Hey guys - is the Cayin C5 still the go-to for portability with SZ2k's? Bout to order one if so.
Technical Parameters:
Rated output power: 800mW + 800mW (32 ohm load)
SNR: ¡Ý101dB (A-weighted)
Life time: about 12 hours (32ohm load)
Frequency response: 20Hz-100kHz (+- 1dB)
Sensitivity: ¡Ü500mV (gain H)
Charge limit voltage: 12.6V
Charging time: about 4 hours (off state, the use of DC5V / 2A charger)
Total Harmonic Distortion: ¡Ü0.02% (1kHz)
Lithium battery capacity: 1000mAh / 11.1V
Weight: about 185g
American TI company specializing in Hi-Fi Headphone Power Driver IC
German company's top Hi-Fi WIMA capacitors
Japan's top ALPS Hi-Fi level potentiometer
Japan's Fujitsu's top-level Hi-Fi relay
are these stable at 16ohm? Wouldn't it then make it 1600mw x 2 (3200mw total), which isn't far off from the ifi idsd.
Anyone can clarify for me thanks. Ofc seems the ifi is more than 2x $$
