Earbuds Round-Up
May 25, 2024 at 1:21 PM Post #75,601 of 75,871
May 25, 2024 at 2:59 PM Post #75,603 of 75,871
More 130 ohm Bery's!
Thanks to @Mr.HiAudio. One of the best sets of Buds I have.
May 25, 2024 at 4:53 PM Post #75,607 of 75,871
Hi everyone,
I was just on Aliexpress to order some more nicehck silicone rings. Decided to order some of the favorites in here, that come up every now and then... Also choice on Aliexpress is somewhat limited in Europe, so better to get them now, before the choice gets even less.
Aeolian Bells, Ry4s 32 & 300 Ohm, and Nicehck Eb2S pro are in the shopping cart.
What is the difference in Eb2S pro and non pro version? The non pro seems to be generally a tiny bit cheaper in the shops. One particularly interesting offer at 14€ for the non pro version.
I won't get it just because it's cheaper - want to know the difference if any one of you has both! (Edit: both seem to use the same driver, 32Ohm LCP, 112db/mw...)(Edit2: couldn't wait any longer - ordered the non pro version, as it was more than 50% cheaper than pro... Reviews seemed euphoric for both. Finally I DID indeed order it just because its cheaper. 🤦)
Thanks. 🙂
May 26, 2024 at 1:47 AM Post #75,608 of 75,871
Hi everyone,
Thanks. 🙂
The upgrade of "NICEHCK EB2S Pro" is the cable, which has been replaced with a mixed cable of silver-plated wire + OCC (high-purity single crystal copper) wire, instead of the conventional OFC (oxygen-free copper wire). Superior vocal and bass performance is achieved by using higher purity and higher quality cable.
May 26, 2024 at 2:14 AM Post #75,609 of 75,871
Thank you - this is solid info!
May 26, 2024 at 3:06 AM Post #75,610 of 75,871
How to use earbuds comfortably as canal-type earphones when earbuds do not fit in the ear, like the MX500 type.
1. buy "SM-R130" ear tips from Amazon or other retailers.
2. buy thin stemmed ear tips such as Sony Hybrid.
3. Put "1" on the earbuds.
4. Screw the stem of "2" into the stem of "1" while turning it.
Canal-type earphones are completed!
May 26, 2024 at 9:19 AM Post #75,615 of 75,871
My Berys (LREY's W03 Pro):
