Earbuds Round-Up
Nov 6, 2020 at 3:53 PM Post #50,206 of 75,209
What metal buds would you recommend that have the "concave arc"?
On this DIY Earbuds thread, you can find some of my DIY mods where I did shell analysis.
One of the more interesting models with MMCX is this and for the cable version, model from part 2
But you need to know that almost every custom shell needs some workaround to make it "perfect" :wink: and really worth every effort
Nov 6, 2020 at 7:41 PM Post #50,207 of 75,209
Oh wow, thank you so much for the links. I’ll look through the DIY mods now :)
Nov 7, 2020 at 2:10 AM Post #50,209 of 75,209
Tomahawk and Green are different. For me Green is better. Good build & very soft cable.
what do you mean by green, could you send me a link?
Nov 7, 2020 at 2:51 AM Post #50,211 of 75,209
Nov 7, 2020 at 2:52 AM Post #50,212 of 75,209
Del
Nov 7, 2020 at 10:38 AM Post #50,213 of 75,209
MX500 shell fits me well
OK, are they more like MX500 than Tonekings other buds?
I'm not really thinking about the part that you shove in to the ear, but more the depth of the buds. They potrude very much compared to most other buds. Don't they get kind of heavy and fall out or so? I guess that the hooks help with that, without them not so good I bet?
Nov 7, 2020 at 6:02 PM Post #50,214 of 75,209
Are Toneking TO400s still a good choice at the price of $55?
Can they face newer graphene earbuds at the same price bracket?
Nov 7, 2020 at 7:30 PM Post #50,215 of 75,209
I don't have the TO400s to compare but looking to spec. TO400s has a better extension on both ends and 10db higher sensitivity so easier to drive.
You have to take into account that it is tuned by Tonekng. For $53 this is nice.
Maybe it's better to wait and see how this new "green" model turned out. The driver, however, uses modern technology.
Nov 8, 2020 at 4:31 PM Post #50,217 of 75,209
Has anyone ever re-cabled Qian39s? Is it easy/do-able? I'm thinking of ordering a few extra pairs and doing it because the included wire kinda sucks, the one on mine starting splitting so I wouldn't mind re-cabling with a shorter wire. Any improvement in sound quality would also be a nice bonus.
Try to ask on DIY Earbuds thread.
Nov 8, 2020 at 7:33 PM Post #50,218 of 75,209
One of the first earbuds that I re-wired, back in March of 2017, was a set of QianYun Qian39.
I used some costly soft Copper wire - but have found some less expensive wire since then, that should work, as well.
Nov 8, 2020 at 8:23 PM Post #50,219 of 75,209
What a beautiful set!
Did you get any sound improvement?
Would you mind sharing links to such cables if they are from AE?
Nov 8, 2020 at 8:27 PM Post #50,220 of 75,209
Beautiful 4-core cable. It's ideal for buds. Another chip and very good cable for IEM and buds (6core) https://www.aliexpress.com/item/33001822584.html
I really regret not taking a couple of pieces, but because of the prices I thought it was below average :sob:
Your cable is quite reminiscent of these two pairs
https://www.aliexpress.com/item/4000097502378.html (good discount)
https://www.aliexpress.com/item/4000297658368.html
This is a good wire for DIY https://www.aliexpress.com/item/32612774761.html
I have a 4-core version which I used for balanced cable.
