Deoee
- Jan 21, 2017
What do you guys think of the Sennheiser HD8/7 DJ?
Yes, but if I buy th SZ1000, I could only buy a very cheap amp, for like
I can, but then I could only get a really cheap amp (like a FiiO K1) and I'm not sure that's a good deal. But I have 0 knowledge about amps to begin with.
I wasn't considering the COP, I was asking about it. Get it right.
If you don't mind a little wait until after chinese new years for the factories to reopen, you can grab a walnut for like $30usd shipped. 4.2w RMS amp in there is no slouch, but is more of a clean power boost than anything else, so whatever your source is, do you EQ all there and use the walnut to make it damn loud! I have been using my SZ1000 and SZ2000 with a lot more low power DAPs because with the help of an amp that powerful the SZs can rattle hard.
I don't know about the K1, no way it has that much power but the walnut lacks any sort of bass boost etc, so it really is just to boost the power. no bass boost switch or anything
I looked into the Pro 500's before I got the SZ2k's and if I remember correctly I read that the Brainwavz HM5 pads could be used on them. That would negate the large ear/comfort issue.
Do the hm5 fit properly or over the cup/?
I have put HM5s on my SZ's in the past and it felt like I was gonna rip the HM5 pads but they did fit on eventually.
I didn't realize how easy it was to swap the pads until I actually did it. I thought there was a trick to it (like there is with some headphones), but all you have to do is put a little bit of it in the groove, then keep twisting until it's all on.
(Though perhaps non-JVC pads might not be as easy.)
How close are ultrasone signature dj to top 10?
15... LOL.
Due to their use of S-Logic, most of the sound kind of "stays inside" the pads/cups. I could try working on a vid later... but I'm pretty sure I tried and failed miserably (although I DON'T push the EQ and amps as much as these guys here.)
Eh, I just impulse bought the SZ1000. A local JVC distributor was having a sale, they didn't even have the SZ2k on stock so I didn't have to make that decision. Gonna pick it up this week, then I'm getting myself some amp I can find.
Impulse buys represent 80% of sales around here
