Purplezorz
i would like to ask for your advice to change my yamaha hph-mt220, i like a new headphone with more bass.
which do you prefer v moda crodssfade m100 or beyer dt 770?
I use the headphone connected to a schiit fulla 2.
Thanks
Carlo
What are you listening to? If it's for bass heavy stuff, then do NOT get the Beyers. They will distort very easily under bass stress, whereas the M100s with XL pads (required upgrade really) will best most basshead headphones IMO.
I have both right now. I find the Beyers the best for anything that isn't listening to music. TV, Movies, Games, Phone Calls. The only genre I really like it on is UK Grime, because they're good at vocal tracking.
If you're listening to other genres that have a little bit of bass and you want it to be present and accurately reproduced at the low end, then yah, the Beyers should do you well. But this was the first can I got and I was so overwhelmingly disappointed with its bass capabilities, that I bought a second one because I thought the first one was broken; it wasn't.
