaxy Note 10.1 (tablet):
http://phandroid.com/samsung-galaxy-note-10-1/
http://www.head-fi.org/t/595071/android-phones-and-usb-dacs/645#post_8814831
. Samsung Galaxy R using USB Audio Recorder PRO (smartphone):
http://www.engadget.com/2011/08/10/samsung-galaxy-r-officially-announced-for-europe-and-asia-nobod/
. Samsung Galaxy S III (smartphone):
http://www.theverge.com/2012/5/25/3042640/samsung-galaxy-s-iii-review
. Samsung Galaxy Tab 2 7.0 using USB Audio Recorder PRO (tablet):
http://www.engadget.com/2012/04/11/samsung-galaxy-tab-2-7-0-review/
. Samsung Galaxy Tab 7.7 using USB Audio Recorder PRO (tablet):
http://www.engadget.com/2012/02/07/samsung-galaxy-tab-7-7-review-international-edition/
. Samsung Galaxy Tab 10.1 using USB Audio Recorder PRO (tablet):
http://www.engadget.com/2012/05/15/samsung-galaxy-tab-2-10-1-review/
. Sony Xperia S using USB Audio Recorder PRO (smartphone):
http://www.engadget.com/2012/03/08/sony-xperia-s-review/
. Sony Xperia Sola using USB Audio Recorder PRO (smartphone):
http://www.androidcentral.com/device/sony-xperia-sola
. Sony Xperia Tablet S using USB Audio Recorder PRO (tablet):
http://www.engadget.com/2012/09/24/sony-xperia-tablet-s-review/
. Toshiba Thrive using USB Audio Recorder PRO (tablet):
http://www.engadget.com/2011/07/22/toshiba-thrive-review/
. Wiko Cink King using USB Audio Recorder PRO (smartphone):
http://www.wikomobile.com/telephone-portable-Cink-king.php
A list of standard USB DAC reportedly interworking with the Android-powered smartphone Samsung Galaxy Note II:
stock Galaxy Note II > digital USB audio out >> USB OTG cable (micro-A plug inserted in the Note II) >> standard USB DAC >> amp >> headphones
. Apex Glacier (USB DAC/amp):
http://www.head-fi.org/t/632019/apex-glacier-amp-dac-review-and-appreciation-thread
http://www.head-fi.org/t/632019/apex-glacier-amp-dac-review-and-appreciation-thread/165#post_8924724
. Asus Xonar U3 (USB DAC/amp):
http://www.overclockersclub.com/reviews/asus_xonar_u3/
http://www.head-fi.org/t/595071/android-phones-and-usb-dacs/1200#post_8997468
. Audio-gd NFB-16 (USB DAC/amp):
http://www.audio-gd.com/Pro/Headphoneamp/NFB16/NFB16EN.htm
http://www.head-fi.org/t/625054/samsung-galaxy-note-2/120#post_8943120
. AudioQuest DragonFly using USB Audio Recorder PRO:
http://www.head-fi.org/t/617241/audioquest-dragonfly-review-affordable-outstanding-tiny-dac-amp
http://www.head-fi.org/t/595071/android-phones-and-usb-dacs/1035#post_8959237
. CEntrance DACport LX using USB Audio Recorder PRO:
http://www.headfonia.com/cheaper-better-the-centrance-dacport-lx/
http://www.head-fi.org/t/595071/android-phones-and-usb-dacs/1065#post_8968468
. ELE EL-D01:
http://www.cnfeature.com/goods.php?id=1299
http://www.head-fi.org/t/643883/portable-amp-for-galaxy-note-2-and-grado-sr80i-heaphones#post_9012249
. FiiO E07K Andes (USB DAC/amp): to be confirmed
http://www.headphiles.org/index.php?t=msg&goto=253249&
http://www.head-fi.org/t/638910/new-fiio-e07k-andes-information-and-impressions/15#post_8924515
http://www.head-fi.org/t/628254/fiio-e18/15#post_8973799
. Focal XS 2.1 (USB speakers):
http://reviews.cnet.com/speakers-speaker-systems/focal-xs-speakers-with/4505-6467_7-33618064.html
http://www.homecinema-fr.com/forum/multimedia-materiels-tablettes-et-smartphones/samsung-galaxy-note-ii-2-go-16-go-android-4-1-2-t30029275.html#p177362999
. GoVibe Magnum (USB DAC/amp):
http://www.head-fi.org/t/324577/review-govibe-magnum-usb-dac-amp
http://www.head-fi.org/t/633201/confirmed-list-of-usb-dacs-for-the-galaxy-s3-international-us-or-note-2#post_8809248
. GoVibe Martini-U (USB DAC/amp):
http://jaben-bandung.com/index.php?route=product/product&product_id=196
http://www.head-fi.org/t/595071/android-phones-and-usb-dacs/990#post_8942287
. GoVibe Vulcan (USB DAC/amp):
http://www.head-fi.org/t/386127/go-vibe-vulcan
http://www.head-fi.org/t/595071/android-phones-and-usb-dacs/960#post_8929084
. HRT HeadStreamer Mobile (USB DAC/amp):
http://highresolutiontechnologies.com/headstreamer-mobile
http://www.computeraudiophile.com/f6-dac-digital-analog-conversion/power-galaxy-note-2-while-using-usb-dac-how-please-14029/
. HeadAmp Pico USB DAC/Amp: bug fixed by HeadAmp
http://www.headfonia.com/headamp-pico/
http://www.head-fi.org/t/595071/android-phones-and-usb-dacs/1305#post_9037872
. HeadAmp Pico Upsampling USB DAC:
http://www.head-fi.org/t/413230/headamp-pico-upsampling-usb-dac-pre-order-now-at-intro-price
. Headstage Lyrix Pro USB total (USB DAC/amp):
http://www.headphonia.com/Amps/Headstage-Lyrix-Pro-USB-total::10071.html
http://www.head-fi.org/t/595071/android-phones-and-usb-dacs/795#post_8854850
. iBasso D-Zero (USB DAC/amp):
http://www.headfonia.com/fiio-e7-meet-your-rival-the-ibasso-d-zero/
. iBasso D12 (USB DAC/amp):
http://www.ibasso.com/en/products/show.asp?ID=63
http://www.head-fi.org/t/595071/android-phones-and-usb-dacs/405#post_8750862
. Leckerton UHA-6S MKII (USB DAC/amp):
http://www.innerfidelity.com/content/leckerton-uha-6s-mkii-portable-headphone-amplifier
http://www.head-fi.org/t/625054/samsung-galaxy-note-2/30#post_8777791
. MyST 1866 PortaDAC (USB DAC/amp):
http://www.musicaacoustics.com/wp/amplifiers/myst-1866/
http://player.ru/showthread.php?t=74459&page=34&p=1084707&viewfull=1#post1084707
. Objective DAC (ODAC):
http://epiphany-acoustics.co.uk/our-products/e-dac-24bit-miniature-usb-dac/
http://www.jdslabs.com/item.php?fetchitem=46
http://www.headnhifi.com/index.php/shop/objective/odac
http://www.head-fi.org/t/595071/android-phones-and-usb-dacs/435#post_8758515
. ODAC+O2 (USB DAC/amp):
http://epiphany-acoustics.co.uk/our-products/ehp-o2d-miniature-desktop-headphone-amplifier-with-usb-dac/
http://www.jdslabs.com/item.php?fetchitem=48
http://www.headnhifi.com/index.php/shop/objective/o2120527192048
. RSA Intruder (USB DAC/amp):
http://www.innerfidelity.com/content/canjam-rmaf-2012-ray-samuels-audio-intruder-balanced-portable-headphone-amp-and-dac
http://www.head-fi.org/t/595071/android-phones-and-usb-dacs/660#post_8819856
. RSA Predator (USB DAC/amp):
http://www.6moons.com/audioreviews/predator/predator_2.html
http://www.head-fi.org/t/625054/samsung-galaxy-note-2/120#post_8960049
. Sony PHA-1 (USB DAC/amp):
http://www.touchmyapps.com/2012/10/09/sony-pha-1-idevice-dac-and-headphone-amp-in-review/
http://www.head-fi.org/t/595071/android-phones-and-usb-dacs/465#post_8769593
. Stoner Acoustics UD100:
http://www.head-fi.org/t/626632/tiny-dac-big-sound-impression-of-stoner-acoustics-ud100-vs-odac
http://forum.lowyat.net/index.php?showtopic=2449848&st=220&p=56352256&#entry56352256
. VentureCraft Go-Dap X (USB DAC/amp): USB cable provided by VentureCraft
http://www.head-fi.org/t/609906/new-venturecraft-go-dap-x-for-both-idevices-and-pcs
. xDuoo XP-1 (USB DAC/amp):
http://www.jaben.com.hk/ProductView.asp?ID=776&SortID=358
http://www.head-fi.org/t/642504/xduoo-new-company-making-interesting-portable-dac-and-amp-units
. Zoom H4 using USB Audio Recorder PRO (USB recorder):
http://en.wikipedia.org/wiki/Zoom_H4_Handy_Recorder
http://forum.xda-developers.com/showpost.php?p=35472432&postcount=23
So far, like the quad-core Exynos powered Galaxy S III, the new quad-core Exynos powered Samsung Galaxy Note II can work with the FiiO E7, the iBasso D12, Leckerton UHA-6S MKII, the ODAC, … ; had some issue with the HeadAmp Pico (bug fixed by HeadAmp); and doesn’t work with the FiiO E17 using the stock USB audio driver.
So, in regard to the USB protocol, the behaviour of the Galaxy Note II is likely identical to the behaviour of the Galaxy S III.
A list of standard USB DAC reportedly interworking with the Android-powered smartphone Samsung Galaxy S III:
stock Samsung Galaxy S III > digital USB audio out >> USB OTG cable (micro-A plug inserted in the S III) >> standard USB DAC >> amp >> headphones
. AMB Gamma 1:
http://www.amb.org/audio/gamma1/
http://www.head-fi.org/t/608535/wolfson-dac-confirmed-for-galaxy-s3/780#post_8750043
. AMB Gamma 2:
http://www.amb.org/audio/gamma2/
http://forum.xda-developers.com/showpost.php?p=27247705&postcount=279
http://www.ttvjaudio.com/Apex_High_Fi_Audio_Glacier_portable_headphone_amp_p/aaa0000010.htm
http://www.head-fi.org/t/608535/wolfson-dac-confirmed-for-galaxy-s3/825#post_8776449
http://www.asus.com/Multimedia/Audio_Cards/Xonar_U3/
http://mybroadband.co.za/vb/showthread.php/429589-Samsung-Galaxy-S3?s=1a313fae4795a9a7493a6ce0f677ca8e&p=8551119&viewfull=1#post8551119
. Atoll DAC 100:
http://www.6moons.com/audioreviews/atoll2/atoll.html
http://forum.xda-developers.com/showpost.php?p=35266076&postcount=17
. Audio-gd Sparrow Version A  (USB DAC/amp):
http://www.audio-gd.com/Pro/Headphoneamp/Sparrow/SparrowEN.htm
http://www.head-fi.org/t/595071/android-phones-and-usb-dacs/915#post_8907415
. Behringer UCA202 (USB DAC/amp):
http://www.behringer.com/EN/Products/UCA202.aspx
http://www.head-fi.org/t/595071/android-phones-and-usb-dacs/240#post_8654226
. Behringer UCA222 (USB DAC/amp):
http://www.behringer.com/en/Products/UCA222.aspx
http://www.computeraudiophile.com/f6-dac-digital-analog-conversion/usb-audio-enabled-android-powered-samsung-galaxy-s-iii-12338/#post171651
. Beresford Caiman:
http://www.techradar.com/reviews/audio-visual/hi-fi-and-audio/hi-fi-accessories/beresford-caiman-673787/review
. C-Media chipset-based sound card Dynamode 7 channel USB 2.0 (USB DAC/amp):
http://soundplayer.systempebisnisonline.com/speaker/dynamode-7-channel-usb-2-0-sound-card/
http://forum.xda-developers.com/showpost.php?p=27604946&postcount=449
. Cakewalk Sonar SPS 25:
https://www.cakewalk.com/support/kb/reader.aspx/2007013101
. Cambridge Audio DacMagic:
http://www.headfonia.com/cambridge-dacmagic-review/
http://www.head-fi.org/t/631855/galaxy-s3-and-ca-dacmagic-plus#post_8899779
. CEntrance DacMini using USB Audio Recorder PRO (USB DAC/amp):
http://centrance.com/products/dacmini/
http://www.head-fi.org/t/595071/android-phones-and-usb-dacs/1200#post_8998731
. Corsair HS1 Gaming headset (USB DAC/amp/headphones):
http://www.anandtech.com/show/3989/corsair-hs1-gaming-headset
http://forum.xda-developers.com/showthread.php?p=27238117#post27238117
. Creative Xmod:
http://reviews.cnet.com/external-audio-adapters/creative-xmod/4505-9335_7-32105686.html
http://www.forum-audiophile.fr/musique-demat/fonction-usb-audio-a-activer-dans-android-t24441-60.html#p336853
. Dared MP 5 or ALO JV5 (USB DAC/amp):
http://www.positive-feedback.com/Issue24/dared_mp5.htm
http://www.head-fi.org/t/595071/android-phones-and-usb-dacs/990#post_8948190
. ELE EL-D01:
http://www.head-fi.org/t/586909/the-discovery-thread-new-dannybs-first-take-ath-ckn50-pg383-ele-hi-fi-usb-18-dac-pg-328/4905#post_8886336
http://www.head-fi.org/t/642554/fiio-e7-galaxy-s3-questions-for-car-audio/15#post_8991125
. FiiO E7 (USB DAC/amp):
http://www.headfonia.com/fiio-e7-portable-dac/
http://www.androidnz.net/2012/07/galaxy-s-iii-real-user-review-part-2.html
http://headfonics.com/2012/12/fiio-e07k-the-andes/
. FiiO E17 using USB Audio Recorder PRO (USB DAC/amp):
http://www.headfonia.com/the-upgrade-fiio-e17-alpen/
http://www.head-fi.org/t/595071/android-phones-and-usb-dacs/1020#post_8958018
. Furutech ADL Cruise (USB DAC/amp):
http://www.furutech.com/a2008/product2.asp?prodNo=399
http://www.head-fi.org/t/608535/wolfson-dac-confirmed-for-galaxy-s3/585#post_8567838
. GoVibe DAC:
http://jaben.net/forums/index.php?topic=2824.0
http://forum.lowyat.net/index.php?showtopic=2440879&st=500&p=53317360&#entry53317360
. GoVibe Mini USB DAC:
http://www.jaben.com.au/collections/go-vibe/products/govibe-minidac
http://www.head-fi.org/t/614111/finally-digital-out-for-galaxy-siii/15#post_8525675
. GoVibe Petite (USB DAC/amp):
http://www.head-fi.org/t/290711/govibe-petite-dac-amp-appreciation-thread-pics-little-update
http://www.head-fi.org/t/595071/android-phones-and-usb-dacs-how-to-increase-the-issues-priority-with-google/195#post_8552452
. HRT HeadStreamer (USB DAC/amp):
http://www.headfonia.com/hrt-headstreamer-review/
http://www.head-fi.org/t/608535/wolfson-dac-confirmed-for-galaxy-s3/750#post_8677483
. HRT Music Streamer II:
http://highresolutiontechnologies.com/music-streamer-ii
http://www.head-fi.org/t/608535/wolfson-dac-confirmed-for-galaxy-s3/465#post_8534856
http://www.head-fi.org/t/258967/headamp-pico-portable-amp-w-optional-upsampling-24-96-usb-dac-pre-order-thread
http://www.head-fi.org/t/632019/apex-glacier-amp-dac-review-and-appreciation-thread/270#post_9036297
http://www.headamp.com/pico/pico_usb_dac/index.htm
. HeadRoom Total BitHead (USB DAC/amp):
http://www.headphone.com/learning-center/bithead-faq.php
http://www.head-fi.org/t/595071/android-phones-and-usb-dacs-how-to-increase-the-issues-priority-with-google/135#post_8527516
. HeadStage USB DAC cable:
http://www.inearmatters.net/2010/04/short-review-headstage-usb-dac-cable.html
http://www.headphiles.org/index.php/topic,4452.msg241979.html#msg241979
. HiFiMan Express HM-101:
http://www.head-fi.org/t/571330/hifiman-express-brand-and-hm-101-portable-usb-dac
http://forum.xda-developers.com/showpost.php?p=27284184&postcount=291
. HiFimeDIY Sabre USB DAC using USB Audio Recorder PRO:
http://hifimediy.com/index.php?route=product/product&product_id=83
http://forum.xda-developers.com/showpost.php?p=36704343&postcount=75
http://www.head-fi.org/t/571116/review-ibasso-d-zero-with-fiio-e7-comparison/30#post_8933882
. iBasso D2 Boa (USB DAC/amp):
http://www.ibasso.com/en/products/show.asp?ID=30
http://www.head-fi.org/t/552014/pictures-of-your-portable-rig-part-xv/5535#post_8509186
. iBasso D2+ Boa (USB DAC/amp):
http://www.ibasso.com/en/products/show.asp?ID=42
. iBasso D5 (USB DAC/amp):
http://www.head-fi.org/t/556490/ibasso-d5-hj-yet-another-usb-dac-amp
http://www.head-fi.org/t/614111/finally-digital-out-for-galaxy-siii#post_8462693
. iBasso D6 using USB Audio Recorder PRO (USB DAC/amp):
http://www.ibasso.com/en/products/show.asp?ID=69
http://www.head-fi.org/t/595071/android-phones-and-usb-dacs/1170#post_8980613
. iBasso D10 (USB DAC/amp):
http://www.ibasso.com/en/products/show.asp?ID=39
http://www.head-fi.org/t/628374/samsung-galaxy-s3-to-dac-usb-micro-b-male-to-mini-b-male#post_8735134
http://forum.xda-developers.com/showpost.php?p=29069294&postcount=924
. iBasso DB2 using USB Audio Recorder PRO:
http://www.ibasso.com/en/products/show.asp?ID=71
http://www.head-fi.org/t/595071/android-phones-and-usb-dacs/1035#post_8959039
. iQube v2 (USB DAC/amp):
http://www.i-qube.nl/index.php?id=24
http://forum.xda-developers.com/showpost.php?s=6fe26080d10769d0f785157c83e74465&p=31207282&postcount=1268
. JH Audio JH-3A (USB DSP/DAC/amp/JH16 CIEM):
http://www.jhaudio.com/product/jh-3a-dsp-amp-jh16-pro-custom-ear-monitor
http://www.head-fi.org/t/595071/android-phones-and-usb-dacs/585#post_8799910
. Jabra GN 5035 (USB headset):
http://reviews.cnet.com/headsets/jabra-gn5035-headset/4505-13831_7-32462996.html
http://forum.xda-developers.com/showpost.php?p=33203364&postcount=1368
. KingRex UD-01:
http://www.kingrex.co.uk/dac.html
https://www.facebook.com/headfonia/posts/352787358128700
. Leckerton UHA-4 (USB DAC/amp):
http://www.leckertonaudio.com/products/uha-4/
http://www.head-fi.org/t/536982/leckerton-audio-slimline-uha-4/1020#post_8773152
http://www.leckertonaudio.com/products/uha-6s-mkii/
http://www.head-fi.org/t/602493/new-leckerton-uha-6s-mkii-portable-headphone-amplifier-announced-update-user-impressions-added-july-20th-2012/435#post_8698006
. Logitech wíreless gaming headset G930 (USB wireless headset):
http://www.logitech.com/en-gb/product/7248?crid=721
http://www.head-fi.org/t/595071/android-phones-and-usb-dacs/1215#post_9004830
. M-Audio Duo USB Audio Interface:
http://www.soundonsound.com/sos/oct02/articles/maudio.asp
http://www.head-fi.org/t/595071/android-phones-and-usb-dacs/540#post_8788814
. Matrix Mini-i (USB DAC/amp):
http://www.headfonia.com/matrix-mini-i-balanced-dac/
http://www.head-fi.org/t/595071/android-phones-and-usb-dacs/465#post_8768166
. Meier Audio Cantate.2 (USB DAC/amp):
http://www.head-fi.org/products/meier-audio-corda-cantate-2
http://www.head-fi.org/t/595071/android-phones-and-usb-dacs/660#post_8820899
. Microsoft Philips Digital Sound System 80 (USB DAC/amp/speakers):
http://en.wikipedia.org/wiki/Digital_Sound_System_80
http://forum.xda-developers.com/showthread.php?t=1703218
[size=10pt]. Microsoft LifeChat LX-3000 (USB headset):[/size]
http://www.microsoft.com/hardware/en-au/p/lifechat-lx-3000/JUG-00003
http://forum.xda-developers.com/showpost.php?p=32899845&postcount=1355
http://www.head-fi.org/t/616889/myst-1866-bluetooth-optical-coaxial-usb-dac-headphone-amp-impressions-thread
http://www.head-fi.org/t/595071/android-phones-and-usb-dacs/795#post_8852573
. NuForce Icon HDP (USB DAC/amp):
http://www.nuforce.com/hp/products/iconhdp/index.php
. NuForce Icon Mobile (USB DAC/amp):
http://www.6moons.com/audioreviews/nuforce10/mobile.html
http://www.head-fi.org/t/595071/android-phones-and-usb-dacs/435#post_8759826
. NuForce Icon uDAC-2 (USB DAC/amp):
http://www.digitaltrends.com/headphone-amplifier-reviews/nuforce-icon-udac-2-review/
http://www.head-fi.org/t/595071/android-phones-and-usb-dacs/315#post_8707637
http://www.facebook.com/permalink.php?story_fbid=410941392302962&id=164588276945555
. Ordnance .25 (USB DAC/amp):
http://jaben.net/forums/index.php?topic=9984.0
http://www.raysamuelsaudio.com/products/intruder
http://www.head-fi.org/t/627080/new-balanced-portable-amp-from-rsa-w-dac/30#post_8781567
http://www.raysamuelsaudio.com/products/predator
http://www.head-fi.org/t/595071/android-phones-and-usb-dacs/150#post_8538933
http://www.head-fi.org/t/624676/sony-pha-1-portable-dac-amp
http://www.head-fi.org/t/645086/samsung-galaxy-s3-and-hd598s#post_9033830
http://stoneracoustics.blogspot.fr/
http://forum.lowyat.net/index.php?showtopic=2452730&st=160&p=54596977&#entry54596977
. Syba SD-AUD20101:
http://www.sybausa.com/productInfo.php?iid=1191
http://www.head-fi.org/t/595071/android-phones-and-usb-dacs/375#post_8736082
. Topping D1 Mark 2 (USB DAC/amp):
http://www.head-fi.org/t/636606/topping-d1-mark-2-review
http://forum.xda-developers.com/showpost.php?p=28673076&postcount=871
. Topping D2 (USB DAC/amp):
http://www.mightybigword.com/tnt/2012/03/topping-d2-dac-review/
http://forum.xda-developers.com/showpost.php?p=32920194&postcount=1357
. Topping TP30 (USB DAC/amp):
http://news.cnet.com/8300-5_3-0.html?keyword=Topping+TP-30
http://www.androidnz.net/2012/05/samsung-galaxy-s-iii-usb-audio.html
. Turtle Beach Audio Advantage Micro II:
http://linkai8424.blogspot.fr/2011/03/turtle-beach-audio-advantage-micro-ii.html
http://www.head-fi.org/t/595071/android-phones-and-usb-dacs/1155#post_8978516
. Unique Melody PP6 using USB Audio Recorder PRO (USB DSP/DAC/amp/CIEM):
http://www.custom-iem.com/um-platform-pure-pp6-p-670.html
http://www.head-fi.org/t/613417/unique-melody-platform-pure-6-pp6-discussion-appreciation-tour-thread/360#post_8965862
http://venturecraft.jp/gadget_en/gdx.php
http://www.head-fi.org/t/595071/android-phones-and-usb-dacs/315#post_8708233
http://www.xduoo.com/xduoo/ProductShow.asp?ID=47
http://www.erji.net/read.php?tid=1320392&fpage=0&toread=&page=1
Bold: new addition to the list
Jan 17, 2013 at 4:08 AM Post #1,379 of 9,526
If someone is able to give me a link where i can buy a cable micro b to mini a for the FiiOE07K i can test the Xperia J and some more.
I can't find it and
It's kinda like the 10th time i'm asking
