JKDJedi
(My IE match has always been off. Pre-amp or direct does not make a difference for me. Still distorts at around the 11-12 o'clock mark.
I'm seriously considering buying the Cayin C5 just to make sure that my dac/amp isn't defective. Or maybe my SZ2000's are defective. Man...I'm getting a bass-load of regret right now.
FWIW, this is iFi's response:
Thanks for your update.
To test if the unit has a problem we advise to run without any EQing. If you are adjusting the EQ for bass and flick XBass at the same time you may get bass distortion but this is down to a number of factors from EQ, XBass, type of HP, track, other devices in chain etc.
We can not test as we do no have the same HP or audio track to test. Past that you are also running the iDSD BL in Turbo mode so if your HP's are easily driven and use Turbo mode (4Watts), plus XBass and EQing mods then distortion maybe present.
We advise to dial in the power setting so you have volume past 12 o'clock and that the volume is comfortable. If the HP is too loud before 12 o'clock then they are driven rather quickly.
Past that we haven't had a problem with the BL or iDSD (silver) regarding distortion in bass which is why we recommend to rule in / out some factors.
Hope this helps.
Thanks.)
I was gonna ask, what's the power difference (watts per channel) between the 2 dacs your using/comparing?
Hope this helps.
Thanks.)
