Alex.Grimm
Could you help me identify the logo/name/brand/diy of the earbud?
well, just buy a reserve pair, I do this quite often if I'm not sure about the quality or fearing that the release will be stopped ..
I don't mean to be disrespectful but now that I know what a "reserve pair" is, this is kind of a ridiculous comment.
I have no faith in Rose products so your suggestion is to buy two pairs? LM(f)AO - that's a big no thank you from me.
I might be wrong, bu the company seems to be Pentagram. I used to have their BT adapter with the exact same logo.Could you help me identify the logo/name/brand/diy of the earbud?
Thanks, you very help meI used to have their BT adapter with the exact same logo.
The metal PK shells of Turandot are certainly heavier than plastic PK, but I wouldn't describe it as a "heavy" earbud. Very comfortable for me.
do you know what metal the Turandot made of? i personally think even the Liebesleid and that old K's Poseidon to be comfortable to wear. even though they have a bit of heft to them, as long as it's snug in the ears the weight won't be a problem. I'm guessing the Turandot would also be comfortable in my ears
I didn’t want to offend anyone, this is my life experience: 4 pcs of Zen1.0, and 2 pcs of Zen2.0, Mojito, Masya, Kinera, AKG K317, K319, beta Asura, Asura2.0, ATH-CM7,700, SWD2 +, Yuins etc. Unfortunately, nothing lasts forever under the moon, and if I like their sound, then I am ready to pay for reserve pairs of my favorite earbuds. At least for me it works this way.
I don't have any issue with turandot fitting. It might be a bit heavy but fit into my ears nicely without feeling it might be falling.others might be better to clarify, but the Turandot is also all metal earbuds, so it may be heavy like the Liebesleid
have you tried the Simphonio Dragons? i haven't heard the version 3, but the version 2 is great sounding earbuds.
can't imagine this one working with an mx500 shell.
On Amazon Japan (https://www.amazon.co.jp/dp/B082V3X5WH/), translated by Google:do you know what metal the Turandot made of?
[Zinc-magnesium alloy housing, unique design] Surface vacuum plating, simple and classic design; ergonomic design provides comfortable wearing feeling, no problem for long time useIt is exactly like the Yuin PK shell, but constructed in metal. If the PK shell fits you well, the Turandot will also.
I tried PK1 MMCX (150ohms red film) with PK shell, after that with this metalic shell + MMCX + balanced cable and nothing.I have buyed diy PK1 MMCX (150ohms red film), but since the bass sound was felt light, I replaced it with docomo earbuds driver by DIY.
As a result of this replacement, not only the sub-bass but also a brilliant treble was obtained.
I was excited and wanted to hear these balanced sounds, so I finally pushed the buy button for a 2.5mm balanced MMCX cable.
(Oh, I'm an idiot, I buyed already converteer of the 3.5mm HIFIMAN balance to the 2.5mm balance and listened the balanced sound of docomo earbuds, but wasted money ...)
Before replace drivers:
After replace drivers:
