haiku
- Mar 4, 2016
The beautiful Bel Audio Ampas Pandawa Nganu
![IMG_0667.JPG IMG_0667.JPG](https://cdn.head-fi.org/a/10124485.jpg)
On sound quality, yes they are side grade, although there are things that might not be replicated exactly with eq between them. If you like a more V shaped and a but more energetic sound you could buy the MK2, but otherwise youcould skip itwould be insane!
Fixed that for you![]()
yes, at that price it's easy and logical to go all out pokemon on the willsounds![]()
I say the above without having heard any high end earbuds except for Zen 1 & 2, so that is to be factored in to my all out pokemoning.
How would you rate the Zen 2.0 to the MK2?
I have the Asura 2.0s which I feel the MK2 to be superior, and it being of a way lower impedance (150 vs 32ohms) is definitely a plus for me as well...
Which MK2 is it?
Willsound MK2...
Shozy Cygnus or BK? Because I consider them in different leagues.Can someone help me the Shozy clones that are around. i read few times that there are same shell buds on Ebay that have a very similar sound under 30$. I can't find that info on HeadFi... Any help will be appreciated.
Chinmie has said he prefers the MK2 over K’s Samsara which was roughly $130-150 too right?LOL Zen 2.0 is at least $150
I hear that the driver of black version 1, 2, 3 are different.
And I think that parhaps the the driver of black version 3, 4, 5 are same, and only color of shells or cables are different.
Thanks. Perhaps it's fair to assume 3 and 4 are the same since the product description doesn't distinguish between them on a technical basis. I contacted NICEHCK yesterday to clarify if there's a difference, but haven't heard back from them. If they reply, I'll post their response.
Maybe it’s a TOTL killer ^^
