ADVICE NEEDED RE HEADPHONE AMP!
I currently have a Megatron, and it's been good to me, but my favorite buds are my Yinman 600s, and I want to get the best out of them! Several people have posted that the Megatron is “good” with the Yinman 600s, but won’t bring out their full potential. I also have Sundaras, which I’m sure would open out more with additional power, and a Serratus and FF3. I want to be able to drive other high impedance buds if I get them.
So I’m looking for an amp, or amp/dac, hopefully under $200. I listen to classical, jazz, blues, male/female vocals, classic rock, world. I like some bass, but I’m not a basshead and don’t listen to metal, rap, or hip-hop.
@samandhi has recommended many times that an amp should have 1 W to 1.2 W @ 32 ohms for the Yinman 600s, and at least 80mW @ 600 ohms.
Megatron
- Many of you have one
- DAC: SABRE ESS9018K2M, bitcoding up to 24bit/96khz.
- MAIN QUESTION: Would it be good enough as a DAC with any of the amps below, or would I need to get something else? If so, what would you recommend?
Here are some of the amp and dac/amps I’ve been looking at, but I’m open to any brilliant suggestions!
Topping L50
- Lots of power @ balanced output
- 2800mW x2 @32Ω
- 290mW x2 @600Ω
- 3 gain settings
- Very high ratings from ASR (AudioScienceReview)
- Too sterile?? Your opinions?
Schiit Vali ++
- Tube rolling sounds like fun (as long as I keep it sensible)
- I like a warmer sound. Love my Yinman 600s. (But also want soundstage, separation, detail, and timbre.)
- Looks like enough power for the Yinman 600s, right?
- Maximum Power, 32 ohms: 1500mW RMS per channel
- Maximum Power, 600 ohms: 200mW RMS per channel
- No balanced output – does this matter?
- Low gain/high gain settings
Fiio K7
- Love to hear comments/recs from those who have one @o0genesis0o (especially comparing it to Megatron, especially with Yinman 600s)
- Integrated DAC/AMP
- Balanced output: 2W @ 32 ohm; 560 mw @ 300 ohm
- 3 gain settings
Thanks for all your input!
I am really liking the looks of the stats on the Shiit Vali. Shiit is very well known for making great amplifiers for less. I just recommended that one to someone JUST yesterday (ironically). As
@ttorbic mentioned, you need to also look at the "other" numbers also if you don't have a chance to audition the amp. This one has REALLY good numbers for the price in comparison to a lot of others in this range. THD and SNR are two very important things to look at here as well, and this amp has very good numbers for the price. Just to compare, my iBasso DX300 (which originally cost $1200) has a SNR of 130dB, depending on the amp card and gain settings. It is said that the human ear can't hear past (roughly) 125dB or so....
@baskingshark might be on to something with his rec also. That one has better numbers and more power for only $50 more.. Just a thought.
As for the the difference between the OG Vali, the Vali+ and the Vali++, the real difference is the tubes used from the factory. Shiit had a hard time sourcing the tube from the Vali+ so changed it up. The other difference is simply the landing for the tube, and they changed a capacitor used on the PCB. Otherwise, it has remained pretty steadfast in its build and quality.
One of the great things about the Vali is that on low gain, you have less than 1Ohm of output impedance (.4Ohms), which is necessary if you want to listen to anything with low impedance and high sensitivity. This will mean that it should sound totally black.
As for having a balanced output, most times it is used more for high impedance gear because normally (especially on a portable) it outputs more power and has better numbers (SNR, THD+N, etc...). This is not true with the Vali, as you have seen it puts out some really good power for the price from SE. As for crosstalk (the other reason for balanced), the SE implementation seems to be very competent, and you should hear no noise due to this, and separation should be very good on this.
As for "auditioning" one, this could be a match for you, because Shiit has a 15 day return policy, and since you are in the US, it shouldn't be a hassle.
Having said all of that, I am not necessarily pitching this amp specifically..... What I might do is look at some of the best known amps (i.e. WooAudio and etc...) and look at all of their numbers. Costing thousands of dollars you can see what specs compare to what you are looking at. There are a "crap-ton" of amplifiers to look at in the Chinese market, but it really is a crap-shoot. While on paper the numbers might look good for some of those, they might have a cheap build, or compromise "somewhere" that most won't know about until its too late. I am certainly NOT saying to stay away from them, but unless you like to experiment, I would remain leery of "unknown" brands. But that is just me, and YMMV.
And finally, I would look at some reviews (quite a few, don't rely on just one). You can find the Vali++ reviews page
here.
I know previously you were recommended 1W @32 ohms but that is at the bare MINIMUM.
This is very true. I did mention that I normally would take the "needed" power output and at least double it for voltage swing, but I guess I never stated this to be the bare minimum outright. Good call!
On the other hand, I think that these can be really enjoyed at those voltages too.
![Headphone Smile :) :)](https://cdn.head-fi.org/e/headfi/smily_headphones1.gif)
I don't want to dissuade others from shying away from these buds because they think they need to mortgage the house to make them sound good.
https://smartstore.naver.com/burubeat/category/9f4a528f80cb468ea143c71186fd6533?cp=1
Here you go. Not just earbuds, they also have cables and other accessories. I am after the Mithril (Berserker 4), because of the mmcx bell shaped shells.
I did a quick check and so far, I do not have ANY CHi-FI earbuds in my collection! It started with Swedish and Canadian, then Korean, Indonesian, Filipino, British...hmm, may be someday a Singaporean (Blur) will add to my collection. I am not sure if I will go for Chi-Fi before auditioning them. I have given preference to the Artisan earbud makers over Chi-Fi because of the ability to consult with the makers directly before deciding on a purchase.
Oh, awesome... Thanks for sharing that. I will have a look at those.
A little box got handed to me by my Wife this morning. So much for stuff arriving unnoticed!
Inside were a pair of Yincrow X6. Much better fit for me than the EB2s so I'll be more keen on trying other buds in the MX500 style. Size of soundstage was impressive compared to IEMs and it's nice to have an option that lets in more ambient sound when I don't need isolation. Just as enjoyable a listen as some of my $50-$80 IEMs. I'm blown away by how good these sound.
Congrats on your new shiny!
You are in luck if you are wanting to try some more MX500 shells... It is a mainstay in the earbuds world (as you might well know by now), and you shouldn't have an issue finding any. Also keep in mind that a lot of DIY buds are made in this shell too.
The X6 have been around for a long time now (and there is a reason for that). They are a great entry point for "high end" audio in earbuds and show you what contemporary buds can be capable of without paying very much at all.
