Greenfun13
Does anyone own the MDR-Z7M2? Curious if they're worth it or not, they do look pretty solid though.
I dont own the M2's but I am currently listening with my Z7s. In a nutshell, when I was doing my research on these I kept reading that the M2's are less bassy then the M1's which is why I ultimately pulled the trigger on the originals. When I got home from work today I started looking up Z7 mods and came across a few. The first I did was use surgical tape on the insides of the cups - I did not care for the new sound profile and quickly ripped off my 1+ hour of work cutting it all out/ carefully placing it. I then came across a VERY SIMPLE mod of placing a little piece of tape over a tiny little hole in the driver baffle that vents the cup into the ear pads. WOW. What a difference!
A few post ago I was complaining that I wasn't satisfied with these and wanted to find a pair of JVC SZ2000s to rattle my skull. NOT ANYMORE! These hit much lower and cleaner now. Still going to buy an amp/dac to complete my setup, but for the moment I am incredibly happy.
The quote from another member on a different forum:
" Yep, that's right. the bass distortion is entirely fixable. This is the bass a 70mm driver deserves. Quite a bit more extended than stock too. Not only that, but it's even a very simple fix. On the very outside of the back of the driver baffle there are two paper filters. One of these has a tiny vent hole that seemingly vents to underneath the pad. Cover that with a strip of tape and most of the bass distortion (especially the nasty D3) is gone. That hole is also why bass rolls off below 35Hz, so you also get more extension, which will probably be too much without any other mods. "
______________________________________________________
ALSO worth mentioning is that in my research today is that it gets compared to the Fostex TH-900.
Quote by @Whitigir: For the record, Z7 bass is much more addicting than th900 after mods on both. However they compliment each other very very well.
