UsbPlug
Yes, but on the contrary. Powerbeats dd driver placed to an earbud (湖西小筑DIY DDM)Anyone here used a flathead driver in an iem shell?
Well, I accidentally broke the voice coil of one of the drivers just after a brief listen. One of the shells was a bit too loose for the driver, so it fell off... I did not want to use glue until I finished the tuning so that was the cost. Luckily I have a spare pair of these drivers.How is 14.8mm 32 ohm TI in wooden shells?
Drill the holes carefully because you risk breaking the shells.Well, I accidentally broke the voice coil of one of the drivers just after a brief listen. One of the shells was a bit too loose for the driver, so it fell off... I did not want to use glue until I finished the tuning so that was the cost. Luckily I have a spare pair of these drivers.
Actually, they sounded pretty good even without any tuning. But these shells have almost no ventilation - only 1 tiny vent hole at the back, so I will experiment by drilling additional holes.
Sure. I have a miniature bench drill for very precise drilling.Drill the holes carefully because you risk breaking the shells.
Wow! Either you have very steady hands and are working very carefully, or you got lucky.I managed to do that with a side cutter. You just carefully cut the plastic edges in small portions until the driver loosens up.![]()
Hmm, I haven't seen that option at all.Not all drivers come in the naked option though...
It's quite easy with transparent faceplates because they are very fragileI'll just have to take the cover off very carefully
Great!!, thanks for sharing I did not know this existed.Yup! We have a spreadsheet not a playlist:
https://docs.google.com/spreadsheet...ewjo3_D_h47C8unxH_b19mBGTsQ/edit?usp=drivesdk
Some solid test tracks on there!
I've seen few on taobao. You can search with image.Hmm, I haven't seen that option at all.
Mine 2.5 to 4.4 is from hereHey people, i need a 2.5 male to 4.4 female adapter.
What is better to take - a solid adapter like the NiceHCK, or a small 10 cm adapter cable (these are available at Ivipq or Openheart) ?
You can also heat one side with lighter, bend side of the cap and hook the ring of membrane.I'll just have to take the cover off very carefully
I got the cabled ones from OpenheartHey people, i need a 2.5 male to 4.4 female adapter.
As an owner of SMG and TGXears Totem and listened to Serratus, Sunniva and DS in the past, i'd say it's comparable. Like, it's behind Totem for sure. Tonality wise, warmer, more balance than Serratus, though not as big of stage.
