May 30, 2011 at 5:50 AM Post #121 of 1,244
There are build quality complaints on every single IEM if you look into it. People generally don't come to forum to compliment a headphone for not breaking down, but a few that do come to complain about break down will immediate cause a panic among the crowd like there is some kind of pandemic. It is hard to look into the big picture in a forum. I have had mine since the beginning and don't have any problem with it. I will note it down if I see a potential issue. If not, I won't. That's not to say it won't have a problem at all, just that I don't have any on mine.
alrighty then. I really thought it was more of a widespread issue. Sorry about that.
Jun 2, 2011 at 2:30 AM Post #122 of 1,244
http://www.head-fi.org/forum/thread/551280/sunrise-sw-xcape-impressive-edition-not-v-2-any-impressions-out-there/60#post_7513092
That settles that. Seems that only 10 people had the issue.. and they figured out exactly what it was. You were quite right about it being an isolated issue. Good call ClieOS :)
Jun 2, 2011 at 10:34 AM Post #123 of 1,244
hey clieos.
how are the re0 and re-zero compared to the DBA-02 in detail and vocal detail , specially female? ... if they can even compete with them...
and how about the re262?
though the re's are dynamic and the dba BAs
Jun 2, 2011 at 2:16 PM Post #124 of 1,244
I personally find RE0 to have one of the best treble detail of any dynamic IEM (and only south of ER4S when BA is included) and does female vocal fairly well. RE-ZERO doesn't quite have the quality in treble as RE0, but it is better at female vocal as it is a little more forwarded. However, both have better vocal than DBA-02. While not really bad per se, DBA-02 just doesn't have the texture in mid to be good in vocal. Of course neither of the three can really compare to RE262.
Jun 2, 2011 at 5:56 PM Post #125 of 1,244
that worries me now.
i've ordered the B2  on mp4nation. and now i wanted to get the B2 + E11 bundle.
i know the B2 arent the dba-02 but i've read they're close each other.
i dont mind cancelling the order and just getting the E11, but still i'm not sure.
any suggestions ?
the re262 will need a good amp, and also seem to be a bit uncomfortable with that design.
and the re-zero , need to use that adapter/s
what a dilema!
Jun 3, 2011 at 12:36 AM Post #126 of 1,244
It is common to doubt your own decision after ordering. Like DBA-02, I am sure B2 is a pretty good sounding IEM on its own and you should try it first before dismissing it all together. Maybe that's what you are looking for and you won't have known without trying.
Jun 6, 2011 at 11:05 AM Post #129 of 1,244
CKM99 is definitely under my radar, but not so sure about CKS90 since I am disappointed by CKS70. Most likely I will pick up the new JVC dual driver before the end of the month, if I can still find stock of it locally by then.
Jun 9, 2011 at 1:32 PM Post #132 of 1,244
Love this thread, great resource. Couldn't help but notice, but the RE272 is no longer on inearmatters as a possible review. Has something changed from head-direct?
Jun 9, 2011 at 9:59 PM Post #133 of 1,244
No, nothing changes. IEM under the 'possible review' section usually is expected to come to me in a relative short notice, like in two, three weeks or less. Since RE272 has yet to be released after so long, I thought I'll remove it from the list and put it back when I have further confirmation.
Jun 9, 2011 at 10:36 PM Post #134 of 1,244
Wow, the review is epic! Not only have you captured the scale of what is out there, you have provided a framework that is comprehensible. I have subscribed this thread to keep abreat of what is going on in this area. I look forward to more reviews and wish you good luck. :)
Jun 9, 2011 at 11:51 PM Post #135 of 1,244
Thanks, guys. This review has certainly evolved overtime
