That link has 20 ohm in first description then 64 ohm further down ![L3000 :L3000: :L3000:](https://cdn.head-fi.org/e/headfi/L3000.gif)
Anyone care to compare any of the Willsounds with the HE 150 PRO?
Sidegrade or upgrade?
Thanks!
I have WillSound Mk2.2, so I will compare with this.Anyone? I am looking for comparisons sound signature with specific comparisons in bass impact, extension, and clarity, and high-end sparkle...
Much appreciated!
What a long thread... oh my! But definitely a wealth of knowledge and experience.
I am looking for a warm (dark), non-fatiguing signature for very long listening sessions. I do like bass but I wouldn't classify myself as a die-hard bass head though. I definitely do not prefer bright and/or strong treble signature nor sibilant earphones. I mainly listen to ambient electronic and ambient classical music (some examples are in my profile). A detachable cable would be great but not a deal breaker. My main want is "non-fatiguing; easy listening".
Based on what I read in this thread, posted reviews, and on Reddit I am currently considering the following (now ordered by recommendations):
Willsound MK1.2 / MK3
Svara-L
Blur Black Panther
Willsound MK2.2 / PK32
Shozy Cygnus
Cypherus Model ??? (since I live in Thailand)
Any suggestions, advice and/or recommendations would be sincerely appreciated.
EDITS:
- Removed Rose Masya; just stumbled across @seanc6441 post regarding mid-range brightness
- Removed Moondrop VX pro as per @chinmie post
- Added MK1.2 and Blur Black Panther as per @capnjack
- Addes MK3 as per @palestofwhite
Guesstimating, where would Willsound's MK1.2, MK2.2, and MK3 fall within the Tier 3 line-up, rating wise? 4.0+?
I have the JVC HA-FX850 and I liken it to the MK1 Rev.2
When I heard my new PK32 there was already a night and day difference right out of the box, definitely. No need to burn them, as my defective has now over 100 hours and the sound did not changed at all too.
I will return them to willy soon, so maybe he can check what was the issue exactly (which could be interesting to know).
So we can easily recognize if a PK32 pair is defective, simply give a quick listen and if no bass, then it is. Where now I'm a bit lost is that some says bass is here but light, on my PK32 new pair it's almost as heavy as my MK2.2, it has very slightly less quantity but has more control. When you listen to PK32 you can see how MK2.2 is more "dopamined" on bass quantity. I still believe than PK32 is best allrounder from WIllsound, where MK2.2 is more for electronical musics (where bass and highs needs to be very present).
I have the fx1200 , but haven't used it much after buying them because cost to muchThose FX850's are classics! Back in the day when I was into iems, I had a good lust going on for them lol.
I have the fx1200 , but haven't used it much after buying them because cost to much![]()
I have both pk32 and Mk2. Mk2 have nice bass and sub bass. My pk32 has far less bass than the Mk2.You guys are making me worried about my pk32 hahah. I felt like the bass is there but just a little light. I’m still not sure if it’s just me being picky or if has anything to do with fitting or foams.
If too many people are having the same issues perhaps it could be a batch thing and might need to be recalled.
For now I have not much issues with mine. Bass is there, yes, though it’s a bit light. If the pk32 is meant to have more bass than the mk2, I would imagine that the mk2 wouldn’t have much bass at all. Note that I’ve not heard the mk2. At the moment I would think that they are adequate but it would still be nice to check or get some confirmation.
Edit: I misread. It’s meant to have about as much or a bit less bass as the mk2, just more controlled.
Abbreviation: W (WillSound Mk2.2), H (HE 150 PRO)
bass impact: W = H
bass extension: W > H
clarity: W ?<? H
high-end sparkle: W > H
I feel that the sound range of HE 150 PRO is a little narrow.
I have WillSound Mk2.2, so I will compare with this.Thank you!
Any thoughts on soundstage comparison?
Also, do you feel the mk2.2 is a big/worthy upgrade? Or should I look to another level?
Again, much appreciated!
Trust me youwould know if your pk32 was like mine or subwoofers as he seems to be in the sam boat as me. It's not just bass light, mine was completely missing extension below like 60-80hz... It couldnt do any sub bass and only bare minimun mid bass. Songs didnt sound the same as I remembered them xDYou guys are making me worried about my pk32 hahah. I felt like the bass is there but just a little light. I’m still not sure if it’s just me being picky or if has anything to do with fitting or foams.
