TOP 10 for June 2014 (REV2)
* Using
70Hz "Hit" and a
* 35Hz "Hit"as comparative test. All listed cans compared with a Cowon DAP Settings= Flat 5 band Eq/BBE+10 Mach3Bass+8 e12 amp +16dB gain on. Bast boost switch on
1. JVC HA-SZ2000
Peerless sub bass and entire 18-120Hz response. Final option for chronic basshead.
Driver size: 55mm "Sub-woofer"/ 30mm CNT
Impedance:16 Ohm
Amp Headroom: Exceptional +30dB @45Hz
EQ: Needs
Genre' (anything)
Weakness: Sub>>Mid transition. , Poor stock pads.
2. JVC SZ1000
Nearly identical to Sz2000.
Only difference is force of bass at very high low end gain.
Highs seem clearer at low volume?
Impedance 16 Ohm
EQ: Needs
Genre' (anything)
3. JVC HA-MR77x
Hits very hard. Eats good amp.
Driver size: 57mm Mylar (PET)
Impedance 46 Ohm
Amp Headroom: Good/Great 16-20dB @45Hz
EQ: Needs (to raise mids)
Genre' (Hip-Hop)
Weakness: Echo/resonance over takes bass response before distortion.
4. Sony XB700
Epic bass. overwhelms signature. Can be amped well.
Driver size: 50mm Mylar (PET)
Impedance 24 Ohm
Amp Headroom: Good +18dB @45Hz
EQ: Needs
Genre' (Hip-Hop/EDM)
Weakness: Pillow pads absorb too much of the hit.
5. Sony XB1000
new on list
Driver size: 70mm Mylar (PET)
Impedance 24 Ohm
Amp Headroom:
(???) @45Hz
EQ: Needs
Genre' (HipHop/EDM/?)
Weakness: ...
(not enough info)
Source: iPod Touch with EQ set to bass boost, playing YouTube Wiz Khalifa's "On My Level" track
Amp: FiioE17 with bass EQ to max setting 10 and 6dB gain
6. Ultrasone Signature DJ
Impedance 32 Ohm
Amp Headroom: Great/Good +18 @45Hz
EQ: Needs (raise bass only)
Genre' (Anything)
Weakness ; Echo/resonance at high amped low end.
7. Monster/Beats by Dre Pro
(original Monster/Dre version)
Driver size: 40mm Mylar (PET)
Impedance 32 Ohm
Amp Headroom: Average +12 @45Hz
Genre' (Hip-Hop/EDM/?)
Weakness: Driver tuned to near limit. Amping gives only some boost.
8. HPH Yamaha Pro 500
Similar to Beats pro in "pre-tuned" driver.
Headroom with amp is low same as beats Pro. Hit hard as **** though
Impedance 32 Ohm
Amp Headroom: Average +12 @70Hz
Genre' (Anything)
Weakness: Driver tuned to near limit. Amping gives only some boost. Pad size (shallow)
9. Monster Npulse
Like the 77x hit way out of their price range and any range.
Headroom is slightly bigger than Yamaha and Beats Pro
Impedance 32 Ohm
Amp Headroom: Average +14 @45Hz
Genre' (Anything)
10. ATH - PRO 700MK2
Driver size: 53mm Mylar (PET)
Impedance 38 Ohm
EQ: Needs (raise bass only,?)
Weakness: Pad depth. Different pairs very different sound?
*ALL Cans tested with identical gear,settings and tracks.
Results based on that specific set-up.
No rec's of any cans made. No buying suggestions given.
Different equipment and settings will possibly/likely yield different results.
**These are numbered but not ranked. Besides #1 these are in no particular order
*** The next list will focus on "A" "B" comparisons with known branded headphones with pedigree. Potential candidates....claims...welcome. Suggestion box always open
Level of Hit
These cans cost 60-100 Bucks (the ones above 200-300)
Tracks used
A clipped version from 0:00 to 0:33 is used for impact (This is
tha crippler...it has ....shown the limit of so many cans I cannot count...many well known ones with nice price tags)
This track from 3:40 to finish (If they get past the crippler they can get stretched out by Wiz and Too $hort. It like shining the flashlight in the Sub-bass's face...cannot hide from this)
New test track 5/8/14
Using what?
A Portable rig designed to abuse the crap outta the low end of any can I can get my fingers on. Anywhere, anytime.
The exact same test tracks are used in the exact same way at the exact same levels. It's a "Go" or a "No Go"...simple as that.
Possible Q&A's
Q)
Who listens to headphones like this?
A) If you're wondering,.... probably not you.
Q)
Who are you?
A) I'm a former Car Audio IASCA dB drag competitor. I am pure-breed basshead. I'm used to measuring things. Words like "Cannon" mean nothing to me without some visual proof.
Low frequency audio signals will give you that visual. Charts, and words like
separation,
staging, are not of interest to me. A typical mastered Hip-Hop track is going to live along the "V" response anyway.
I live in Japan and have access to an enormous amount of headphones. I have a personality that allows me to behave in a way most would not. I take an "O.K." and go all the way with it. I do not damage cans but I could and some know that so my quest requires me to push the limits of acceptability and etiquette.
Q)
Why?
A) Because nobody else is. (simple answer). Also because it's fun. I'm a basshead. Finding sub $100 Head hammers or exposing supposed ones of much higher price is enjoyable.
There is room enough on Head-fi for everyone. I do my thing.
If Audiophile Bass and all kinds with a community is what you want this is the place>>
http://www.head-fi.org/t/715697/the-audiophile-bass-lounge-basshead-club-part-ii
There is also a GROUP. (I'm a member)>>>
http://www.head-fi.org/groups/show/34/the-audiophile-bass-lounge-group
Q)
Why are these not "Cannon's" on the Wiki?
A) Good question. These are the 10 hardest hitters that I have heard but they are not all cannons automatically. Some may be as that Wiki is updated as often as possible. Also many ....7 of 10 with the 77x ,American Audio, and XB700 being the exceptions...play most Genre
and can hammer. 70% of the list is not even Basshead. It's not what the cans do...it's what the cans
can do.
Potential.
(Revision 1.0)
- In an epic oversight
Never tested the 1Hz/1dB that separates the sz2000 and 1000. In Hip Hop with my test tracks it was nearly impossible to tell the difference. Maybe force of impact? Highs sounded clearer? Really odd?
In a focus to deliver the bass the brass sheath might be overwhelming the late mids /early highs by delivering the bass too well?
- Listened to the Denons. Urban Raver and the like including D2k and was ...as a basshead...most pleased with the AHD600. Not sure what to say but it was stout and strong and held up better than any other Denon
- The Senn DJ cans are nice.
(Revision 2.0)
- Added 70mm XB1000 It was a matter of time but I haven't seen them recently and cb just put up the vid.
- The Denon were on here for about a minute.
- Suggestions for test candidates always welcome
