preproman
- Mar 16, 2011
Cool. Your good to go..
Just stating my actual use of the MF X-CAN V3 with X-PSU V3 and the TH900s are pretty darn good. Good synergy, good weight (not with absolute authority but enough to be substantial), good bloom in the midrange (maybe a touch over) and decent highs but not HD800-piercingly detailed highs.
I haven't gotten my PWDII DAC back from PS Audio yet (in for repairs) but will hook this up and see how large a difference the DAC makes over what I'm using now: headphone jack from PC to RCA jacks on the X-CAN V3.
Hello. Plz help me to decide and pick a better value .Yulong D100MK2 or Audio-gd NFB-5.32. or i can stay with ElitePro and get Schiit Asgard as an amp. My setup is Denon 7000 and i would pick a D100 but harsh highs worry me a bit. What do you think ?
ok. so i can go with NFB-5.32 /15.32 or my ElitePro with Schiit Asgard amp. Asgard would cost me 250$ and NFB-5.32 /15.32 near 400$
does the sound quality etc between those two setups cost 150$ difference ?
The NFB is a DAC with amp, keep that in mind. You also cannot use it as a stand alone amp, very unfortunately.
I thought the 15 would go for about $100 cheaper?
I have a pair of Denon D2000. Do you guys think it's worth getting a Schiit Magni to replace my Firestone Cute Beyond (http://www.firestoneaudio.com.au/index.php/cute-series/beyond)?
I think the D2000 sound great with this amp and it should pair well with its high current output, however the Cute Beyond being my first amp I don't have much reference. The only reason I'm considering replacing it is because sometimes I get some static without having touched the amp or the cables. I have to move the cables (or rotate them) a bit where they connect to the amp for the static to go away. I replaced the cables but it didn't help.
Any thoughts?
Any thoughts?
You should try to clean the jack contact with DeoxIT.
I don't think you will get much out of replacing your amp for the Magni. You will get a much better increase in sound if you upgrade your source first.
