Thoft208
I was trying to find a better eq for my sony walkman.... can anybody tell me how i should eq the mp3 to get the most bass out of it?
Check the sony threads.
I know they have a thing called Clearbass but beyond that I'm not familiar with the device
This what your settings look like with a +3 on the low and 2 mids, and -2 on the hi, for the Neutron MP EQ. You didnt say your gains, but this would be the general shape. I don't think the hump at 60 Hz is helping you achieve deeper wider bass.
My extreme Bass settings in Neutron are currently:
Lowband gain 0 dB Mid1 band gain -12 dB Mid 2 band gain -14 dB Hi band gain -15 dB Low band cut off 40 Hz Low band slope Q 5 Mid1 band center freq 1000 Hz Mid 1 band width Octaves 7 Mid 2 band center freq 2500 Hz Mid 2 band width Octaves 9 Hi band cut off 4000 Hz Hi band slope Q 0.04
This gives a huge "spoon shape" with 1 at 0 dB, 100 Hz at -15 dB, and everything from 368 Hz to 5000 Hz at less than -30 dB. Add a bass boost by amp and you're in serious bass business (you can change the gains to adjust the scoop, to take advantage of amp boost and volume, and add more mid/treble as you like). I have found that additive gains (>0) in software EQ can lead to distortion, whereas with substractive EQ it needs more volume but keeps sound quality clean.
HTH!
just got the headphones(sz2000) in the mail yesterday and loving them. tomorrow my cayin c5 comes in the mail and the real bass begins
Not loving the E12 anymore ehh HBB
Hopefully this time you bought shares in the company before this thread boosts sales through the roof. BAAM! I still love my e12 although the battery seems to drain rather quickly. My Pa2v2 lasts over 100h easily on one charge. Gain can be set very high and it looks just like a bomb, especially with a silver braded cable.
