quisxx
- Oct 17, 2011
I meant the pads. I did say “in or around ear”Wait, what? Fostex is king of fast bass and doesn't seal very well at all.
Hey guys I'm not sure if this is right place for this but I know a lot of you guys are using this setup.
Just got my SMSL SP200 and M200 in. Something is up. No bass, very tinny, and I am "hearing double" if that makes sense. Its like the track is playing twice with one about 2 sec behind the other. Got the driver installed for the DAC and tried both XLR and RCA to no avail. Anyone else had an issue like this? New to this high end equipment so hoping I'm doing something wrong.
Can you check all the plugs including the headphones are inserted properly and no software EQ leading to the reverb is on?
Also are the cable connections on the headphones correctly inserted or not?
Ah man I feel like an idiot. Seems like its the headphones connection. Didnt have an issue with this 1/4" adapter before but its like the headphones feel really loose inside of it. I adjusted it a little and the sound is better but there is like a constant buzzing sound. Just put in an order for a new adapter so hopefully that will clear it up. Thanks.
No.yesterday i demoed the meze, emphrean cans
wow!
loads of bass.
Good bass? Yeah. It has well-textured lows, with good layering. It sounds a little mushy, though.yesterday i demoed the meze, emphrean cans
wow!
loads of bass. $3k price tag.
誰 も 彼 も が 完 璧 な キ ス の 方 法 は 知 ら な い は ず だ よ 。
Yes, your description had me quite baffled as to what was going on, because I most certainly have not had that issue, and haven't known anyone on here who had that issue either. Looks like it was just an improper headphone connection. Some adapters don't allow connectors to get all the way in properly, just depends on how they were designed. Glad there was a resolution though, and you will be happy with some delicious sound soon.
Buzzing sounds are most certainly caused by ground fault situations. And if the connector can't make full proper contact, you will get the buzz. Once its all resolved, it would be great if you could come back, and let us all know how much you enjoy your new S.M.S.L combo
Alright I finally got it squared away after 3 different adapters. Sound has DEFINITELY improved. The amp was a game changer. Sound has definitely opened up and a lot less muddy than the old external card I was using. Love it!
That said, its definitely a flatter profile. Everything is crisp as can be, but I think I can push the bass more. Before I drop another $200 on the Loki, I tried poking around for a software EQ. For some reason none of them seem to work with the DAC drivers. I am also missing the enhancement tab in the speaker settings in Windows. The hardware option is fool proof, but any of you have a software EQ that is confirmed to work with the SMSL M200? I did see the sound color option on the DAC but I'm still craving more BASS.
