Earbuds Round-Up
Aug 26, 2019 at 1:06 PM Post #44,253 of 75,861
IT would be nice to know the Ohms of this new Fukubukuro
While I was placing my order for the fukubukuro, I looked at the details that are available on the page. The buds are 32 ohm...which I expected.
Aug 26, 2019 at 3:22 PM Post #44,255 of 75,861
Can someone measure the size of the Smabat ST-10 buds, and how it compares with Yuin shells (that are 16,1mm I think) ?
Already did, see below.
The ST-10s are a hair over 16mm in diameter.
Dimensions and picture for size comparison:
A couple more measurements and a shape comparison.
15.9mm EBX (17.70mm wide/thick)
16.8mm Smabat ST-10 (16.60mm wide/thick)
Top: 16.8mm ST-10, 15.9mm EBX & 15.75mm ACG
Bottom: 16.8mm MX500 & 16.1mm PK shell
Aug 26, 2019 at 3:37 PM Post #44,257 of 75,861
ClieOS did you realize that this thread is now ten years old? Thank you ClieOS and thanks for all of you that made this thread exist :) Congratulations :birthday:
Aug 26, 2019 at 3:38 PM Post #44,258 of 75,861
Worth mentioning that the ST-10 is supposed to be worn cable-up, which should help them stay in place. I can't comment on the wing tips.
I know. Part of the reason I'm concerned about fit. If the cable is tight, or if I'm running, I would imagine that the buds would naturally want to pull down. Possibly even from the weight of the cable alone. Can anyone elaborate on this?
Aug 26, 2019 at 4:09 PM Post #44,259 of 75,861
I wasn´t planning on buying anything for a long time, in fact I´m in selling mode for the time being but reading ClieOS was involved in the project my hands took a will of their own, which promptly issued a warning lament from my credit card involving the first four letters of the bud´s name.
Ten years and over four million views, thanks for pointing that out ValSilva, the baby ClieOS conceived and all of us nurtured is growing very healthy indeed, consider yourselves group-hugged!
Aug 26, 2019 at 6:24 PM Post #44,260 of 75,861
Aug 26, 2019 at 9:41 PM Post #44,261 of 75,861
I have the same question...
I already asked here if someone could measure the size of the earbuds, and compare with the Yuin shells (16,1 I think).
While the real Yuin is measured to about 16.1mm in diameter, the PK shell from other brands can measure up to 16.8mm in diameter. ST-10 on the other hand is about 16.8mm in diameter.
Aug 26, 2019 at 9:52 PM Post #44,263 of 75,861
