I finally received the earbuds of "Diy SR2 16ohms TPE-wire" in the link below.
https://www.aliexpress.com/item/diy...ohms-32ohms-150ohms-TPE-wire/32801646835.html
Before, I purchased and liked "Diy SR2 PRO 16ohms Silver plated-wire" which uses the same driver, so I recommended this to everyone in this forum.
However, because I began to feel that the treble of this earbuds sounds too sharp and strong, I changed the connection to the copper wire cable of Shozy Cygnus. And it became a sound signature of V-Shaped which is sufficiently beautiful treble and strong bass, although this is Docomo/PK Shell type earbuds.
So I purchased the earbuds of "Diy SR2 16ohms TPE-wire" version which uses copper wire .
It is burned-in for only 20 hours yet (100 hours needed), but it has a similar sound signature.
I think this has the best V-Shaped sound among earbuds of 16ohms Docomo/PK Shell below 50usd.
I could purchase it at 12usd by negotiation to seller, I will recommend strongly this earbuds for 11/11.
As earPad I recommend you double Pads as to put the DounutsPad on the VE thin Pad.
Perhaps It is seemed that I am boy who cried wolf...
(Before, I'm very sorry to those who purchased the "Diy SR2 PRO 16ohms Silver plated-wire".
But they can make sound similar by changing to connect to the copper cable like fengru.
By the way, the driver of "Diy SR2 16ohms" Is 11.33usd in the link below.
https://www.aliexpress.com/item/SUN...fever-headphone-unit-A8-style/1984665598.html)
