Sacred music and chants via APWS/dongle/Arte on MacBook Air :
The back cover of the FF3 is slightly curved, outward.
I had to use some Kapton tape to pull the back loose. It appears to have been glued on - so I'll have to clean it up a bit, and then re-glue it.
I find the 3000 to be a little small for my ears and movement tends to make them move around. Using a thicker foam can help (the issue decreased for me when I started using Fiio bass foams, for example). Putting a silicone ring onto the bud underneath the foam can also help.Hello, is there something that can be done to improve fit in ear? I feel like I have to keep readjusting rw-3000 every 15 minutes to keep from feeling like they’ll fall out…into the sink while I’m washing dishes, to my horror, haha. Relatable or just my ears?
You can use something like this.Hello, is there something that can be done to improve fit in ear? I feel like I have to keep readjusting rw-3000 every 15 minutes to keep from feeling like they’ll fall out…into the sink while I’m washing dishes, to my horror, haha. Relatable or just my ears?
Is the weight of the cable pulling them out of place or is it the twist of the cable after the Y splitter? If weight, then use a small clip to attach the cable to your shirt so the weight of the cable is lessened. Could also adjust the chin slider up toward your chin which will help, that will tighten the cable and the buds will be more secure. If caused by the cable twist you can rotate the buds so the cable twist is neutral or slightly twisted to cause the rear edge of the bud to twist inward toward the ear Concha. That will help to lock the front of the bud into the Tragus / Antitragus. I hope that makes sense.Hello, is there something that can be done to improve fit in ear? I feel like I have to keep readjusting rw-3000 every 15 minutes to keep from feeling like they’ll fall out…into the sink while I’m washing dishes, to my horror, haha. Relatable or just my ears?
I love the RW 3000 and use them a lot, but I can only use them stem up and cable over ear. Then they have a pretty good position and won’t fall out of my ears.Hello, is there something that can be done to improve fit in ear? I feel like I have to keep readjusting rw-3000 every 15 minutes to keep from feeling like they’ll fall out…into the sink while I’m washing dishes, to my horror, haha. Relatable or just my ears?
I use over-ear way for all buds and have not noticed any drawbacks. So for me the way is more natural rather stem-down one.I love the RW 3000 and use them a lot, but I can only use them stem up and cable over ear. Then they have a pretty good position and won’t fall out of my ears.
Or, if you don't like the "wings" in your ears, you could use something like this:I love the RW 3000 and use them a lot, but I can only use them stem up and cable over ear. Then they have a pretty good position and won’t fall out of my ears.
Yeah, i find that silicon wings help preserve subbass but can increase/decreases soundstage depending on the earbuds, they also improve clarity and details, and they will also give you a more consistent and secure fit. Most earbuds don't fit me securely it's why I have a bunch of them.And the sound is better !
It's called antidrop silicon horns/wing
I used it alot in my earbuds that doesn't fit me securely
Thank you, I like this option even more! Where’d you get yours?And the sound is better !
I'm not aware of such one - just place buds to get comfort and use slider. Probably it is individual for everyone to find that golden position.Is there a trick to wearing them this way?
