Sam L
hmmm how is it that the monk plus is rated so highly on the EA Facebook group. The ME80 has like 7 votes compared to 36 (Monk plus). I don't understand. I'm so confused...
hi,Please let me know how it turns out. I'm thinking of compiling autoeq and peq files for a bunch of popular buds.
K. Will do. I didn't really give it much thought. Just captured graphs as the appeared on my desktop. But I should consider how users here would read them. Thanks for the feedback. Really appreciate it.@Sam L have you considered changing the vertical scale on your graphs from 70db to 50db? Makes it easier to read imo.
After you import it, you have to go back and search for the file you just imported. It will then appear on your pick list to usehi,
how to create custom wavelet autoeq?
I've tried to manually edit the eq text file,
but it failed to import to wavelet,
when I restore the original eq file,
it successfully imported.
test...@Sam L have you considered changing the vertical scale on your graphs from 70db to 50db? Makes it easier to read imo.
The bottom one looks better because it is more clear on what the differences are.test...
or
test...
or
first one was 25 db/decade. second was 50 db/decade2nd. Looks like you went a little closer to 40db, which looks a little exaggerated.
There is a limit setting button that opens a settings box you can set the scale at for x & y axis. I also try and put the FR towards the center and don't worry if the upper treble (10k+) drops off the graph.
Can confirm. RW-9 does bass. You can never have too much bass.Yeah, actually the rw-9 sounds pretty v-shaped for a bud. The bass on the rw-9 can hit hard. It's a bit much for my tastes.
I didn't really like Turandot either, I sold them. But my friends liked it, but they don't listen to heavy music.I only have experience with the DQSM Turandot and that is a dissapointment and I really hope the other buds at that price range is better.
I'm going to grab the ME80 despite fit issues. Perhaps the EB2 and the X6 too.
Count me in (Monk Lite 120ohm)K, guys. I'm going to start generating test targets for wavelet and peace/apo equalizer.
So far, I know of these users who use wavelet and might be interested in trying out some target curves?
- @waynes world (monk lite 120ohm)
- @Nool (rambo 2)
- @sub30 (rambo 2)
Anyone else interested?
