SHAMuuu
- Sep 23, 2013
6 drivers in there... yup.
Back of UFO pads. 2 of the clips pop off easily, need to find them first, then it seems to twist a little then pop off. It was not so easy, and i just kinda yanked it off taking risk, it worked.
see how small opening is compared to hm5/xb1k pads
xb pads allows drivers to breathe more as i expected, see it to believe it
Hm5 pads have a hole that has also enough room for drivers to breathe. More distance from drivers seems to impact soundstage a bit, but i dont think its all that accurate to begin with! But there is change, and more airy lowend. Don't expect miracles though! It will still get slayed by szs. But comfort. yessir
There it is UFO with hm5. It fits over the cup, but sits fine with adjustment.
I think the plastic rings can be removed, superglued to xb pads, and reattached, but im waiting for pads to arrive from ASIA. I am thinking i might like xb pads for even more comfort. They are just too marshmellowy.
One other change i think happened is they seem LOUDER. These cans are very very very loud. Some guy on youtube called them Seattle Seahawks Loud, and they are with all the drivers not being interfered with.
I watched Straight outta Compton, and the performed well. For music, well they;re still beaten easily. But they're not bad. But they're not great. But since its a bluetooth, it gets a pass. Dont dish more than a buck fifty on these!
