roy1963
- Dec 28, 2016
Sorry, I cannot help, my silver/white Monk Lite is 120 ohm with regular cable, not SPC.
how are you finding its sound compared to the qian39
Unfortunately I have not listened to the Qian39 in a really long time so I am unable to comment at this time.
I have only listened to the gold/black 40 ohm version right now, if I compare with the Monk+, they both share the same laid-back presentation but the tuning is different. Monk Lite has less bass and better clarity than Monk+, whereas Monk+ has warmer tonality, Lite is more neutral sounding, leaning towards bright.
Maybe they are hand delivered via bicycle messanger lolGot a notification that my K600 has cleared customs, but the two orders from the end of Nov are still out there in the ether. I'm guessing slow deliveries are in a container on a ship somewhere on the sea, or they are still using piston engined biplanes for airmail
Do White Bell and Black Bell have the same earpiece (just different in silver vs dark metal finish)? In other words, is the real difference between White and Black only the cable?
new toys:
White Bell comes with either single ended or balanced termination, both are OFC cable. Black Bell comes with stock or pure silver cable, stock is silver plated OFC + gold plated OFC. Poseidon comes only with 5N pure silver cable, but three different exotic housing materials: pure silver (stock and cheapest, but currently out of stock), platinum or gold. The later two are super expensive (10x the price). Bell series are brass btw. Given these are no cheap buy, I think you can probably ask for balanced plug even if you didn't see the option in Taobao.
No fitting issue with anyone of them - but as you can imagine, since they are all full metal with smooth finish, they don't offer a lot of friction and will slide out if you shake your head very quick (plus they are heavier than plastic earbuds, though not as much as Liebesleid). Those with Liebesleid probably already know how this goes. The solution is to use some foam pad, ideally donut foam or better yet, the DIY multi-hole foam that I described in the past.
