Trae
I've been thinking the same thing, but it would cost people money to do... Although it would be more accurate, but if people can get a seal with the paper and do it correctly, it should work.
Well, sound meters aren't that expensive, and I don't think $20-40 (well more if you want one that does a lot) is going to dent anyone's wallets (especially if you can afford some expensive headphones), especially when said equipment has much more utility than just measuring a headphone's output loudness.
You missed the long ago posts with a dB meter and misunderstood the entire purpose of this thread which is finding the cans that provide enough bass/low frequency energy by sheer driver quality and force or driver and housing resonating /vibrating combo to be felt on the head through the pads.
Appreciate you taking the time but this thread is basshead not sound science.
Just yo humor me ....or you....you could use our not so Scientific way and see how much air and energy your cans are hurling out.
Yeah, I just read those posts, but I did not misunderstand this thread in the slightest. I was simply proposing that instead of doing the paper test, or as an alternate option to measure how loud the bass is, to use a sound meter. In a way, the paper test is no less scientific than using a sound level meter. The paper test gives you more tangible and audible feedback, whereas the dB meter gives you more discrete, accurate, consistent, and easily repeatable results. Both methods are mediums that reflect on the driver's bass reproduction.
I did the paper test to the best of my ability (kinda hard to get the paper in the right place), and it's a bit above the TH900.
