snip3r77
- May 13, 2010
Mk1 vs mk3 is it a side grade ? If it's very similar I'd skip thisAnd don't forget the balanced cable drama over there.. Classic![]()
Oh no.. you unluckyJust gotten my MK3 back and the new PK32...
Replacement MK3 is great and using it now...
Also really liked how the PK32 sounded when I plugged in it but realised the right side was softer and now the right driver has totally stopped working altogether...
Guess I'm not really lucky again and will have to see what Rholupat or Willy can do about it...
Edit: It was the right driver that failed instead of left.
Oh no.. you unlucky
Really counted on another PK32 new fresh impression, hehe
From your working beginning on it, how was your quick feeling on bass domain ?
(Can't wait to receive my PK32 replacement pair)
On first listen to the PK32, bass was lesser than MK2 but definitely there. They sound really different enough from the MK series, whereas the MK2 and 3 share the same sound signature.
MK2 comes off as more clinical and MK3 being warmer, but both have that "balanced" sound.
Also, something to note was that glue marks were also quite prominent on the shells of my PK32 and that the right driver cover had some white stains (around the tiny holes where the sound comes out). Not sure if they're related to the failure though. I have feeling the PK32 are harder for Willy to work with because of the smaller shell, hence more prone to QC issues?
Either way, Willy has assured me that my unit will be replaced and I won't be dealing with Rholupat from now onwards...
darn it.. twice in a row.. i hope you got the third one working properly. glad to hear that willy himself took the on hand solution for this
My actual PK32 pair seems to suffer a bit the same, it has a little scratch on the grid of the left shell and the right pair is not perfectly white but has some kind of yellow glue in some spots. Also, I remarked some white glue on the left grid from shell also.Also, something to note was that glue marks were also quite prominent on the shells of my PK32 and that the right driver cover had some white stains (around the tiny holes where the sound comes out). Not sure if they're related to the failure though. I have feeling the PK32 are harder for Willy to work with because of the smaller shell, hence more prone to QC issues?
I found MK2 and MK1 was much attentioned about bulding quality, but nothing to really worry anyway.
@handwander or @RobinFood : I need your help~ B&O Play White (Wireless Earbuds) will be released at e-earphone on 14/06/2018. Could you go to trail listening it and share your impression here?
Did you tried cleaning the plug ? sometimes it can help.EDIT 3: Back to only right side dead. Sound is still bad come front left driver. Just packed it up to be shipped off tomorrow. No more messing around with them.
I tried to plug very slowly jack to my source to see if there is any difference and.. not(I heard left driver on, then the second, and them both which is the normal behaviour when you plug classic 3,5mm plug).
When the left driver worked I gave a quick listen and it sounded the same as fully plugged, so looks like we have different problems, but the fact you did didn't had bass like me is quite interesting.
Anyway, I will wait for my PK32 replacement too and see. We stay tuned![]()
