Thanks ClieOS, good to see impressions of these!
And how is the low end quantity and quality?
Good quality, but fairly neutral in quantity.
Many thanks for the replies. Still mulling over trying one of the Snow-Lotus varieties since they're about the same on Amazon Prime as AliExpress, but regardless, leaning towards ordering a sampler of sorts from AE with some combination of the below:
FAAEAL Iris 1.0
Fengru EMX500
NICEHCK Vido
Philips SHE3800
QuianYun Quian25
RYGMR RY4S UE
TY Hi-Z TY
Can someone link to what is commonly referred to as the FENGRU SILVERS? That's the one I saw repeatedly in this thread but couldn't find on AE. I'd probably add those or swap one of the above out to make room for it, if they're still available.
The entire list above comes out under $40 shipped, which I hope is easily worth it to narrow down signatures before moving up... and if I'm lucky, maybe even finding one I like enough to settle on and just stock up on 4 more pairs for practically nothing. There are a few options in that $12-20 range like NICECHK EB2, NICECHK ME80, and Fengru PK2 I haven't ruled out throwing into the order, but not sure it's worth doing a hapless "buffet" in that price range until I at least check out the truly cheap options first.
To answer an earlier question: I am using the included foam on both the Datura X and H180, even though I've always preferred my MX365s naked. I quickly saw the benefits of slapping on the pads for a brighter bud.
I think it was mentioned before that it has a different cable. Maybe the search function will yield some results.came across a supposedly another variant of RY4S? it's called RY4S HI. what's the difference between HI and UE?
thx, forgot about the search function but there was no direct comparison, guess nobody has both of themI think it was mentioned before that it has a different cable. Maybe the search function will yield some results.
Isn't Sabia V6 out of production now?Out of that list I only have the Vido's, EMX500, RY4S UE and Datura X. The Vido's, and then the EMX500's were both revelations when I first got them, so I suppose they are no brainers.
At this point for me, the other no brainers are:
RY4S UE
Snow Lotus 1.0+ CE (if it's still available)
Fengru Silvers
ME80
Yincrow RW9
Kube V1
and for a bit more:
Sabia V6 experimental
Willsound MK2
and for yet a bit more:
Smabat ST10 (I don't have them, but they are supposedly similar to the Svara L 32ohms which I love).
just got myself a pair of emx500 with mmcx connector since you said they are no-brainer. they truly are no-brainer indeed. the bass omg. i love these. they do look weird though with my cableOut of that list I only have the Vido's, EMX500, RY4S UE and Datura X. The Vido's, and then the EMX500's were both revelations when I first got them, so I suppose they are no brainers.
RY4S UE
Fengru Silvers
ME80
Yincrow RW9
Kube V1
and for a bit more:
Willsound MK2
And how is the imaging and stageAll I can say is I prefer the Shiro Yuki as it sounds more balanced to me
Considering the UE is not very bassy to begin with (tight and punchy enough but definately not a bassy earbud in stock), I think I'd find the HI version too bass light. But maybe the difference is very subtle.Someone did have both but I can't find the post. From memory, the HI was less bassy and more detailed than the UE version. I had also messaged the seller previously about the differences, he said UE has copper cable and HI is using SPC cable.
