Ziggomatic
Any earbuds recommendation under 10 usd, already ordered RY4S, and EB2 and have Vido.
The Edifier H180 is a good choice at a little more than $10.
it really helps to let us know if you want a tonally neutral earbud or a frequency response that is most balanced-neutral.Neutral sounding best earbuds? Anyone?
Because many buds are below neutral point in bass and treble response or do not extend as much as neutral headphones or speakers will. But have excellent midrange neutrality.
Others have a more general neutrality with great extension and reletively neutral mids, thus overall being more accurate and neutral. These usually come in the TOTL price range though.
For instance as danneq recommended the Cypherus Zoomfred which is most likely capable of delivering an accurate bass and treble response as it is a high end earbud which others have noted for it's extension and accuracy. So coming from headphones those will sound vastly more neutral than most buds that will come off as midcentric and mid forward in comparison.
But if you want the most realistic and neutral midrange timbre a Blur earbud might be what you're looking for or the SW dragon 2 + also mentioned above as those have been praised for their mids and sounding realistic and accurate in that sense.
I am actually looking at TOTL category.
It may not be neutral, and it may not be TOTL, but all you need is the Svara L 32ohm.
(sorry - I like them - couldn't resist!l
I have been using recabled Sony MDR-E808+ earbuds today after irritating my left ear with goddam iems
How would you rate Blox TM9 and Yin with respect to neutrality?It's difficult to find perfectly neutral earbuds even in the TOTL category. Something neutralish might be Cypherus ZoomFred. It has got a slight focus on bass with very deep sub bass for an earbud. I would also say that Simphonio SWD2+ is tilting toward a neutral sound but with a slight focus on upper mids and highs. So even if Zoomfred and SWD2+ in some ways are neutralish they still sound different from each other.
Two of the most neutral TOTL earbuds I've heard are both diiscontinued: Sennheiser MX980/985 and Cypherus CAX Black edition. But those to ALSO had some differences where MX980/985 has got a bit more sparkle in the treble and not too deep sub bass while CAX Black has got that sort of "analogue" that Cypherus earbuds share - a warm and musical sound that still does not sacrifice detail.
Thank you everybody for your inputs and increasing more confusion.
So far being suggested by FM are:
Cypherus ZoomFred
Yinman 600
Puresound PS100-500 or PS100-600
Blox TM9
Which one has smaller shell?
If you want a smaller shell the SW Dragon 2 plus is probably the way to go then. The rest mentioned use mx500 type shells which are standard-larger fitting for most.Thank you everybody for your inputs and increasing more confusion.
Cypherus ZoomFred
Yinman 600
Blox TM9
