redkingjoe
- Nov 29, 2016
I would take the Svara L's off of your list... the bass is so good, it's distracting lol. Well, the bass probably wouldn't be a problem for you, but the highs are fairly present which might put them out of your "non-fatiguing; easy listening" category (I don't find them fatiguing, but rather engaging). The build quality and mmcx option is great (using them balanced right now). However, you might be looking for something a bit mellower.
The only others in your list that I have are the MK2.2's. There is more mid-bass and the bass doesn't thump as hard or seem to go as low as the Svara L's. The MK2.2 bass still plentiful, but mellower. The mids are a bit more forward, and the highs are still quite present but not in a fatiguing at all. Overall they sound awesome, but, the treble might be a bit too present for you.
I'm sure you'll get lots of good input. Good luck!
Edit: I just read chinmie's endorsement of the Svara L's. I just wanted to point out that his are the older higher impedence versions, and mine are the 32ohm version. I am not sure how the highs compare.
Any ideas on the Svara L vs Svara Pro?
Thanks!
