Perhaps it's the cable at fault. Can you try a different one? Or reverse the one you have?
Well I switched mmcx cables for the one I had on my Tennmak pro. It turned completely green from the 2 years or so it was in storage...
The cable itself goes down a lot more than the stock cable from the ST-10. Where the stock cable was floating 1-1.5 mm, the Tennmak cable is touching on the right and floating .5 to 1mm on the left...
I listened for a few hours today and no cuts. I felt like the cable made the bass heavier the first time I switched but made some of the imaging less good, but I am pretty sure it is from the green placebo. After a break and listening they sounded great again.
They definitely feel like a step up from the MK2. Details are about the same, but the MK2 brings everything up front really close and it hurts the imaging.
Playing Overwatch with it too, the soundstage and imaging is PERFECT. Everything is exactly as far away as it seems it is. I can even hear if the sound is coming from behind me. I've never been able to hear that from another earbud/IEM/headphone that I own. Listening to Marvin Gaye "Sexual Healing" every percussion seems to come in at a different height. Amazing! This is something I have almost never heard this clearly. Maybe only on the ATH-CM2000Ti.
Even if I have to switch it if it cuts up again, I will get another st-10. It's amazing!
