lup31337
- Dec 8, 2010
This thread was not around when i was a bass head. Mixed feelings ...
5. Jam out.
Cranking up the tunes can do great things for your mind and body. (Count ‘em! There are at least 20 health benefits associated with it.) And now, recent research suggests that listening to music may lead to feeling more powerful . To paraphrase popstar Meghan Trainor, it’s all about that bass (no treble): listening to heavy-bass songs promotes more feelings of power than the low-bass songs.
http://greatist.com/grow/easy-confidence-boosters
It is not really coming from my headphones, but my latest setup has the most bass I have ever experienced:
http://www.head-fi.org/t/756810/full-body-headphone-sound-yes#post_11365756
Guys, which music players or EQ programs do you use in Windows to EQ your music?
I use MusicBee, but it only goes as low as 32hz.
Do you find that enough or do you EQ also lower frequencies?
Could you give some suggestions about some EQ settings for a super bass?
Generally in MusicBee what I do is +12db on 32hz, +9 on 50hz, +6 on 80, +3 on 125hz. I usually leave the 200 untouched for the normal music.
Then I have a setting for Dubstep, with even more boost (and there I also boost the 200hz).
What do you think?
How do you EQ the e12 amp? i was looking at a diagram of the amp and it looked like that you have to take the thing apart and reorganize the chips or something...
32 Raised is pulling up a hill that is raising the nearby frequencies to. It's likely a 32Hz @+12 is dragging the 25 Hz at around +2 to +6 depending on what the Q/bandwidth is
You need an amp and pads that keep the ws99 off your ears as it seems your eq is fine. My rig goes to 31Hz with a q factor that allows me to hear 25Hz notes. Your good to go with the Eq
On most music players the EQ is a normal band EQ, not a parametric one, so, no idea which Q they use.
On Neutron (a player for Android) I have a parametric EQ with 4 bands, low band, mid 1 mid 2, and high band. For low and high there is a Q, for the two mid there is a width control.
In Neutron I have dedicated the low band and the two mid for low frequencies, setting the low at 20hz with a Q of 0.4, the mid1 at 60hz with a width of 1.2, and the mid2 at 120hz with a width of 2.4. Then the high band I have it set on 9000hz with a Q of 3.
Additionally I use the band EQ of my Xperia, decreasing 400 and 1000hz of 3db each (the ATHWS99 do too much in that region for my tastes) and increasing 2500 of 3db, 6000 of 6, and 16000 of 3.
What do you think of these settings?
I, honestly, still do not understand very well how a parametric EQ works, so I am not sure that my settings in Neutron make sense.
My aim was to make the bass deeper and wider, with more body and more rumble and punch. It kind of worked to my ears, but I wonder if I can do better with other settings.
