There's absolutely no link between sound quality and driver impedance. If that were true, then surely the highest impedance headphone ever created would have the best sound quality ever measured, right? True, we do tend to see many high-end headphones using high impedance drivers, but that may just be as a side-effect to the design. It's always important tot remember that correlation is not the same thing as causation.
Regarding low impedance buds producing "better" bass, this is easily understood when we consider what it is that a driver is doing. All an audio file is is a set of instructions for a power amplifier as to how much power it should be outputting and when.
If we pull any track into an application such as Audacity, we will see somewhat of a waveform for each channel.
Those lines help us visualise the power that's being sent to the driver, and ultimately what the driver should be doing. All a driver does is move in and out (or forwards and backwards) as that's what causes air to move at particular frequencies, and then we perceive that as sound. When the line moves up the driver should be moving outwards, and when the line starts going down, that's the driver moving backwards.
So, the harder it is to move the driver, the harder the amplifier has to work to move the driver all the way out. As you may have noticed, easier to drive earphones can often produce better bass because the amplifier can easily deliver the power required to move the driver at the correct pace and to the correct extent. As it becomes harder to drive, the amp will start to struggle to keep up, and that's when we might hear some kind of distortion or just a lack in bass power.
Regarding the graphs for impedance and frequency, I don't have any for earbuds, but here are 3 measurements I've taken of the new Focal Stellia.
The yellow is with the amp at 0-ohms output impedance, green is at 10, and blue is at 120.
Not all drivers undergo a change in frequency response as the output impedance of an amp is increased, but many do. I suspect that this is why many people claim that headphones such as the HD600, 650, etc sound better on tube amplifiers because tube-based systems tend to have higher output-impedances. So the "improvements" they hear is most likely due to how that output impedance affects the frequency response of the driver, rather than the fact that it's a tube-based system.
