I'd say TOTL according to the maker; it's their flagship. It does a lot of things right, and did nothing wrong (except probably the housing might not for everyone although it's one of the main selling points for me for not using MX / PK shells). If compared to IEMs, I'd put it between Tin Audio T2 and Kanas, slightly to the Kanas side for overall. Soundstage is definitely better on the EBX, wide and natural. Imaging is better on Kanas. I have a set of MK2 rev2, so I could compare them later at home.Is the EBX one of TOTL earbuds? how is the sub bass and mid bass? is it light or mild? can they punch? i came from iem worlds
and how is it compared to willsound earbuds? is it big different?
If differences are subtle i might just go for EBX and settle down, not going to buy so many earbuds.
and 1 dumb question, how is the correct way to wear earbuds? i mean are they suppose to be just "sitting down" on ear not blocking / sealing your ear canals or is it supposed to seal it? I always feel it wrong like the buds just hanging around without proper seal and my mind always playing with me "its gonna fall down after this, yeah, in 3..2..." but actually they're not falling down.
Thanks in advance
There's no correct way, if there's one, I won't care. For some buds, I padded them with rubber rings and foams so they'll sit tight and seal the canals as long it doesn't make the bass overwhelming; so, yeah, kinda IEM-like. Other buds, like PK16, I just applied rubber rings to give a little padding and use them without foams; I like them open as they still sound good even in noisy environment (the bass already rolled-off anyway). Experiment with how to wear them to match your preference.
