golov17
CF2 on the way )))No activity for the last 19 hours? This is a test to make sure that sean didn't get the thread locked or something
RY4S? They are awesome for $8.Whenever I buy a Vido someone or the other always requests to take and and I had to give. Arghhhh!!!
I was legit confused as I’ve been out of the iem market for a while, but for buds i would reply semi-competently.Don't worry. When you figure out what iem you want, you can come back here and pick out a nice bud I enjoy both....and headphones!
I have ordered a RY4S which is on it's way.RY4S? They are awesome for $8.
That player wowww
The Shozy BK is really something! Nice sound!
Just received the ry4s with UE . Pretty happy with this.Maybe you need to order 10 at a time
What song do you recommend? I will try to make few assessmentMay I know which earbud do you guys recommend that have sweet vocal and warm sounding? Sweet vocal as in when I listen to it, there’s a sweet taste generated in my mouth.. (not sure if you guys have been through it) I’m using Fiio Q1 mk2
Any earbud plus a sugar cube should work!May I know which earbud do you guys recommend that have sweet vocal and warm sounding? Sweet vocal as in when I listen to it, there’s a sweet taste generated in my mouth.. (not sure if you guys have been through it) I’m using Fiio Q1 mk2
Kidding, maybe consider the new rose Masya pro? The original masya had very sweet forward vocals and a warmish bass with thick foams.
I think the higher the output impendance of the source the warmer it sounds. So you need a good source pairing for it to take on the tonality you desire. Low OI will make it leaner and colder.
I recommend Boarseman MX98S which is sweet, but still balanced. It sounds a bit like Blox TM9.May I know which earbud do you guys recommend that have sweet vocal and warm sounding? Sweet vocal as in when I listen to it, there’s a sweet taste generated in my mouth.. (not sure if you guys have been through it) I’m using Fiio Q1 mk2
