After digging around inconclusively, I have decided to put ordering the RY4S on hold for the time being but instead went with a pair of KSC75X.
Earbuds Round-Up
- Thread starter ClieOS
- Tags
- akg akg-k-319-in-ear-bud-headphone-dark-charcoal audio-technica-ath-cm707 baldoor-earbell-e100 bang-olufsen-a8-earphones blox-anv3 blox-m2c blox-tm7 blue-ever-blue-328r creative-aurvana-air-headphones-over-the-ear crossroads-hr1 dunu-alpha-1-hybrid-earbuds-dynamic-balanced-armature-high-fidelity-headphones earbuds hifiman-electronics-es100-vintage-style-earbud-with-15mm-driver-blue rose sennheiser sennheiser-mx-580-stereo-headphones-with-intergrated-volume-control sennheiser-mx-581-stereo-stereo-headphones-with-intergrated-volume-control sennheiser-mx-760 sennheiser-mx-90-style-series-in-ear-headphone-with-volume-control sunrise-audio sunrise-audio-charm venture-electronics-ve-zen yuin-pk1-earphones yuin-pk3-earphones
waynes world
- Jun 21, 2012
If you don't have the ksc75's, then you've made the right choice.
I had the original one about over 10 years ago and I still quite miss it till this day. So when I found out the KSC75X came in black, I knew I just have to own it again.
cyh03176
Everyday I see the name RY4S pop up in my emails so I just bought the white plus mmcx version. You guys are like poison.
Alex.Grimm
how do you get to tell or it sound and bass is better than ue/hi version
cyh03176
stop lolhow do you get to tell or it sound and bass is better than ue/hi version
i asked the store and since he said plus version has the different drivers and sounds better, i am just going to take his words
Alex.Grimm
stop lol
and told me that its the same
cyh03176
really? what is the difference between the normal and the plus version that he told you?and told me that its the same
Alex.Grimm
No, normal have difference between plus. I tell about plus and hi/ue version. maybe he can't properly explain. a couple of the above wrote that it sounds better and more bass
cyh03176
oh.. then it doesn't matter because i want the mmcx version. i want to use ridiculously thick cable on these.No, normal have difference between plus. I tell about plus and hi/ue version
RY4s 300 ohm on the left and RY4S 32 ohm plus version on the right, both with 2.5mm balanced plugs
If I had one it would have been opened alreadySean will ... @seanc6441 opens everything
The tuning could be different which could affect the bass response. Even minimal differences to bass port size or driver back dampening can make a notable difference in bass levels.But, RY4S driver(= RY4S MMCX Normal version driver) has more bass than RY4S HI version driver(= RY4S MMCX Plus version driver).
Therefor, RY4S MMCX Normal has more bass than RY4S MMCX Plus, doesn't it?
Of course you know this already, but maybe this is why the bass levels do not correlate with the info we know already.
So how's the ry4s 300ohm? Sound like open back headphone?
I just playing Rise of Nation and and happened to grab ry4s UE. Sound is Wow!
