assassin10000
You talking about the willsound mk2? I've probably misunderstood the original comment though.
K's LBB
No, @assassin10000 was talking about K's LBB.You talking about the willsound mk2? I've probably misunderstood the original comment though.
Nice. Thank you. As long as it doesn't sound dark or congested. How would you rate it for hard rock music?It's an earbud that's rough around the edges but has lots of raw power!
Great dynamic sound but the midrange is a bit pedestrian at times. Low treble is nicely in balance though so you won't get any artificial brightness nor is it dark. Vocals are average though on occasion as there is a dip then peak in the 300-2000hz zone so you get some details pushed but the tonality can be a bit off at times IMO. Of course its not severe at all and perfectly listenable on 99% of music just not refined as much as the best midranges ive heard in earbuds.
Definitely atleast mid tier maybe mid + from what I've heard. Off the top of my head I'd say It's in my top 10 but maybe not my top 3. But its also NOT that expensive so its brilliant for the price.
Pretty good, it's what id call an all rounder earbud as it can handle most genres but won't specialise in one.Nice. Thank you. As long as it doesn't sound dark or congested. How would you rate it for hard rock music?
Have you compared the to200 to the 150ohm version? Everything I've read would suggest I'd like the 180 better, especially for rock and metal. It sounds like 200 is more analytical in comparison, while the 180 is more fun, engaging, and dynamic with better bass slam.Clearly, I don't think any earbud can match the sub quantity of a ZS7 tbh, a few earbuds have good extension tho (EBX, RW-1000 for example) and with a bit of eq you can push it.
However I have yet to hear an IEM that has the "physical" mid-bass slam of a TO200, TO600 or some plastic buds, it seems the fact that it's inside the ear canal doesn't allow for the same sound quality to me, it's invariably softer in attack, with no feeling of air being actually, physically moved to me.
The sound of jazz kickdrums invariably makes my day on the TO200, but ymmv.
Hi, I'm new to earbuds and a̶m̶ ̶t̶o̶o̶ ̶l̶a̶z̶y̶ ̶t̶o̶ ̶r̶e̶a̶d̶ ̶3̶0̶0̶0̶ ̶p̶a̶g̶e̶s̶ I've searched exhaustively and have questions: My non-OEM earbud experience prior to today was the MH755, which is amazing and wonderful. But I gambled on Black Friday and got two pair of Nicehck earbuds with letters and numbers in the model name. Today they arrived. My two questions are stupid ones, the first for which I expect @Slater to post "here dum-dum" images to set me straight. So how exactly are these things worn? I figure the neck of the buds goes in the notch in the lower ear, which means that the driver/speaker is not flush against anything. Coming from IEM-land of implanted nozzles, this feels like it's just resting there out in Siberia, though the sound isn't awful.
Secondly, what are the colors of foam, and how do they affect sound? I see there are blue and black, some that fully cover the speaker-driver, some that are basically big o-rings of foam. Guessing the foam-rings are more treble, and the full foam covers are to muffle the treble, like T800 dampers. So why are there two colors of each? And is there an easy way to put them on? It's like putting tiny socks on a toy doll, not wanting to rip them.
A fun experiment so far, and I'm not sure they'll take me away from IEMs, but at least now I can say with this new inventory I'm one step closer to being a snobby sneeringly arrogant audiophile™
Yes it is
You're talking about mkii here right?It's an earbud that's rough around the edges but has lots of raw power!
I only have a few buds atm. I have the bgvp dx5 and don't care for it. I have the Smabat M1 incoming. As of right now, my favorite is the **** Bk2.You're talking about mkii here right?
And can you tell what's your favourite 10?
Yes the mk2.You're talking about mkii here right?
Definitely!Anything more than a tiny amount ruins the sound though.
Does the sub bass over power, distort, or bleed into the other frequencies on the 180? And are the high mids too much, causing fatigue and discomfort? I don't want a hot and bright sound, but I also don't want an analytical sound. The mid bass slam is what I'm after - would you say both buds are equal in that regard? I want a warmer sound, but not overly so. My music is primarily hair metal and classic rock. Which would you recommend for this? I'm exchanging an earbud at Penon Audio, and I can't decide between these 2. My primary source will be my Opus#1s balanced.Hi, I just received the TO180 (the 150 ohms one) and yes it has more bass than the TO200, sounds therefore maybe more "fun" if that's a thing, but definitely quite a bit warmer. Not as warm as the TO600 tho. It has the same kind of physical slam the TO200 has, but with the "bass boost" of my amp turned on if you like. For mids and highs it's difficult to say as I don't have the TO200 at hand and won't before monday, but it seems to me that it's more weighted towards the high mids than the TO200 which is more weighted towards low mids, as pushing the volume results in a bit of discomfort, which doesn't happen on the TO200 (but burn-in might change it a bit, possibly)
The TO180 sounds very, very similar so far to the Tomahawk which was in the same parcel, the latter just being easier to drive (it's a quick impression after a 5 minutes sessions mind you, I'll come back to it this evening, no time for now)
