Who has shozy xb
Let's buy it...
Who has shozy xb
What is the general sound profile of the Ourart ACG. Would appreciate some feedback if poss. Thanks
Just noticed this from K's Taobao shop on pre-sale. The name translate to either "smurf' or 'blue elf'
Price is around $240, so probably another top-tier level earbuds.
Which of the current offerings of ultra-low budget (~$10) earbuds with the smaller shells (smaller than Monk+ type) have the heaviest bass? I'd like to try the smaller form factor.
Whichever will give you the best seal. Maybe take a look at the Ty Hi-z 150 ohm. Decent sub and mid bass for 20 bucks.
$50 price range would be good.
Okie doki. I've decided I want a pair of mmcx that's good for wearing cable down, rather than over the ear. I like to use the wing tips, and the Ty Hi-z fits me very well. Again, rock and hard rock are my jams. Willing to spend 100 bucks. There's just too many to choose from, and no way to listen to them. The new Smabat M1 coming out looks about perfect, but obviously we don't know what they sound like. Really, I just want to know which buds with detachable cable are comfortable to wear cable down. What should I be looking for as to where the cables attach to the earbuds?
Excellent mids, good highs and soundstage. Still a favorite, kinda going back and forth between it and the ST-10. In a quiet environment it to me is better than the ST-10 but out and about the ST-10.
Bass can be good if you have a great seal for earbuds but typically is a bit lacking. I think this is due to the large open face design, which allows a lot more air to escape around the circumference of it.
I own both and the B40 offers just what you want.Any budget ones with mic with more clarity than headroom ms16? Is the b40 this way? Looking for flat/balanced, perhaps mid forward but without too much high roll-off
Is there any reason you don't EQ on your laptop? If it uses Windows, PEACE/APO is excellent:I don't have a higher powered source I'd use them with, except maybe for my laptop which I don't EQ on.
https://sourceforge.net/projects/peace-equalizer-apo-extension/
OK, but it's an option if you need more power.Mostly because I hardly use it for music/movies.
I'm one earbud richer. Thanks for the infoI own both and the B40 offers just what you want.
