Dec 13, 2019 at 4:43 PM Post #46,471 of 80,670
I've been into earbuds maybe a year but still don't know if rubber rings are really something people use on their earbuds, and if they work what they DO and where to get them. I'm suspecting a slight increase in bass presence would occur if my Turandots were just a teeny bit wider in circumference. Double foams would be an option, but I can't seem to get two of them on in any satisfactory way. If these had a slight increase more in bass, they would be end game for me. Anyone here use anything besides foams to tighten earbud fit and boost bass quantity?
Rubber rings increase the diameter, which provides a better fit for some people (foams may also still be needed for air seal). I've received some earbuds that included rings along with foams, but someone here may know of a separate source.
Double foams are tough for everybody. I'm pretty good at fine detail dexterity work and it is still hard for me. But I did manage:
Foams on my Turandot. Tore a couple of donuts getting there, but I think this is the best I've ever done.
Dec 13, 2019 at 4:49 PM Post #46,472 of 80,670
Double foams are not difficult if u use foams that don't tear apart easily like trig-rains, and preform the one that will go on top (fit it, remove it, put the slimmer one, and the one u just removed on top)
Dec 13, 2019 at 4:59 PM Post #46,473 of 80,670
That's exactly what I need to do... Did you do that with the donuts and foams the Turandot came with? Did you attempt to, if not what brand of foams are those? Thanks!
Dec 13, 2019 at 5:01 PM Post #46,474 of 80,670
I'm going to try when I get home the way you said. The Turandot finish is super slippery metal. Really not easy for me
Dec 13, 2019 at 5:07 PM Post #46,475 of 80,670
I am lucky that one set of foams is just right for me to have a proper fit. Like you said, the Turandot is slippery. I can feel the foams slide a little while I am putting the buds in my ears. Once in place they feel stable... especially after the metal warms op a bit.
Dec 13, 2019 at 5:24 PM Post #46,477 of 80,670
That's because you haven't tried the RW-1000 yet :wink:
Not sure what your point is?. I love the Turandot. I was never planning to get the RW-1000.
Have you seen how many buds I have? Running out of space.
Dec 13, 2019 at 5:31 PM Post #46,478 of 80,670
Not trying to make a point, chill. If I'm not mistaken your husband has it, so you'll get to listen it, it's insanely bright to my ears compared to any other earbud, so I need double foams personally, you both will tell us what you think :wink:
Dec 13, 2019 at 5:35 PM Post #46,479 of 80,670
I actually rarely listen his buds. If they are insanely bright I am not interested. He can tell you what he thinks. I like to spend my listening time just enjoying music with my own stuff.
Dec 13, 2019 at 5:49 PM Post #46,481 of 80,670
Ok. One of your post that striked me lately was that he didn't tell you he was getting x earphone and you were angry because "people need to talk to each other". Carry on, I don't give a ****, but maybe expose less of your private life on public forums in the future instead of becoming defensive later. Cheers.
Dec 13, 2019 at 5:49 PM Post #46,482 of 80,670
I'm thinking of cutting a loooong narrow piece of packing tape, and just wrapping it around the circumference of the earbud and putting the foam on afterwards. Is that crazy? I feel I just need about a milimeter wider...
To me they are like a piece of jewelry... I would hate to damage the finish... Might the glue on the tape react with the finish? Maybe masking tape would be safer?
Dec 13, 2019 at 5:54 PM Post #46,483 of 80,670
LOL, I was never being defensive. I was disappointed and kind of sad because I was planning to buy a certain iem and then found out he already had... a super deal had come up and he was quicker. That is all. It doesn't even matter now... I like earbuds better. At least the deal was had... it was less than half price.
Dec 13, 2019 at 5:58 PM Post #46,485 of 80,670
Good point. I'm going to put all my effort into fitting the double foams. Packing tape left on there for years will most likely ruin the finish. They ARE like jewelry, I agree. Photos don't do them justice.
I was kind of surprised to find them so slippery. I have a couple of shiny plastic buds that don't cause the foams to slip...although, when I am wiggling around any bud to get it seated properly, donut foams will shift every time for me. I can only use a donut if it is on top of a full foam... luckily I have only needed to do that on a couple of models... can't remember which ones at the moment.
