It is an internal acoustic tuning cavity within the shells of a good number of Smabat models... 3D acoustic maze structure in the shape of a labyrinthWhat are "labyrinth-maze acoustics"
You are very welcome good sir. We can't have our resident "encyclopedia" missing information can we?You are awesome! Thank you.
I am looking into trying to find what those used (and the M0 also).Completely forgot about the available modules for M2s Pro... I added all those. Your astute call out shook up the ole' gray matter and reminded me that the M2 Pro 2021 Version also used the same modules as the M2s Pro. I also added the three types of tuning dampers as well.
I don't recall that, but thank you for bringing it to my attention. I didn't see those available to purchase when I bought my modules for the M4.Regarding the M4 module drivers... you might recall the 40ΩTi (M2s Pro) driver was only available for a very short time for the M4 (pic here in a detailed M4 post from @mt877). It came and went in a blink of an eye.
I am trying to look into it. I will make another post on stuff I have found.I still need to have someone double check the listed tuning damper and driver modules that were available for M2 Pro, M0, and M3 Pro.
This is what I have thus far:
Smabat M2 Pro; 40Ω (1st Gen Modular Earbud w/ 2nd Gen Labyrinth-Maze Acoustics; two (2) tuning modules: type 0 and type 1)Smabat M0; 20ΩTi (1st Gen DIY Modular Earbud; three (3) tuning dampers: type-1, type-2, and type-3; other driver modules: 40ΩTi (M2s Pro) and 100ΩBio (Super One aka Super Point))Smabat M3 Pro; 150Ω (3rd Gen Modular Earbud w/ 3rd Gen Labyrinth-Maze Acoustics; ST10S Black-Gold 150ΩTi driver w/ two (2) tuning dampers: type 01 golden and type 02 black)
What @WoodyLuvr said, and you can have a look at them (for the ST10S) HERE. Scroll down to the "Internals" section to see pictures.What are "labyrinth-maze acoustics"
@WoodyLuvr It looks like the same drivers and filters were available for the M0 and M2s Pro as seen HERE.
And for the M2 Pro 2020 our very own @baskingshark can probably best answer this (as seen HERE). It looks like there are actually 3 drivers for it. The stock one (40LCP???), the 150ti, and another ti (which I am going to guess as the 40ti), and 2 filters (type 0 and type 1).
As for the M3 Pro, I can't find any other options for the driver modules besides the stock 150ti, but one site said the filters were type 0 and type 1.
Also, didn't @mt877 find out there are actually 4 tuning filters for the M4 (0, 1, 2, and 3)? The stock one was the 0 IIRC, and you can't buy that one, except as stock when you purchase the M4 itself. Or am I forgetting and mixing it all up? I guess I am too lazy to search this thread... ROFL
Yep, there are 4 tuning dampers, originally they weren't including the Type 2.5, but now they are. Smabat is selling the damper set with all four dampers now.@WoodyLuvr It looks like the same drivers and filters were available for the M0 and M2s Pro as seen HERE.
It's like a labyrinth, but kinda mazey, or like a maze but more labyrinthy.What are "labyrinth-maze acoustics"
A team effort! Very much appreciated!You are very welcome good sir. We can't have our resident "encyclopedia" missing information can we?
F'n outstanding I declare! Thank you for breaking out the crayons and bringing it down to my level (links are great). I will add/correct the timeline here shortly,@WoodyLuvr It looks like the same drivers and filters were available for the M0 and M2s Pro as seen HERE.
Very well put good sir! I was too lazy to extrapolate.In theory, if implemented properly, an acoustic labyrinth concept lengthens the sound tubes within a shell by squeezing longer tubes in a limited space, so as to increase sub-bass quantity. Because higher frequency sounds are dissipated first, when the sound travels over a prolonged period via a mazy longer tube, the bass may be emphasized.
Earbuds are generally slated for having weak sub-bass, but if you have heard some Smabat earbud eg original ST10, these generally have huge sub-bass because of this creative configuration.
Yep I think u are correct!
Bingo! So in regards to this fourth tuning damper for the M4... should I refer (mention) that it was originally Type-0 but now known and sold as Type-2.5 (M4 - 2.5)?Yep, there are 4 tuning dampers, originally they weren't including the Type 2.5, but now they are. Smabat is selling the damper set with all four dampers now.
Tuning dampers set: https://www.smabat.cn/smabat/products/50939655.html
You're talking about for use with TGXear Sunniva... correct?The bass tuning kit is on the road![]()
ahh I see. I also found a diagram. I'd be curious to know if there's any difference between this and a stem vent, especially since the upper diagram seems to be more a straight line than a labyrinthIn theory, if implemented properly, an acoustic labyrinth concept lengthens the sound tubes within a shell by squeezing longer tubes in a limited space, so as to increase sub-bass quantity. Because higher frequency sounds are dissipated first, when the sound travels over a prolonged period via a mazy longer tube, the bass may be emphasized.
The Z1R iem has a similar spiral-shaped tube behind its largest driver!![]()
Originally Smabat called the default damper M4+type3, but that really caused a lot of confusion because in the first damper set the dampers were labeled Type-1, Type-2 and Type-3. So the confusion arises because they didn't supply a Type-4 as shown in the picture below.Bingo! So in regards to this fourth tuning damper for the M4... should I refer (mention) that it was originally Type-0 but now known and sold as Type-2.5 (M4 - 2.5)?
Indeed. Also unlike a stem turbo vent it's capped with a mesh grill, that probably changes things somewhat. I wouldn't be surprised if it has the same effect as a stem vent but in a more compact shape though, my understanding is that you can do the same thing with a speaker's rear volume to simulate a longer chamberNot sure about the upper diagram, but there seems to be a longer spiral acoustic design in the Smabat earbud picture you showed:
As for the Sony Z1R, that IEM is endgame for bass quality with quantity (if well fitted - the fit is damn iffy). Perhaps this spiral acoustic design plays a part for this nice bass?
Much appreciated; Svara-Smabat timeline fully updatedOriginally Smabat called the default damper M4+type3, but that really caused a lot of confusion because in the first damper set the dampers were labeled Type-1, Type-2 and Type-3. So the confusion arises because they didn't supply a Type-4 as shown in the picture below.
In reality, Type-1=type1, Type-2=type2, M4+Type-2.5=M4+type3 and Type-3=type4, where "New name" = "Old name"
Smabat realizing their mistake then corrected it and released a 'revised' tuning damper chart with the correct naming scheme.
And here's more info:
Here's the old suggested tuning for M4 and different drivers. I remember seeing an updated tuning chart which suggested slightly different damper suggestions.
You can't forget, they also had a BA module for the M4. Surprisingly, or maybe not so surprisingly the BA module sounds very good with the M4 base and default tuning.
