gelocks
- Jun 6, 2011
I have the O2 connected to the 3.5mm jack directly on the motherboard. Then the headphones are connected to the O2 by 3.5mm again. With a DAC and digital cable coming from my MB to the O2 give me the difference I'm looking for? Thank you for the patience as obviously I'm a huge noob here. I don't see an EQ knob on your Magni, and there isn't one on the O2 either. How do I adjust the EQ? Is this through a DAC (which I don't have, but will get if that is what you think I need) or through software? Thanks!
I EQ'ed via my MP3 player... (right now, using AK100 MK2).
On the PC, depends on which software you are using. If you use FooBar, there are available equalization options same for a bunch of different software.
A DAC might help overall sound reproduction since usual integrated PC motherboard solutions just plain suck really. But again, it's a question of preference. Sometimes I use my PC sound card output with NO amps even! But, not for the JVCs...
I'm at work right now, so I can't do the paper test. I'm not sure how I would be able to adjust the sub base or eq any more. The O2 amp only has a 1 press EQ button, on or off, and it definitely sounds better with it on. The other amps I see recommended don't have any EQ knob at all. How do you boost the sub bass?
To your edit: I got these for RAP and hip hop. I got the O2 amp because it was highly regarded on this forum and was very reasonable priced at $129. The top desktop amps seem to be 300+ here. Will a DAC + optical cable running from mb give me what I'm looking for? Is there software you use to adjust the levels youre talking about?
What you are referring on the O2 (with regards to a button) is the "GAIN" switch! This basically outputs MORE power for higher impedance headphones (you think it sounds better because you are just providing more power, hence more volume can be attained and that might make some cans like the JVC sound "better").
The O2 is "highly regarded" not for basshead, but because they measure well and are pretty much "neutral" and a good option for people starting out. But, as you can see from the first post, most people use their MP3 players with Equalization option and DSP effects paired with amps (you will not see O2s on most of these set ups.).
If you buy a DAC, you can just connect the PC to it via USB (no need for an optical cable). And yes, depending on what playback software you are using in your PC, you will have different EQ options.
