thedjkhalid
Hmm in that case I would probably lean towards the M4. Is the fit better? The M2s Pro's fit was pretty okay/good for me, compared to mx500s. Wasn't uncomfortable.OIC.
Yes, they are the same driver (IIRC). In my experience with both the M2s Pro and the M4, the stock (40ohm) driver doesn't have the bass that the other (especially higher ohm) drivers have. I would say that they sound very similar overall, so what you are hearing with the M2s Pro you will hear similar with the M4 (just a bit of a difference in the shell makeup). But to me, the good stuff is really in the other drivers you can get for both/either of them (not that the 40ohm driver is bad by any means).
So, if given a choice of only one of them (knowing what I know about both), if I were going for sound quality alone, the M2s Pro are just a tad bit better to my ears, but the M4 are overall nicer (more mature). I would say that if the 2k region doesn't bother you, then you really can't go wrong with either.
If you have the money, I would buy the m4 and exchange the M2s Pro and have both to compare for yourself... Though I would highly encourage you to get at least the 150ohm Ti driver or the Super One 100ohm bio driver for both (if you can). Or (not to throw too much of a curve ball at ya') the ST10S B&G (150ohm Ti) is still available also, and those have some REALLY good bass response. Just my $.02 though!
I have heard many things about the ST10s driver, especially on the DIY end. I think I will probably choose between the Super One driver and ST10s and looking into it more.
