mochill
US $7.99 | 5 Pair Flat head earphones silicone sleeve, protective sleeve, sponge anti slip rubber eartips for vido x6 Stellar TC200 EMX500
https://a.aliexpress.com/_mOGLiDe
Just released, I don't have them yet
These look like they would just smother the frequency response of an earbud. Have you had success using them? How do they tend to effect things like the tuning, soundstage, detail retrieval, etc?
A bit complicated, but good to know it's possible, I will order oneSend them a message saying that you want one. They'll send you a link to a $1 service charge and you'll change that quantity to 10 or 12 or whatever that covers the coat of the plug with a note with the purchase that says you're buying a 2.5mm balanced tip for your FF3s and they'll ship one out to you. At one point they had the 2.5mm up as an item, but that's what they had me do.
Ok, that link now says item no longer available. Looks like you'll have to use mt877's method above, but I'm sure they will hook you up.I ordered 2 for my FF3 and FF5, but it won’t come up in app, and the mobile site just takes me back to the app. In the Fiio store, under accessories, then After Sale (I think), there was an option to buy the 2.5 tip. I’ll try my desktop in the morning and add a link.
This is not ranking list, only I recommend these.Which foams are good ? Any list of foams rankings etc?
・Ex-pack LITEE: https://www.veclan.com/engappliance_sel_one?eng_ApplianceVo.eac_id=14
・HieGi foam: your country amazon
As I mentioned before, be careful with Trig Rain's red and blue foams, as the color will shift.Concur. The Ex-Pack LITE has a nice selection of different density foams and doughnut foams in various colors.
Trig Rain also makes a variety pack of different colored foams but they all seem to be about the same medium-to-thick density.
The HieGi sets are nice and dense. For my ears they’re the most comfortable of the three. They come in standard and doughnut versions in either white or black.
Now I need a reliable seller on AliExpress.Yes indeed !
At the end, it seems it will be the RW3000
Any recommendation about best cable to pair with, to soften the highs ?
Like I wrote, I have a graphene cable that I bought for RW2000, but I find it a bit heavy...
